Home » Modeling » EMF » ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null(What are the subtle differences?)
ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886305] Thu, 14 June 2012 13:22 Go to next message
Hi there,
ResourceSetImpl.createResource(URI) hands a contentType=null down the resource creation. In ResourceFactoryRegistryImpl.getFactory(uri,protoMap,extMap,contentMap,contentTypeIdentifier,delegate) this is compared to UNSPECIFIED_CONTENT_TYPE to decide whether the type is to be computed.
In my case I have an ecore model that I ammended with an alternative ResourceFactory with an second content-type.
I give an URI with an extension that is registered against the alternative content-type as output parameter to a QVTo transformation. When debugging that run I see that both of my content types are well listed in the contentTypeIdentifierToFactoryMap but as the null does not cause the content-type for my URI to be computed the correct ResourceFactory is not looked up but I run into the fallback Resource.Factory.Registry.DEFAULT_EXTENSION with returns the deault XMI Resource Factory.
What should I change so that my URI is mapped to the correct ResourceFactory?
Or is it a bug? And if so: of EMF or of QVTo?
Thanks in advance,
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886347 is a reply to message #886305] Thu, 14 June 2012 15:07 Go to previous messageGo to next message
content-types were a late addition and needed to be compatible and so
the priorities are not always perfect.
You should avoid Resource.Factory.Registry.DEFAULT_EXTENSION if using
content-types. You may need to programmatically remove it if you cannot
avoid its addition.
Ed Willink
On 14/06/2012 18:22, Uwe Ritzmann wrote:
> Hi there,
> ResourceFactory?
> Thanks in advance,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886516 is a reply to message #886305] Fri, 15 June 2012 00:57 Go to previous messageGo to next message
Uwe,
Comments below.
On 14/06/2012 7:22 PM, Uwe Ritzmann wrote:
> Hi there,
> ResourceFactory?
Who is calling createResource? Note that there are two createResource
methods so if you need to specific a content type, you should call the
one that lets you specify a content type. Keep in mind that for
existing resource one would generally expect you'd use
ResourceSet.getResource(uri, true) to load it and that will end up
calling ResourceSetImpl.demandCreate which calls createResource(uri,
ContentHandler.UNSPECIFIED_CONTENT_TYPE). For the case that you're
creating a new resource, it's obviously not possible to determine the
content type from the non-existent content so it would generally be
pointless to try to determine a content type when creating a new resource.
> Thanks in advance,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886692 is a reply to message #886516] Fri, 15 June 2012 09:07 Go to previous messageGo to next message
Hi, Ed,
I have a project in which I am working with XMI files having varying
content types requiring different Resource implementations, but which
all bear the *.xmi file extension (because they're XMI files :-) ).
I have found that, even though I register ContentHandlers for the
content-types I need to deal with, I end up with plain XMIResourceImpls
because someone in my JVM registered the "xmi" file extension in the
shared resource-factory registry. The registry prefers registrations
by extension over registrations by content-type.
Currently, I am working around this by creating resources myself,
describing the content of a file and looking up the factory by
content-type in the registry before falling back to file-extension
registrations.
Is there a recommended better way? Can I configure something in the
resource-factory registry to prefer content-types over extensions?
Should I look into getting the "xmi" extension removed from the shared
registry in my VM? (it's a J2EE container hosting other applications,
so that may be hard)? Or is the way I'm doing it just the way to do it?
Christian
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886696 is a reply to message #886692] Fri, 15 June 2012 09:24 Go to previous messageGo to next message
Hi Christian
To get some of the UML stuff working before UMLREsourceUtil.init() was
sorted out, I removed the global "xmi" entry programmatically and added
the corresponding backstop content type for "xmi" in its place so that
the resolution priorities were more sensible.
Ed Willink
On 15/06/2012 14:07, Christian W. Damus wrote:
> Hi, Ed,
> XMIResourceImpls because someone in my JVM registered the "xmi" file
> extension in the shared resource-factory registry. The registry
> prefers registrations by extension over registrations by content-type.
> registrations.
> Christian
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #886824 is a reply to message #886516] Fri, 15 June 2012 13:43 Go to previous messageGo to next message
Ed, thank you very much for your answer.
> > ResourceFactory?
The QVT Launch Configuration is.
ResourceSetImpl.createResource(URI) line: 423
EmfUtil.createResource(URI, ResourceSet) line: 397
QvtLaunchConfigurationDelegateBase.saveTransformationResult(ModelExtentContents, TargetUriData, ResourceSet) line: 239
QvtLaunchConfigurationDelegateBase.doLaunch(QvtTransformation, List<ModelContent>, List<TargetUriData>, String, IContext) line: 203
QvtLaunchConfigurationDelegateBase.doLaunch(QvtTransformation, ILaunchConfiguration, IContext) line: 140
QvtLaunchConfigurationDelegate$1.run() line: 65
SafeRunner$SameThreadRunner.run(BaseProcess$IRunnable) line: 33
SafeRunner$1.run() line: 26
QvtLaunchConfigurationDelegate$2(ShallowProcess).run(IDebugTarget) line: 41
QvtLaunchConfigurationDelegate$2(ShallowProcess).run() line: 32
QvtLaunchConfigurationDelegate$3.run() line: 98
Thread.run() line: not available
> For the case that you're creating a new resource, it's obviously not possible
> to determine the content type from the non-existent content so it would generally
> be pointless to try to determine a content type when creating a new resource.
Obviously. The subtle point between createResource(uri,null)
and createResource(uri,UNSPECIFIED_CONTENT_TYPE) in this
pointless situation is then what?
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887088 is a reply to message #886824] Fri, 15 June 2012 23:19 Go to previous messageGo to next message
Uwe,
Comments below.
>> > What should I change so that my URI is mapped to the correct >
>> ResourceFactory?
> Quote:
>> line: 41
>> possible
>> would generally
>> resource.
So best you specify the content type when you create a new resource and
you know the purpose of that new resource is to store your known content
type.
> Regards,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887091 is a reply to message #886692] Fri, 15 June 2012 23:22 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Christian,<br>
<br>
If you do this<br>
<blockquote>resourceSet.getResourceFactoryRegistry().getContentTypeToFactoryMap().putAll<br>
&nbsp;
(Resource.Factory.Registry.INSTANCE.getContentTypeToFactoryMap())<br>
</blockquote>
Then in your resource set, all content type registrations will take
precedence over all other (global) registrations.<br>
<br>
<br>
On 15/06/2012 3:07 PM, Christian W. Damus wrote:
<blockquote cite="mid:jrfc2o$j88$1@xxxxxxxxe.org" type="cite">Hi,
Ed,
<br>
<br>
varying content types requiring different Resource
implementations, but which all bear the *.xmi file extension
<br>
<br>
file extension in the shared resource-factory registry.&nbsp; The
registry prefers registrations by extension over registrations by
content-type.
<br>
<br>
registrations.
<br>
<br>
Is there a recommended better way?&nbsp; Can I configure something in
the resource-factory registry to prefer content-types over
extensions?&nbsp; Should I look into getting the "xmi" extension
removed from the shared registry in my VM? (it's a J2EE container
hosting other applications, so that may be hard)?&nbsp; Or is the way
<br>
<br>
<br>
<br>
Christian
<br>
<br>
</blockquote>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887259 is a reply to message #887088] Sat, 16 June 2012 05:39 Go to previous messageGo to next message
Ed, thanks again for the reply.
> type.
I will certainly do that whenever I access ResourceSetImpl.createResource(.) programmatically.
But currently, while having developed my own metamodel, I am only a mere user of the QVTo engine and an URI is the only thing I can give for the output model.
And that does not work as expected (outlined in my original post).
Is this a fault of QVTo? Should they offer a content-type combo in the ui?
The interesting source is in
QvtLaunchConfigurationDelegateBase.saveTransformationResult(,,)
        	case NEW_MODEL: {
        		try {
            		URI modelUri = outUri.trimFragment();
           	    	Resource outExtent = resSet.getResource(modelUri, false);
           	    	if(outExtent == null) {
           	    		outExtent = EmfUtil.createResource(modelUri, resSet);
Should QVTo better use loadOnDemand=true for getResource?
Or should QVTo drop the EmfUtil.createResource implementation and rather compute the content-type beforehand and use ResourceSet.getResource(uri,type)?
On the other hand you still did not answer what the semantic difference of contentType=null vs contentType=UNSPECIFIED_CONTENT_TYPE is. So I can't help feeling that the real issue is an imprecision or inconsistency in the EMF API that should better be fixed instead of worked around by other parties (e.g. QVTo).
What would be the problem if ResourceSetImpl.createResource(uri) would be changed to call createResource(uri, UNSPECIFIED_CONTENT_TYPE)?
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887279 is a reply to message #887259] Sat, 16 June 2012 06:21 Go to previous messageGo to next message
Uwe,
Comments below.
>> type.
> ui?
> case NEW_MODEL: {
> try {
> resSet);
Not sure what this does...
Well, this is an output resource to it's likely that it doesn't already
exist and even if it does, that you'll just overwrite it regardless of
the current content.
It seems to be fully general, it ought to provide a way to specify the
content type of the output resource.
> is.
One says there is no content type; the other says I've not specified it
but there likely is one so try to determine it from the content.
Imagine the output resource doesn't exist, which is likely the common
case. In this case, there is no way to determine the content type from
the content. So it must be specified along with the URI.
It wouldn't solve your problem because you're creating new outputs, in
general.
> Regards,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887340 is a reply to message #886305] Sat, 16 June 2012 08:33 Go to previous messageGo to next message
Hi Uwe
Abstracting away from the details for a moment the problem seems to be:
Given a URI and a forest of EObjects, create a suitable Resource for
those EObjects and assign them to Resource.contents.
If you're writing the code you may know the content-type and so you can
do it right.
A modeling tool such as QVTo, ATL, Epsilon and probably even Xtend may
not have a content-type concept to enable you to get it right.
So, today, such tools could examine all the EPackages and use Java
reflection to get the eCONTENT_TYPE and endeavour to find a content-type
that is compatible with all the EPackages; quite easy when there's only
one or it's homogeneous.
If this is the required solution, EMF could provide an eContentType()
API to avoid reflection and/or a createResource(URI, List<EObject>) method.
Ed Willink
> Hi there,
> ResourceFactory?
> Thanks in advance,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887509 is a reply to message #887279] Sat, 16 June 2012 15:03 Go to previous messageGo to next message
Hi Ed,
> general.
Well, yes and no.
I used the debugger to sneak UNSPECIFIED_CONTENT_TYPE into createResource(uri,type).
In the first run, when the resource is not existing, an exception is thrown
File(Resource).checkExists(int, boolean) line: 341
File(Resource).checkAccessible(int) line: 215
File.getContentDescription() line: 263
PlatformResourceURIHandlerImpl$WorkbenchHelper.getContentDescription(String, Map<?,?>) line: 399
PlatformContentHandlerImpl.contentDescription(URI, InputStream, Map<?,?>, Map<Object,Object>) line: 82
PlatformResourceURIHandlerImpl(URIHandlerImpl).contentDescription(URI, Map<?,?>) line: 261
ExtensibleURIConverterImpl.contentDescription(URI, Map<?,?>) line: 366
ResourceSetImpl$2(ResourceFactoryRegistryImpl).getContentTypeIdentifier(URI) line: 158
ResourceSetImpl$2(ResourceFactoryRegistryImpl).getFactory(URI, Map<String,Object>, Map<String,Object>, Map<String,Object>, String, boolean) line: 124
ResourceSetImpl$2.delegatedGetFactory(URI, String) line: 459
ResourceSetImpl$2(ResourceFactoryRegistryImpl).getFactory(URI, Map<String,Object>, Map<String,Object>, Map<String,Object>, String, boolean) line: 145
ResourceSetImpl$2(ResourceFactoryRegistryImpl).getFactory(URI, String) line: 86
ResourceSetImpl.createResource(URI, String) line: 431
and no content type computed, my ResourceFactory not found, the default XMIFactory used and the XMI version of the output model written.
In the second run no exception is thrown and File.getContentDescription() uses
ContentTypeManager to derive my content-type from the URI extension, hence my Factory is found and the text version of the output model is written happily overwriting the XMI version.
ContentTypeCatalog.getDirectlyAssociated(String, int) line: 527
ContentTypeCatalog.internalFindContentTypesFor(ContentTypeMatcher, String, Comparator) line: 477
ContentTypeCatalog.findContentTypesFor(ContentTypeMatcher, String) line: 307
ContentTypeManager(ContentTypeMatcher).findContentTypeFor(String) line: 48
ContentDescriptionManager.getDescriptionFor(File, ResourceInfo, boolean) line: 334
File.getContentDescription() line: 271
This second behaviour is what I would generally expect. I do not see the point why filename-from-URI based and file-extension-from-URI based content-type lookup is shortcut by the existence/non-existence of the file.
So, while certainly a strange solution and leaving the feeling that content type handling has room for improvements, nevertheless it would be a solution for my, admittedly very specific, problem.
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887870 is a reply to message #887509] Sun, 17 June 2012 05:17 Go to previous messageGo to next message
Uwe,
Comments below.
On 16/06/2012 9:03 PM, Uwe Ritzmann wrote:
> Hi Ed,
>> would > be changed to call createResource(uri,
>> general.
> Well, yes and no.
> thrown
> Map<?,?>) line: 399
> Map<?,?>) line: 261
> line: 158
> boolean) line: 124
> boolean) line: 145
> line: 86
> line: 41
Yes, if there is nothing there, a content type can't be computed.
Not from the content, which is XMI?
> line: 307
> line: 48
> boolean) line: 334
> Map<?,?>) line: 399
> Map<?,?>) line: 261
> line: 158
> boolean) line: 124
> boolean) line: 145
> line: 86
> line: 41
Deriving a content type purely from the extension?
Content type is about looking at what's in the underlying storage to
determine the content. If the extension is sufficient, register your
resource factory with that extension.
> Regards
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887871 is a reply to message #887340] Sun, 17 June 2012 05:19 Go to previous messageGo to next message
Ed,
Comments below.
On 16/06/2012 2:33 PM, Ed Willink wrote:
> Hi Uwe
> can do it right.
Should they have such a thing? The platform hasn't always had that
concept nor EMF, but we added them...
> content-type that is compatible with all the EPackages; quite easy
> when there's only one or it's homogeneous.
Or should it consider just the root object?
> method.
We could add such a utility method to EcoreUtil; it could use reflection
as you suggest...
> Regards
> Ed Willink
>> Hi there,
>> ResourceFactory?
>> Thanks in advance,
>> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887908 is a reply to message #887871] Sun, 17 June 2012 06:38 Go to previous messageGo to next message
Comments below
On 17/06/2012 10:19, Ed Merks wrote:
> Ed,
> Comments below.
>> may not have a content-type concept to enable you to get it right.
Arguably they do. It's the meta-model. The outer Resource mapping is an
implementation detail. We just need to provide the algorithm to deduce
the Resource content type from the meta-model.
For 99% of uses the output forest is a tree so there is a single root,
but with language extension it is quite feasible that the root is a UML
Model, one of whose Packages is a QVT transformation for which some
ValueSpecification is an OCL expression. Examining the UML Model root
might be simplistic. But the subtleties are of two forms. XMI details
and meta-model evolution. XMI requires the right resource serialization.
Meta-model evolution just needs a version converter that can perhaps be
sorted out later.
So perhaps it sufficient for createResource(URI, List<EObject>) to
select the best content-type that is compatible with each root EObject,
where best is the first (in content handler registration order) content
type with a namespace pattern, else the default content type for the
extension, else normal extension-based selection.
>> method.
> reflection as you suggest...
That would be good.
Ed Willink
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887913 is a reply to message #887908] Sun, 17 June 2012 06:47 Go to previous messageGo to next message
Hi Ed
A createResource(URI, EPackage) method avoids the tree/forest
complexities and the inefficient challenge of finding the most demanding
EPackage used by a forest.
Ed Willink
On 17/06/2012 11:38, Ed Willink wrote:
> Hi
> Comments below
>> Ed,
>> Comments below.
> an implementation detail. We just need to provide the algorithm to
> deduce the Resource content type from the meta-model.
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887946 is a reply to message #887908] Sun, 17 June 2012 07:57 Go to previous messageGo to next message
Ed,
Comments below.
On 17/06/2012 12:38 PM, Ed Willink wrote:
> Hi
> Comments below
>> Ed,
>> Comments below.
> UML Model, one of whose Packages is a QVT transformation for which
> some ValueSpecification is an OCL expression. Examining the UML Model
> root might be simplistic. But the subtleties are of two forms. XMI
> details and meta-model evolution. XMI requires the right resource
> serialization. Meta-model evolution just needs a version converter
> that can perhaps be sorted out later.
> EObject, where best is the first (in content handler registration
> order) content type with a namespace pattern, else the default content
> type for the extension, else normal extension-based selection.
How one decides the content type of a list of objects isn't clear and,
in any case, I'd rather provide something that doesn't introduce new
methods on interfaces....
>>> eContentType() API to avoid reflection and/or a createResource(URI,
> That would be good.
> Regards
> Ed Willink
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887947 is a reply to message #887913] Sun, 17 June 2012 07:59 Go to previous messageGo to next message
Ed,
Using something like resourceSet.createResource(uri,
EcoreUtil.getContentType(ePackage)) seems equivalent. I wonder if the
getContentType method returning UNSPECIFIED_CONTENT_TYPE would be best...
On 17/06/2012 12:47 PM, Ed Willink wrote:
> Hi Ed
> demanding EPackage used by a forest.
> Regards
> Ed Willink
>> Hi
>> Comments below
>>> Ed,
>>> Comments below.
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #887994 is a reply to message #887947] Sun, 17 June 2012 09:43 Go to previous messageGo to next message
Hi Ed
That works for me.
There are a variety of modeling tools (Acceleo, Xtext and to a lesser
extent OCL) that now try to support the current tool on an old EMF,
platform, so additional static methods cannot easily be used.
Since this code could easily work on Helios, is it worth putting it in
EcoreUtilHelios.java so that it can be used on old platforms? Perhaps
EcoreUtil extends EcoreUtilJuno extends EcoreUtilIndigo extends
EcoreUtilHelios with the new code in an emf.compatibility plugin? Not
worth it for just this routine, but perhaps the packaging supports the
more general future usage of a stable EMF.
Ed Willink
On 17/06/2012 12:59, Ed Merks wrote:
> Ed,
>> Hi Ed
>> Regards
>> Ed Willink
>>> Hi
>>> Comments below
>>>> Ed,
>>>> Comments below.
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888045 is a reply to message #887870] Sun, 17 June 2012 11:43 Go to previous messageGo to next message
Ed,
> > thrown
Not from actual content, but nevertheless the current implementation of the platforms ContentTypeManager not only uses content, but the URI as well.
Certainly not, as the XMI is registered against another content-type as the text version with is in this case successfully derived from the URI extension.
I did not say that, but even files who are thought of as having a content-type must be created at first. And that's what I am talking about all the time. And at that point of time the user must be able to give a desired content-type.
One could have thought of a query segment in the URI like "?contenttype=my.meta.model.text-content-type", but in contrast it at least seems to me that someone thought it would make sense to allow extensions to be associated with content-types (see Preferences > General > Content Types).
I just showed you the stack trace that that is not the full truth or other implementors share not your philosophy on content-type computation.
> If the extension is sufficient, register your resource factory with that extension.
Actually, I did that. I did it via the preferences, not via the plugin xml as extension-parser.
And I'd prefer the first solution because this registration can be done by the user.
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888050 is a reply to message #887908] Sun, 17 June 2012 11:53 Go to previous messageGo to next message
Hi Ed,
Edward Willink wrote on Sun, 17 June 2012 06:38
I disagree. The meta-model does not have a content type. It is the ResourceFactory which maps between content-type and metamodel.
Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888057 is a reply to message #888045] Sun, 17 June 2012 12:04 Go to previous messageGo to next message
Uwe,
Comments below.
On 17/06/2012 5:43 PM, Uwe Ritzmann wrote:
> Ed,
>> is > thrown
>> > and no content type computed, my ResourceFactory not found, the >
> as well.
What does it do if there are multiple content types registered for the
same extension? That's pretty much the only interesting case...
>> > In the second run no exception is thrown and >
>> extension, > hence my Factory is found and the text version of the
>> output model is > written happily overwriting the XMI version.
> URI extension.
>> > I do not see the point why filename-from-URI based and >
>> that extension.
Even in the preferences you'll see programmed entries that are locked.
> done by the user.
> Regards
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888060 is a reply to message #887994] Sun, 17 June 2012 12:07 Go to previous messageGo to next message
Ed,
Comments below.
On 17/06/2012 3:43 PM, Ed Willink wrote:
> Hi Ed
> That works for me.
The latest version of EMF is compatible with Eclipse 3.5, i.e., the
lower bound is 3.5.
I'm not sure what you're suggesting...
> Perhaps EcoreUtil extends EcoreUtilJuno extends EcoreUtilIndigo
> extends EcoreUtilHelios with the new code in an emf.compatibility
> plugin? Not worth it for just this routine, but perhaps the packaging
> supports the more general future usage of a stable EMF.
I'm not sure why this is needed or how it would be used...
> Regards
> Ed Willink
>> Ed,
>> the getContentType method returning UNSPECIFIED_CONTENT_TYPE would be
>> best...
>>> Hi Ed
>>> Regards
>>> Ed Willink
>>>> Hi
>>>> Comments below
>>>>> Ed,
>>>>> Comments below.
>>>>>> Xtend may not have a content-type concept to enable you to get it
>>>>>> right.
>>>>> that concept nor EMF, but we added them...
>>>> is an implementation detail. We just need to provide the algorithm
>>>> to deduce the Resource content type from the meta-model.
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888083 is a reply to message #888050] Sun, 17 June 2012 12:59 Go to previous messageGo to next message
Of course a meta-model (as specified by some standards authority) does
not have an Eclipse content-type.
Until recently UML Packages didn't even have a namespace URI.
content-types are an Eclipse-ism to enable the Eclipse platform to
handle overloaded file extensions. This was extended by EMF to XML
namespaces.
If this problem was being tackled today for e4 that uses EMF, nsURIs
might well have been used as the content-type. But they aren't.
So we have a number of largely 1:1 relationships between
meta-model intellectual content
meta-model nsURI
content-type
So arguably, as I wrote, on an Eclipse platform a meta-model has an
associated content-type that you may find as the eCONTENT_TYPE field.
Ed Willink
On 17/06/2012 16:53, Uwe Ritzmann wrote:
> Hi Ed,
> Regards,
> Uwe
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888088 is a reply to message #888060] Sun, 17 June 2012 13:10 Go to previous messageGo to next message
Hi Ed
If applications that are shipped to run on EMF >= 2.5 use the proposed
EcoreUtil.getContentType, they suddenly acquire an EMF 2.9 lower bound.
So applications can only use the new EMF routine by cloning the new
utility routine into their own code base.
My suggestion, first of an EcoreUtilHelios class, allows the
applications to get the functionality from EMF without cloning.
My further suggestion of packaging it in an emf.compatibility plugin
with a 2.5 lower bound would allow applications to bundle the Kepler
emf.compatibility plugin for use in polymorphic
Helios/Indigo/Juno/Kepler distributions.
Ed Willink
On 17/06/2012 17:07, Ed Merks wrote:
> Ed,
> Comments below.
>> Hi Ed
>> That works for me.
> lower bound is 3.5.
>> in EcoreUtilHelios.java so that it can be used on old platforms?
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888167 is a reply to message #888088] Sun, 17 June 2012 15:51 Go to previous messageGo to next message
Ed,
Comments below.
On 17/06/2012 7:10 PM, Ed Willink wrote:
> Hi Ed
It's 2.8 actually. From that type of reasoning, one can never add new
things. If EMF 2.8 installs and works well in Eclipse 3.5, then
there's no (direct) problem using it in a Helios context.
So no routine can ever be added, or at least can ever be used.
Why is that better than ensuring that all parts of EMF can run in 3.5?
Is there any precedent in the platform for this type of pattern?
> Regards
> Ed Willink
>> Ed,
>> Comments below.
>>> Hi Ed
>>> That works for me.
>>> lesser extent OCL) that now try to support the current tool on an
>>> old EMF, platform, so additional static methods cannot easily be used.
>> lower bound is 3.5.
>>> packaging supports the more general future usage of a stable EMF.
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888251 is a reply to message #887340] Sun, 17 June 2012 19:00 Go to previous messageGo to next message
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta http-equiv="Content-Style-Type" content="text/css">
<title></title>
<meta name="Generator" content="Cocoa HTML Writer">
<meta name="CocoaVersion" content="1138.47">
<style type="text/css">
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica; min-height: 14.0px}
p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #002391}
p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco; color: #008d12}
p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Monaco}
p.p6 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #002390}
p.p7 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #002390; min-height: 14.0px}
p.p8 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12}
p.p9 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12; min-height: 14.0px}
p.p10 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #000000; min-height: 14.0px}
span.s1 {color: #000000}
span.s2 {color: #002391}
span.s3 {color: #008d12}
</style>
</head>
<body>
<p class="p1">Interesting this has come up as I faced a similar situation about 18 months ago (I think asked about it in the newsgroup) as I'm using QVTo heavily within our RCP app and I wanted an automated way of ensuring only valid ResourceImpl could be used with the outputs as our UI is built automatically from the QVTo AST.<span class="Apple-converted-space">  </span>This is primarily because some of our transforms are to very specific models that are reverse engineered from existing legacy data formats so our users don't care or need to know that they can save the output to an XMI file when they want it in the legacy column-delimited format.</p>
<p class="p2"><br></p>
<p class="p1">My solution is an extension point where an EPackage URI has one or more ResourceFactory's associated with it (and for those that are universal e.g. XMI it simply has the URI as *).<span class="Apple-converted-space">  </span>I also added some additional meta-data around about them to give more human-readable names, the file extensions etc. Within the UI now it can look out the output parameter from QVTo (or from CDO when exporting from the repository) programatically then from this EPackage find the ResourceFactorys that go with that EPackage. The extension also includes an "isDefault" and "priority" attributes so I can set the EPackage-specific ResourceFactorys as default and also change the priority of the agnostic ones to determine what is used by default.</p>
<p class="p1">A lot of this was aimed at providing an extensible way of building the UI hence the inclusion of human-readable names.<span class="Apple-converted-space">  </span>Works quite nicely for our needs!</p>
<p class="p1">A couple of examples are below.</p>
<p class="p1">Alan</p>
<p class="p3">&lt;extension</p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">         </span></span><span class="s2">point=</span>"com.cimphony.core.emf.schema_resource"<span class="s2">&gt;</span></p>
<p class="p3"><span class="s1"><span class="Apple-converted-space">      </span></span>&lt;schema</p>
<p class="p5"><span class="Apple-converted-space">            </span><span class="s2">uri=</span><span class="s3">"*"</span><span class="s2">&gt;</span></p>
<p class="p5"><span class="Apple-converted-space">         </span><span class="s2">&lt;parser</span></p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">               </span></span><span class="s2">class=</span>"org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">               </span><span class="s2">priority=</span><span class="s3">"5"</span></p>
<p class="p5"><span class="Apple-converted-space">               </span><span class="s2">type=</span><span class="s3">"xmi"</span></p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">               </span></span><span class="s2">name=</span>"OMG XMI 2.0 Format"<span class="s2">&gt;</span></p>
<p class="p5"><span class="Apple-converted-space">         </span><span class="s2">&lt;/parser&gt;</span></p>
<p class="p3"><span class="s1"><span class="Apple-converted-space">      </span></span>&lt;/schema&gt;</p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">            </span></span><span class="s2">uri=</span>"http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"<span class="s2">&gt;</span></p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">               </span></span><span class="s2">class=</span>"com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">               </span><span class="s2">isDefault=</span><span class="s3">"true"</span></p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">               </span></span><span class="s2">name=</span>"GridLAB-D Powerflow Format"</p>
<p class="p5"><span class="Apple-converted-space">               </span><span class="s2">type=</span><span class="s3">"glm"</span><span class="s2">/&gt;</span></p>
<p class="p3"><span class="s1"><span class="Apple-converted-space">   </span></span>&lt;/extension&gt;</p>
<p class="p1">On 2012-06-16 12:33:38 +0000, Ed Willink said:</p>
<p class="p6">Hi Uwe</p>
<p class="p7"><br></p>
<p class="p6">Abstracting away from the details for a moment the problem seems to be:</p>
<p class="p6">Given a URI and a forest of EObjects, create a suitable Resource for those EObjects and assign them to Resource.contents.</p>
<p class="p6">If you're writing the code you may know the content-type and so you can do it right.</p>
<p class="p6">A modeling tool such as QVTo, ATL, Epsilon and probably even Xtend may not have a content-type concept to enable you to get it right.</p>
<p class="p6">So, today, such tools could examine all the EPackages and use Java reflection to get the eCONTENT_TYPE and endeavour to find a content-type that is compatible with all the EPackages; quite easy when there's only one or it's homogeneous.</p>
<p class="p6">If this is the required solution, EMF could provide an eContentType() API to avoid reflection and/or a createResource(URI, List&lt;EObject&gt;) method.</p>
<p class="p6"><span class="Apple-converted-space">     </span>Regards</p>
<p class="p6"><span class="Apple-converted-space">         </span>Ed Willink</p>
<p class="p6">On 14/06/2012 18:22, Uwe Ritzmann wrote:</p>
<p class="p8">Hi there,</p>
<p class="p9"><br></p>
<p class="p8">ResourceSetImpl.createResource(URI) hands a contentType=null down the resource creation. In ResourceFactoryRegistryImpl.getFactory(uri,protoMap,extMap,contentMap,contentTypeIdentifier,delegate) this is compared to UNSPECIFIED_CONTENT_TYPE to decide whether the type is to be computed.</p>
<p class="p8">In my case I have an ecore model that I ammended with an alternative ResourceFactory with an second content-type.</p>
<p class="p8">I give an URI with an extension that is registered against the alternative content-type as output parameter to a QVTo transformation. When debugging that run I see that both of my content types are well listed in the contentTypeIdentifierToFactoryMap but as the null does not cause the content-type for my URI to be computed the correct ResourceFactory is not looked up but I run into the fallback Resource.Factory.Registry.DEFAULT_EXTENSION with returns the deault XMI Resource Factory.</p>
<p class="p8">What should I change so that my URI is mapped to the correct ResourceFactory?</p>
<p class="p8">Or is it a bug? And if so: of EMF or of QVTo?</p>
<p class="p8">Thanks in advance,</p>
<p class="p8">Uwe</p>
<p class="p10"><br></p>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888465 is a reply to message #888167] Mon, 18 June 2012 02:49 Go to previous messageGo to next message
Below
On 17/06/2012 20:51, Ed Merks wrote:
> Ed,
> Comments below.
>> Hi Ed
>> proposed EcoreUtil.getContentType, they suddenly acquire an EMF 2.9
>> lower bound.
2.8 is Juno; nothing new is now going to go into Juno. So an
EcoreUtil.getContentType would be in Kepler which is probably EMF 2.9.
Yes. It's a real pain. The ability to create branded Eclipse solutions
is one of Eclipse's successes, but it means that users of those
solutions must wait until the branded solution updates and until their
corporate authority approves the upgrade for production use. It is
really depressing how many Galileo questions appear on the newsgroups.
Such users may not be allowed to upgrade any of the plugins that form
part of the branded solution, but they may be able to add new plugins.
So it is desirable to support new plugins on old platforms. As from
Juno, EMF is partially part of the platform, so upgrading EMF to support
modeling applications may become difficult for some users. It would be
nice to try to help.
> 3.5? Is there any precedent in the platform for this type of pattern?
Don't know. It would be nice to hear from anyone from Acceleo or Xtext
here to understand their pains and workarounds for polymorphic
distributions.
Ed Willink
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888468 is a reply to message #888251] Mon, 18 June 2012 02:54 Go to previous messageGo to next message
<html>
<head>
</head>
Hi Alan<br>
<br>
I'm not clear that your solution achieves anything that could not be
achieved by the standard content type declarations. Your extension
point may be easier to read but it creates a confusion between
alternate declaration mechanisms.<br>
<br>
&nbsp;&nbsp;&nbsp; Regards<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink<br>
<br>
On 18/06/2012 00:00, Alan McMorran wrote:
<blockquote cite="mid:jrlnit$g49$1@xxxxxxxxe.org" type="cite">
charset=ISO-8859-1">
<title></title>
</style>
from the QVTo AST.<span class="Apple-converted-space">&nbsp; </span>This
<p class="p2"><br>
</p>
*).<span class="Apple-converted-space">&nbsp; </span>I also added
<p class="p2"><br>
</p>
names.<span class="Apple-converted-space">&nbsp; </span>Works quite
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p4"><span class="s1"><span class="Apple-converted-space">&nbsp;&nbsp;
&nbsp; &nbsp; &nbsp; </span></span><span class="s2">point=</span>"com.cimphony.core.emf.schema_resource"<span
<p class="p3"><span class="s1"><span class="Apple-converted-space">&nbsp;
&nbsp; &nbsp; </span></span>&lt;schema</p>
<p class="p5"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span><span
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span><span
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span></span><span class="s2">class=</span>"org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span><span
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span></span><span class="s2">name=</span>"OMG
&nbsp; &nbsp; </span></span>&lt;/schema&gt;</p>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span></span><span class="s2">uri=</span><a class="moz-txt-link-rfc2396E" href="http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution">"http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"</a><span
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span></span><span class="s2">class=</span>"com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span></span><span class="s2">name=</span>"GridLAB-D
<p class="p3"><span class="s1"><span class="Apple-converted-space">&nbsp;&nbsp;
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p6"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; </span>Regards</p>
<p class="p7"><br>
</p>
<p class="p6"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>Ed
Willink</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p7"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p9"><br>
</p>
<p class="p10"><br>
</p>
</blockquote>
<br>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888714 is a reply to message #888468] Mon, 18 June 2012 10:25 Go to previous messageGo to next message
<html>
<head>
<title></title>
p.p3 {margin: 0.0px 0.0px 0.0px 12.0px; font: 16.0px Helvetica; color: #002390}
p.p4 {margin: 0.0px 0.0px 0.0px 12.0px; font: 16.0px Helvetica; color: #002390; min-height: 19.0px}
p.p5 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390}
p.p6 {margin: 0.0px 0.0px 0.0px 12.0px; font: 12.0px Helvetica; color: #002390; min-height: 14.0px}
p.p7 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12}
p.p8 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12; min-height: 14.0px}
p.p9 {margin: 0.0px 0.0px 0.0px 36.0px; font: 12.0px Helvetica; color: #930f04}
p.p10 {margin: 0.0px 0.0px 0.0px 36.0px; font: 12.0px Helvetica; color: #930f04; min-height: 14.0px}
p.p11 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; min-height: 14.0px}
span.s1 {text-decoration: underline}
span.Apple-tab-span {white-space:pre}
</style>
</head>
<body>
<p class="p1">Ed,</p>
<p class="p1">I couldn't see any existing extension points that let you set a ResourceFactory for an EPackage <span class="Apple-converted-space">  </span>My situation is that I know I have a bunch of EObjects from a particular EPackage but I wasn't aware of an existing extension point that let me select the ResourceFactory.<span class="Apple-converted-space">  </span>I asked about this about 18 months ago:</p>
<p class="p1"><span class="Apple-tab-span"> </span>http://www.eclipse.org/forums/index.php/mv/tree/173386/</p>
<p class="p1">What existing content type declarations let you find valid ResourceFactorys for a particular EPackage?<span class="Apple-converted-space">  </span>I use them heavily for the other way around (when I have an existing resource and want to find the ResourceFactory to parse it), but I couldn't see how to use them to create new, blank Resources that could then be populated with EObjects.</p>
<p class="p1">Apologies if I've misunderstood this thread and gone off on a tangent</p>
<p class="p1">On 2012-06-18 06:54:39 +0000, Ed Willink said:</p>
<p class="p3">Hi Alan</p>
<p class="p4"><br></p>
<p class="p3">I'm not clear that your solution achieves anything that could not be achieved by the standard content type declarations. Your extension point may be easier to read but it creates a confusion between alternate declaration mechanisms.</p>
<p class="p3">    Regards</p>
<p class="p3">        Ed Willink</p>
<p class="p3">On 18/06/2012 00:00, Alan McMorran wrote:</p>
<p class="p5">Interesting this has come up as I faced a similar situation about 18 months ago (I think asked about it in the newsgroup) as I'm using QVTo heavily within our RCP app and I wanted an automated way of ensuring only valid ResourceImpl could be used with the outputs as our UI is built automatically from the QVTo AST.<span class="Apple-converted-space">  </span>This is primarily because some of our transforms are to very specific models that are reverse engineered from existing legacy data formats so our users don't care or need to know that they can save the output to an XMI file when they want it in the legacy column-delimited format.</p>
<p class="p6"><br></p>
<p class="p5">My solution is an extension point where an EPackage URI has one or more ResourceFactory's associated with it (and for those that are universal e.g. XMI it simply has the URI as *).<span class="Apple-converted-space">  </span>I also added some additional meta-data around about them to give more human-readable names, the file extensions etc. Within the UI now it can look out the output parameter from QVTo (or from CDO when exporting from the repository) programatically then from this EPackage find the ResourceFactorys that go with that EPackage. The extension also includes an "isDefault" and "priority" attributes so I can set the EPackage-specific ResourceFactorys as default and also change the priority of the agnostic ones to determine what is used by default.</p>
<p class="p5">A lot of this was aimed at providing an extensible way of building the UI hence the inclusion of human-readable names.<span class="Apple-converted-space">  </span>Works quite nicely for our needs!</p>
<p class="p5">A couple of examples are below.</p>
<p class="p5">Alan</p>
<p class="p5">&lt;extension</p>
<p class="p5"><span class="Apple-converted-space">         </span>point="com.cimphony.core.emf.schema_resource"&gt;</p>
<p class="p5"><span class="Apple-converted-space">      </span>&lt;schema</p>
<p class="p5"><span class="Apple-converted-space">            </span>uri="*"&gt;</p>
<p class="p5"><span class="Apple-converted-space">         </span>&lt;parser</p>
<p class="p5"><span class="Apple-converted-space">               </span>class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">               </span>priority="5"</p>
<p class="p5"><span class="Apple-converted-space">               </span>type="xmi"</p>
<p class="p5"><span class="Apple-converted-space">               </span>name="OMG XMI 2.0 Format"&gt;</p>
<p class="p5"><span class="Apple-converted-space">         </span>&lt;/parser&gt;</p>
<p class="p5"><span class="Apple-converted-space">      </span>&lt;/schema&gt;</p>
<p class="p5"><span class="Apple-converted-space">            </span>uri=<a href="http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"><span class="s1">"http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"</span></a>&gt;</p>
<p class="p5"><span class="Apple-converted-space">               </span>class="com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">               </span>isDefault="true"</p>
<p class="p5"><span class="Apple-converted-space">               </span>name="GridLAB-D Powerflow Format"</p>
<p class="p5"><span class="Apple-converted-space">               </span>type="glm"/&gt;</p>
<p class="p5"><span class="Apple-converted-space">   </span>&lt;/extension&gt;</p>
<p class="p5">On 2012-06-16 12:33:38 +0000, Ed Willink said:</p>
<p class="p7">Hi Uwe</p>
<p class="p8"><br></p>
<p class="p7">Abstracting away from the details for a moment the problem seems to be:</p>
<p class="p7">Given a URI and a forest of EObjects, create a suitable Resource for those EObjects and assign them to Resource.contents.</p>
<p class="p7">If you're writing the code you may know the content-type and so you can do it right.</p>
<p class="p7">A modeling tool such as QVTo, ATL, Epsilon and probably even Xtend may not have a content-type concept to enable you to get it right.</p>
<p class="p7">So, today, such tools could examine all the EPackages and use Java reflection to get the eCONTENT_TYPE and endeavour to find a content-type that is compatible with all the EPackages; quite easy when there's only one or it's homogeneous.</p>
<p class="p7">If this is the required solution, EMF could provide an eContentType() API to avoid reflection and/or a createResource(URI, List&lt;EObject&gt;) method.</p>
<p class="p7"><span class="Apple-converted-space">     </span>Regards</p>
<p class="p7"><span class="Apple-converted-space">         </span>Ed Willink</p>
<p class="p7">On 14/06/2012 18:22, Uwe Ritzmann wrote:</p>
<p class="p9">Hi there,</p>
<p class="p9">ResourceSetImpl.createResource(URI) hands a contentType=null down the resource creation. In ResourceFactoryRegistryImpl.getFactory(uri,protoMap,extMap,contentMap,contentTypeIdentifier,delegate) this is compared to UNSPECIFIED_CONTENT_TYPE to decide whether the type is to be computed.</p>
<p class="p9">In my case I have an ecore model that I ammended with an alternative ResourceFactory with an second content-type.</p>
<p class="p9">I give an URI with an extension that is registered against the alternative content-type as output parameter to a QVTo transformation. When debugging that run I see that both of my content types are well listed in the contentTypeIdentifierToFactoryMap but as the null does not cause the content-type for my URI to be computed the correct ResourceFactory is not looked up but I run into the fallback Resource.Factory.Registry.DEFAULT_EXTENSION with returns the deault XMI Resource Factory.</p>
<p class="p9">What should I change so that my URI is mapped to the correct ResourceFactory?</p>
<p class="p9">Or is it a bug? And if so: of EMF or of QVTo?</p>
<p class="p9">Thanks in advance,</p>
<p class="p9">Uwe</p>
<p class="p11"><br></p>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888740 is a reply to message #888714] Mon, 18 June 2012 11:10 Go to previous messageGo to next message
<html>
<head>
</head>
Hi Alan<br>
<br>
I'm sure Ed will correct this...<br>
<br>
For major examples that really work see UML2's plugin.xml.<br>
<br>
A relatively simple set of declarations are:<br>
<br>
&nbsp;&nbsp; &lt;extension point="org.eclipse.emf.ecore.generated_package"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;package<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uri=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/ocl/3.1.0/Pivot">"http://www.eclipse.org/ocl/3.1.0/Pivot"</a><br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; class="org.eclipse.ocl.examples.pivot.PivotPackage"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; genModel="model/Pivot.merged.genmodel"/&gt;<br>
&nbsp;&nbsp; &lt;/extension&gt;<br>
<br>
&nbsp;&nbsp; &lt;extension point="org.eclipse.emf.ecore.content_parser"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parser<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; contentTypeIdentifier="org.eclipse.ocl.examples.pivot"<br>
class="org.eclipse.ocl.examples.pivot.utilities.PivotResourceFactoryImpl"/&gt;<br>
<br>
point="org.eclipse.core.contenttype.contentTypes"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;content-type<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; base-type="org.eclipse.emf.ecore.xmi"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; file-extensions="pivot"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; id="org.eclipse.ocl.examples.pivot"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; name="%_UI_Pivot_content_type"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; priority="normal"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;describer
class="org.eclipse.emf.ecore.xmi.impl.RootXMLContentHandlerImpl$Describer"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parameter name="namespace"
value=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/ocl/3.1.0/Pivot">"http://www.eclipse.org/ocl/3.1.0/Pivot"</a>/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parameter name="kind" value="xmi"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/describer&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/content-type&gt;<br>
<br>
org.eclipse.emf.ecore.generated_package: EPackage &lt;=&gt; nsURI<br>
org.eclipse.core.contenttype.contentTypes: nsURI &lt;=&gt; cTI<br>
org.eclipse.emf.ecore.content_parser: cTI &lt;=&gt; ResourceFactory<br>
<br>
<br>
<br>
On 18/06/2012 15:25, Alan McMorran wrote:
<blockquote cite="mid:jrndpg$n7n$1@xxxxxxxxe.org" type="cite">
<title></title>
</style>
<p class="p2"><br>
</p>
class="Apple-converted-space">&nbsp; </span>My situation is that I
the ResourceFactory.<span class="Apple-converted-space">&nbsp; </span>I
<p class="p1"><span class="Apple-tab-span"> </span><a class="moz-txt-link-freetext" href="http://www.eclipse.org/forums/index.php/mv/tree/173386/">http://www.eclipse.org/forums/index.php/mv/tree/173386/</a></p>
<p class="p2"><br>
</p>
class="Apple-converted-space">&nbsp; </span>I use them heavily for
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p3">&nbsp;&nbsp;&nbsp; Regards</p>
<p class="p4"><br>
</p>
<p class="p3">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink</p>
<p class="p4"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>point="com.cimphony.core.emf.schema_resource"&gt;</p>
<p class="p5"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; </span>&lt;schema</p>
<p class="p5"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>uri="*"&gt;</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>&lt;parser</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>priority="5"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>type="xmi"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>name="OMG
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>&lt;/parser&gt;</p>
<p class="p5"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; </span>&lt;/schema&gt;</p>
<p class="p5"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>uri=<a
moz-do-not-send="true"
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>class="com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>isDefault="true"</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>name="GridLAB-D
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>type="glm"/&gt;</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;&nbsp; </span>&lt;/extension&gt;</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p7"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; </span>Regards</p>
<p class="p8"><br>
</p>
<p class="p7"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>Ed
Willink</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p11"><br>
</p>
</blockquote>
<br>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888747 is a reply to message #888740] Mon, 18 June 2012 11:21 Go to previous messageGo to next message
<html>
<head>
<title></title>
p.p7 {margin: 0.0px 0.0px 0.0px 24.0px; font: 16.0px Helvetica; color: #008d12}
p.p8 {margin: 0.0px 0.0px 0.0px 24.0px; font: 16.0px Helvetica; color: #008d12; min-height: 19.0px}
p.p9 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12}
p.p10 {margin: 0.0px 0.0px 0.0px 24.0px; font: 12.0px Helvetica; color: #008d12; min-height: 14.0px}
p.p11 {margin: 0.0px 0.0px 0.0px 36.0px; font: 12.0px Helvetica; color: #930f04}
p.p12 {margin: 0.0px 0.0px 0.0px 36.0px; font: 12.0px Helvetica; color: #930f04; min-height: 14.0px}
p.p13 {margin: 0.0px 0.0px 0.0px 48.0px; font: 12.0px Helvetica; color: #002390}
p.p14 {margin: 0.0px 0.0px 0.0px 48.0px; font: 12.0px Helvetica; color: #002390; min-height: 14.0px}
p.p15 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; min-height: 14.0px}
</style>
</head>
<body>
<p class="p1">Thanks Ed, I wasn't aware of the standard namespace parameter on the Content Describer for providing this functionality. Is this new?</p>
<p class="p1">On 2012-06-18 15:10:24 +0000, Ed Willink said:</p>
<p class="p3">I'm sure Ed will correct this...</p>
<p class="p3">For major examples that really work see UML2's plugin.xml.</p>
<p class="p3">A relatively simple set of declarations are:</p>
<p class="p3">   &lt;extension point="org.eclipse.emf.ecore.generated_package"&gt;</p>
<p class="p3">      &lt;package</p>
<p class="p3">            uri=<a href="http://www.eclipse.org/ocl/3.1.0/Pivot"><span class="s1">"http://www.eclipse.org/ocl/3.1.0/Pivot"</span></a></p>
<p class="p3">            class="org.eclipse.ocl.examples.pivot.PivotPackage"</p>
<p class="p3">            genModel="model/Pivot.merged.genmodel"/&gt;</p>
<p class="p3">   &lt;/extension&gt;</p>
<p class="p3">   &lt;extension point="org.eclipse.emf.ecore.content_parser"&gt;</p>
<p class="p3">      &lt;parser</p>
<p class="p3">            contentTypeIdentifier="org.eclipse.ocl.examples.pivot"</p>
<p class="p3">            class="org.eclipse.ocl.examples.pivot.utilities.PivotResourceFactoryImpl"/&gt;</p>
<p class="p3">   &lt;extension point="org.eclipse.core.contenttype.contentTypes"&gt;</p>
<p class="p3">      &lt;content-type</p>
<p class="p3">            base-type="org.eclipse.emf.ecore.xmi"</p>
<p class="p3">            file-extensions="pivot"</p>
<p class="p3">            id="org.eclipse.ocl.examples.pivot"</p>
<p class="p3">            name="%_UI_Pivot_content_type"</p>
<p class="p3">            priority="normal"&gt;</p>
<p class="p3">         &lt;describer class="org.eclipse.emf.ecore.xmi.impl.RootXMLContentHandlerImpl$Describer"&gt;</p>
<p class="p3">            &lt;parameter name="namespace" value=<a href="http://www.eclipse.org/ocl/3.1.0/Pivot"><span class="s1">"http://www.eclipse.org/ocl/3.1.0/Pivot"</span></a>/&gt;</p>
<p class="p3">            &lt;parameter name="kind" value="xmi"/&gt;</p>
<p class="p3">         &lt;/describer&gt;</p>
<p class="p3">      &lt;/content-type&gt;</p>
<p class="p3">org.eclipse.emf.ecore.generated_package: EPackage &lt;=&gt; nsURI</p>
<p class="p3">org.eclipse.core.contenttype.contentTypes: nsURI &lt;=&gt; cTI</p>
<p class="p3">org.eclipse.emf.ecore.content_parser: cTI &lt;=&gt; ResourceFactory</p>
<p class="p3">On 18/06/2012 15:25, Alan McMorran wrote:</p>
<p class="p5">Ed,</p>
<p class="p5">I couldn't see any existing extension points that let you set a ResourceFactory for an EPackage <span class="Apple-converted-space">  </span>My situation is that I know I have a bunch of EObjects from a particular EPackage but I wasn't aware of an existing extension point that let me select the ResourceFactory.<span class="Apple-converted-space">  </span>I asked about this about 18 months ago:</p>
<p class="p5"><span class="Apple-converted-space"> </span><a href="http://www.eclipse.org/forums/index.php/mv/tree/173386/"><span class="s1">http://www.eclipse.org/forums/index.php/mv/tree/173386/</span></a></p>
<p class="p5">What existing content type declarations let you find valid ResourceFactorys for a particular EPackage?<span class="Apple-converted-space">  </span>I use them heavily for the other way around (when I have an existing resource and want to find the ResourceFactory to parse it), but I couldn't see how to use them to create new, blank Resources that could then be populated with EObjects.</p>
<p class="p5">Apologies if I've misunderstood this thread and gone off on a tangent</p>
<p class="p5">On 2012-06-18 06:54:39 +0000, Ed Willink said:</p>
<p class="p7">Hi Alan</p>
<p class="p7">I'm not clear that your solution achieves anything that could not be achieved by the standard content type declarations. Your extension point may be easier to read but it creates a confusion between alternate declaration mechanisms.</p>
<p class="p7">    Regards</p>
<p class="p7">        Ed Willink</p>
<p class="p7">On 18/06/2012 00:00, Alan McMorran wrote:</p>
<p class="p9">Interesting this has come up as I faced a similar situation about 18 months ago (I think asked about it in the newsgroup) as I'm using QVTo heavily within our RCP app and I wanted an automated way of ensuring only valid ResourceImpl could be used with the outputs as our UI is built automatically from the QVTo AST.<span class="Apple-converted-space">  </span>This is primarily because some of our transforms are to very specific models that are reverse engineered from existing legacy data formats so our users don't care or need to know that they can save the output to an XMI file when they want it in the legacy column-delimited format.</p>
<p class="p9">My solution is an extension point where an EPackage URI has one or more ResourceFactory's associated with it (and for those that are universal e.g. XMI it simply has the URI as *).<span class="Apple-converted-space">  </span>I also added some additional meta-data around about them to give more human-readable names, the file extensions etc. Within the UI now it can look out the output parameter from QVTo (or from CDO when exporting from the repository) programatically then from this EPackage find the ResourceFactorys that go with that EPackage. The extension also includes an "isDefault" and "priority" attributes so I can set the EPackage-specific ResourceFactorys as default and also change the priority of the agnostic ones to determine what is used by default.</p>
<p class="p9">A lot of this was aimed at providing an extensible way of building the UI hence the inclusion of human-readable names.<span class="Apple-converted-space">  </span>Works quite nicely for our needs!</p>
<p class="p9">A couple of examples are below.</p>
<p class="p9">Alan</p>
<p class="p9">&lt;extension</p>
<p class="p9"><span class="Apple-converted-space">         </span>point="com.cimphony.core.emf.schema_resource"&gt;</p>
<p class="p9"><span class="Apple-converted-space">      </span>&lt;schema</p>
<p class="p9"><span class="Apple-converted-space">            </span>uri="*"&gt;</p>
<p class="p9"><span class="Apple-converted-space">         </span>&lt;parser</p>
<p class="p9"><span class="Apple-converted-space">               </span>class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p9"><span class="Apple-converted-space">               </span>priority="5"</p>
<p class="p9"><span class="Apple-converted-space">               </span>type="xmi"</p>
<p class="p9"><span class="Apple-converted-space">               </span>name="OMG XMI 2.0 Format"&gt;</p>
<p class="p9"><span class="Apple-converted-space">         </span>&lt;/parser&gt;</p>
<p class="p9"><span class="Apple-converted-space">      </span>&lt;/schema&gt;</p>
<p class="p9"><span class="Apple-converted-space">            </span>uri=<a href="http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"><span class="s1">"http://www.pnnl.gov/gridlabd/2.1/powerflow/distribution"</span></a>&gt;</p>
<p class="p9"><span class="Apple-converted-space">               </span>class="com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
<p class="p9"><span class="Apple-converted-space">               </span>isDefault="true"</p>
<p class="p9"><span class="Apple-converted-space">               </span>name="GridLAB-D Powerflow Format"</p>
<p class="p9"><span class="Apple-converted-space">               </span>type="glm"/&gt;</p>
<p class="p9"><span class="Apple-converted-space">   </span>&lt;/extension&gt;</p>
<p class="p9">On 2012-06-16 12:33:38 +0000, Ed Willink said:</p>
<p class="p11">Hi Uwe</p>
<p class="p12"><br></p>
<p class="p11">Abstracting away from the details for a moment the problem seems to be:</p>
<p class="p11">Given a URI and a forest of EObjects, create a suitable Resource for those EObjects and assign them to Resource.contents.</p>
<p class="p11">If you're writing the code you may know the content-type and so you can do it right.</p>
<p class="p11">A modeling tool such as QVTo, ATL, Epsilon and probably even Xtend may not have a content-type concept to enable you to get it right.</p>
<p class="p11">So, today, such tools could examine all the EPackages and use Java reflection to get the eCONTENT_TYPE and endeavour to find a content-type that is compatible with all the EPackages; quite easy when there's only one or it's homogeneous.</p>
<p class="p11">If this is the required solution, EMF could provide an eContentType() API to avoid reflection and/or a createResource(URI, List&lt;EObject&gt;) method.</p>
<p class="p11"><span class="Apple-converted-space">     </span>Regards</p>
<p class="p11"><span class="Apple-converted-space">         </span>Ed Willink</p>
<p class="p11">On 14/06/2012 18:22, Uwe Ritzmann wrote:</p>
<p class="p13">Hi there,</p>
<p class="p14"><br></p>
<p class="p13">ResourceSetImpl.createResource(URI) hands a contentType=null down the resource creation. In ResourceFactoryRegistryImpl.getFactory(uri,protoMap,extMap,contentMap,contentTypeIdentifier,delegate) this is compared to UNSPECIFIED_CONTENT_TYPE to decide whether the type is to be computed.</p>
<p class="p13">In my case I have an ecore model that I ammended with an alternative ResourceFactory with an second content-type.</p>
<p class="p13">I give an URI with an extension that is registered against the alternative content-type as output parameter to a QVTo transformation. When debugging that run I see that both of my content types are well listed in the contentTypeIdentifierToFactoryMap but as the null does not cause the content-type for my URI to be computed the correct ResourceFactory is not looked up but I run into the fallback Resource.Factory.Registry.DEFAULT_EXTENSION with returns the deault XMI Resource Factory.</p>
<p class="p13">What should I change so that my URI is mapped to the correct ResourceFactory?</p>
<p class="p13">Or is it a bug? And if so: of EMF or of QVTo?</p>
<p class="p13">Thanks in advance,</p>
<p class="p13">Uwe</p>
<p class="p15"><br></p>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888786 is a reply to message #888747] Mon, 18 June 2012 12:04 Go to previous messageGo to next message
<html>
<head>
</head>
Hi Alan<br>
<br>
CVS shows RootXMLContentHandlerImpl unchanged since 2008.<br>
<br>
<br>
<br>
On 18/06/2012 16:21, Alan McMorran wrote:
<blockquote cite="mid:jrnh1o$toi$1@xxxxxxxxe.org" type="cite">
<title></title>
</style>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
plugin.xml.</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p3">&nbsp;&nbsp; &lt;extension
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;package</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uri=<a moz-do-not-send="true"
<p class="p3">&nbsp;&nbsp; &lt;/extension&gt;</p>
<p class="p4"><br>
</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parser</p>
<p class="p4"><br>
</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;content-type</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; base-type="org.eclipse.emf.ecore.xmi"</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; file-extensions="pivot"</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; id="org.eclipse.ocl.examples.pivot"</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; name="%_UI_Pivot_content_type"</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; priority="normal"&gt;</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;describer
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parameter name="namespace" value=<a
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;parameter name="kind"
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/describer&gt;</p>
<p class="p3">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/content-type&gt;</p>
<p class="p4"><br>
</p>
&lt;=&gt; nsURI</p>
&lt;=&gt; cTI</p>
ResourceFactory</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p6"><br>
</p>
<p class="p5"><span class="Apple-converted-space">&nbsp;</span><a
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p7">&nbsp;&nbsp;&nbsp; Regards</p>
<p class="p8"><br>
</p>
<p class="p7">&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink</p>
<p class="p8"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>point="com.cimphony.core.emf.schema_resource"&gt;</p>
<p class="p9"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; </span>&lt;schema</p>
<p class="p9"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>uri="*"&gt;</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>&lt;parser</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>priority="5"</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>type="xmi"</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>name="OMG
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>&lt;/parser&gt;</p>
<p class="p9"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; </span>&lt;/schema&gt;</p>
<p class="p9"><span class="Apple-converted-space">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>uri=<a
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>class="com.cimphony.schemas.gridlabd.v2.powerflow.Distribution.util.DistributionResourceFactoryImpl"</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>isDefault="true"</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>name="GridLAB-D
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; </span>type="glm"/&gt;</p>
<p class="p9"><span class="Apple-converted-space">&nbsp;&nbsp; </span>&lt;/extension&gt;</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p11"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; </span>Regards</p>
<p class="p12"><br>
</p>
<p class="p11"><span class="Apple-converted-space">&nbsp;&nbsp; &nbsp; &nbsp; &nbsp; </span>Ed
Willink</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p15"><br>
</p>
</blockquote>
<br>
</body>
</html>
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888824 is a reply to message #888465] Mon, 18 June 2012 13:09 Go to previous messageGo to next message
Ed,
Comments below.
On 18/06/2012 8:49 AM, Ed Willink wrote:
> Hi
> Below
>> Ed,
>> Comments below.
>>> Hi Ed
>>> lower bound.
>> new things. If EMF 2.8 installs and works well in Eclipse 3.5, then
Yes, it's too late for Juno.
Such is life, but I can't make that my problem.
Then again, maybe not.
Yes, we support Eclipse 3.5.
> As from Juno, EMF is partially part of the platform, so upgrading EMF
> to support modeling applications may become difficult for some users.
> It would be nice to try to help.
Yes, but not to the point of butchering API.
> Xtext here to understand their pains and workarounds for polymorphic
> distributions.
I tried to make that easier but broadening the range of platforms in
which EMF will install. That's will have to suffice.
> Regards
> Ed Willink
Re: ContentHandler.UNSPECIFIED_CONTENT_TYPE vs null [message #888827 is a reply to message #888786] Mon, 18 June 2012 13:12 Go to previous message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Yes, the general idea is that the namespace of the root XML element
(or the element nested within the XMI root element) will use a
namespace that corresponds to a package's nsURI so using that to
recognize content type deals with the common case.<br>
<br>
<br>
<div class="moz-cite-prefix">On 18/06/2012 6:04 PM, Ed Willink
wrote:<br>
</div>
<blockquote cite="mid:jrnjje$35j$1@xxxxxxxxe.org" type="cite">
Hi Alan<br>
<br>
<br>
<br>
<br>
<title></title>
</style>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p2"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
plugin.xml.</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
&lt;=&gt; nsURI</p>
&lt;=&gt; cTI</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p4"><br>
</p>
<p class="p6"><br>
</p>
select the ResourceFactory.<span class="Apple-converted-space">&nbsp;
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p6"><br>
</p>
<p class="p8"><br>
</p>
mechanisms.</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
<p class="p8"><br>
</p>
class="Apple-converted-space">&nbsp; </span>This is primarily
<p class="p10"><br>
</p>
the URI as *).<span class="Apple-converted-space">&nbsp; </span>I
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p10"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
homogeneous.</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
Willink</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p12"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
content-type.</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p14"><br>
</p>
<p class="p15"><br>
</p>
</blockquote>
<br>
</blockquote>
<br>
<br>
</body>
</html>
Previous Topic:[CDO/Dawn] Deadlock on accessing CDOView
Next Topic:[CDO] setting a reference feature unique not allowed while advised in performance tip
Current Time: Fri Jul 25 21:53:23 EDT 2025
Powered by FUDForum. Page generated in 0.10689 seconds
