Home » Eclipse Projects » Remote Application Platform (RAP) » NLS support fpr german language
Re: NLS support fpr german language [message #88651 is a reply to message #88593] |
Tue, 20 May 2008 03:40   |
Originally posted by: fappel.innoopract.com
what do you mean by implement? Language packs are simple fragments that
contain the translation property-files only.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Markus Krüger [mailto:krueger@ion.ag]
Bereitgestellt: Montag, 19. Mai 2008 19:47
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: NLS support fpr german language
Betreff: Re: NLS support fpr german language
And how can I implement the language packs in RAP?
For examle the org.eclipse.jface.nl_de_0.2.0.v20080518043402.jar to get
the correct labels for dialog buttons...
Markus
"Rüdiger Herrmann" <rherrmann@innoopract.com> schrieb im Newsbeitrag
news:g0s571$dv4$1@build.eclipse.org...
> Hi Markus,
> RAP itself does not provide language packs. You could have a look at
> the Babel project for a start:
> http://www.eclipse.org/babel/downloads.php
> It provides translations for the 3.3 Workbench. With some exceptions
> they should also work for the 3.4 code base.
> This newsgroup entry:
> http://dev.eclipse.org/newslists/news.eclipse.platform/msg68 187.html
> points to a tool to compare 3.2.1 to 3.3. It might also work to
> compare other versions.
> This SVN repository
> http://publicsvn.bestsolution.at/repos/java/eclipse-language -packs/
> contains the nl1 (de, fr, es, it, pt) language packs for Eclipse 3.3.
> Please note that support for extension point localization works for
> 3.3 code base. Support for the 3.4 code base will come with one of the
RCs.
> Cheers,
> Rüdiger
> Markus Krüger wrote:
>> Do you have fragments or somthing to change RAP to german
language(i.e.
>> Button "cancel" to "abbrechen")?
>> Regards,
>> Markus
Re: NLS support fpr german language [message #88795 is a reply to message #88781] |
Tue, 20 May 2008 08:00   |
Originally posted by: rherrmann.innoopract.com
Hi Markus,
have you read the documentation about internationalization in RAP?
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. rap.help/help/html/advanced/internationalization.html
Rüdiger
> I know that from RCP, but with RAP the locale comes from the browser,
> doesn't it?
> May be you can tell me what to do to get German button lables for dialogs
> for example.
> Regards,
> Markus
> "Frank Appel" <fappel@innoopract.com> schrieb im Newsbeitrag
> news:02f901c8ba4c$b7eccf10$6402a8c0@Abulafila...
>> Hi,
>> Ciao
>> Frank
>> Regards,
>> Markus
>>> Hi Markus,
>>> This SVN repository
>> RCs.
>>> Cheers,
>>> Rüdiger
>> language(i.e.
>>>> Regards,
>>>> Markus
Re: NLS support fpr german language [message #88869 is a reply to message #88851] |
Tue, 20 May 2008 11:51   |
Hi Markus,
you just need to put the NLS fragments mentioned earlier in this to
your launch config/deployment.
Rüdiger
> Hi Rüdiger,
> I read the documentation and I know how to translate my own plugins
> (following the guide from
> http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. rap.help/help/html/advanced/internationalization.html).
> I'm just wondering, how the "standard" plugins like jface can be translated,
> and what I have to do for it to get it work, because I think, that there is
> also a special RAP messages file needed that does the translation as RAP
> needs it???
> Regards,
> Markus.
> news:g0ueg6$eeu$1@build.eclipse.org...
>> Hi Markus,
>> Cheers,
>> Rüdiger
>>> doesn't it?
>>> for example.
>>> Regards,
>>> Markus
>>>> Hi,
>>>> Ciao
>>>> Frank
>>>> Regards,
>>>> Markus
>>>>> Hi Markus,
>>>>> This SVN repository
>>>> RCs.
>>>>> Cheers,
>>>>> Rüdiger
>>>> language(i.e.
>>>>>> Regards,
>>>>>> Markus
Re: NLS support fpr german language [message #90340 is a reply to message #88869] |
Tue, 27 May 2008 11:38  |
--------------040303020105030106050709
I think, adding the fragment only doesn't work out of the box:
1. The fragment host differs (org.eclipse.rap.jface instead of
org.eclipse.jface)
2. In JFace all translated texts are in a message.properties file. In
RAP, there exists another file dialogmessages.properties which contains
labels for dialog buttons. So, there must be a translated version of
this property file in the fragment which isn't the case in the original
version.
However, if these issues are fixed, the approach works.
Markus: A German version of the latter file is attached.
Stefan.
R
Current Time: Sun Aug 31 05:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.05498 seconds
