Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP Test Results with "no verdict" while Total test performed reported
Re: TPTP Test Results with "no verdict" while Total test performed reported [message #89165 is a reply to message #89150] |
Thu, 30 November 2006 23:10   |
Originally posted by: jaikumar.sharma.barco.com
Hi Liz,
Thanks for your response. Actually I execute JUnit tests headless using
TPTP, when I execute JUnit tests in Eclipse UI, I always get 100 percent
pass result, but when I try to execute the testsuite headless then at times
(randomly) I get the Test Execution History report like (which is attached)
in which Total test are reported, but no verdict appears -- either it is
pass or fail or error .. etc.
Jaikumar
"Liz Dancy" <lizdancy@ca.ibm.com> wrote in message
news:ekmu38$j56$1@utils.eclipse.org...
> Could you provide more information on when you are seeing the reports with
> no verdict? A screen capture of the Test Log View or a test log file would
> be very helpful in narrowing down what is causing this.
> Sincerely,
> Liz Dancy
> "Sharma, Jaikumar" <jaikumar.sharma@barco.com> wrote in message
> news:ek5s98$9c2$1@utils.eclipse.org...
>> Hi,
>> I have stumbled in TPTP test reports, in which total tests peformed are
>> reported but there is no verdict reported either -- pass / fail / error.
>> I have same report as shown under comment#19 in the following URL in
>> which
>> Total tests on the top of the report are reported but no verdict (pass /
>> fail / error)
>> https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&a mp;id=144045
>> I am platform includes the followings for the TPTP and BIRT :
>> birt-report-framework-sdk-2.1.1
>> TPTP-SDK-4.2.1
>> GEF-ALL-3.2
>> emf-sdo-xsd-SDK-2.2.1
>> Awaiting your response!
>> Thanks!
>> Regards, Jaikumar
Re: TPTP Test Results with "no verdict" while Total test performed reported [message #89446 is a reply to message #89165] |
Tue, 05 December 2006 16:17   |
Hi Jaikumar,
Do you know if the test execution histories contain the correct
verdict? I want to know if this is the problem with the report or the
execution histories are not recording the correct verdict.
Does your junit test reference other junit tests?
Sheldon.
On Fri, 1 Dec 2006 09:40:50 +0530, "Sharma, Jaikumar"
<jaikumar.sharma@barco.com> wrote:
>Hi Liz,
>Regards,
>Jaikumar
>> Sincerely,
>> Liz Dancy
>>> Hi,
>>> which
>>> fail / error)
>>> TPTP-SDK-4.2.1
>>> GEF-ALL-3.2
>>> Thanks!
>>> Regards, Jaikumar
Re: TPTP Test Results with "no verdict" while Total test performed reported [message #89462 is a reply to message #89446] |
Tue, 05 December 2006 23:10   |
Hi Sheldon,
Thanks for respone!
I think execution history does not contain correct verdict. I can see the
following contents in the file -- ResourceContents inside
LoggerTest.execution as as a result of running LoggerTest.testsute.
____________________________________________________________ ____________________________________________________________
<Common_Testprofile:TPFExecutionResult xmi:version="2.0"
xmlns:Common_Testprofile="http://www.eclipse.org/hyades/models/common/testprofile.xmi"
id="F783B9E0EA62B0BFE2A28BB0837411DB" name="LoggerTest"
type="org.eclipse.hyades.test.java.junit.testSuite">
<executionHistory>
<executionEvents xsi:type="Common_Testprofile:TPFMessageEvent"
timestamp="1165376663689"
text="System.out:
log4j.properties
</executionHistory>
<test xsi:type="Common_Testprofile:TPFTestSuite"
href=" src/com/barco/cmstest/foundation/logging/LoggerTest.testsuit e#F783B9E0EA62B0BFE2A28BB0837411DB "/>
</Common_Testprofile:TPFExecutionResult>
____________________________________________________________ ____________________________________________________________ __
My JUnit test does not refer to other JUnit tests. Kindly let me know, in
case you need further info.
Jaikumar
<sleeloy@ca.ibm.com> wrote in message
news:qbobn29ct25cc3ppisqcvuf5vr2gfremt2@4ax.com...
> Hi Jaikumar,
> Sheldon.
>>Hi Liz,
>>times
>>attached)
>>Regards,
>>Jaikumar
>>> with
>>> would
>>> Sincerely,
>>> Liz Dancy
>>>> Hi,
>>>> error.
>>>> which
>>>> fail / error)
>>>> TPTP-SDK-4.2.1
>>>> GEF-ALL-3.2
>>>> Thanks!
>>>> Regards, Jaikumar
Re: TPTP Test Results with "no verdict" while Total test performed reported [message #89549 is a reply to message #89462] |
Wed, 06 December 2006 14:28   |
Would it be possible to email me the .execution file and .testsuite
file to me directly.
Also are you running the testsuite within an eclipse environment or
via an ant script.
email: sleeloy@ca.ibm.com
Sheldon.
On Wed, 6 Dec 2006 09:40:47 +0530, "Sharma, Jaikumar"
>Hi Sheldon,
>Thanks for respone!
><?xml version="1.0" encoding="UTF-8"?>
>xmlns:xmi="http://www.omg.org/XMI"
> <executionHistory>
>text="System.out:
log4j.properties
> </executionHistory>
>Regards,
>Jaikumar
>> Hi Jaikumar,
>> Thanks,
>> Sheldon.
>>>Hi Liz,
>>>times
>>>attached)
>>>Regards,
>>>Jaikumar
>>>> with
>>>> would
>>>> Sincerely,
>>>> Liz Dancy
>>>>> Hi,
>>>>> error.
>>>>> which
>>>>> fail / error)
>>>>> TPTP-SDK-4.2.1
>>>>> GEF-ALL-3.2
>>>>> Thanks!
>>>>> Regards, Jaikumar
Re: TPTP Test Results with "no verdict" while Total test performed reported [message #89862 is a reply to message #89549] |
Sun, 10 December 2006 22:24  |
Hi Sheldon,
Were you able to pinpoint the problem. I had sent you both (.execution and
..testsuite) files, you had asked for.
Regards, Jaikumar
news:kc6en2dd97evqjvublsng9eodlcnq262ob@4ax.com...
> via an ant script.
> Sheldon.
>>Hi Sheldon,
>>Thanks for respone!
>> <executionHistory>
>>text="System.out:
log4j.properties
>> </executionHistory>
>>Regards,
>>Jaikumar
>>> Hi Jaikumar,
>>> Thanks,
>>> Sheldon.
>>>>Hi Liz,
>>>>times
>>>>attached)
>>>>Regards,
>>>>Jaikumar
>>>>> with
>>>>> would
>>>>> Sincerely,
>>>>> Liz Dancy
>>>>>> Hi,
>>>>>> are
>>>>>> error.
>>>>>> which
>>>>>> (pass
>>>>>> fail / error)
>>>>>> TPTP-SDK-4.2.1
>>>>>> GEF-ALL-3.2
>>>>>> Thanks!
>>>>>> Regards, Jaikumar
Current Time: Sun Jul 27 08:53:14 EDT 2025
Powered by FUDForum. Page generated in 0.23875 seconds
