Home » Modeling » Epsilon » [EWL] Wizards is not appearing in RCP Application
[EWL] Wizards is not appearing in RCP Application [message #885429] Tue, 12 June 2012 21:21 Go to next message
Hi, everybody.
I would like ask you a help once again.
I've created some wizards to my GMF application (using EuGENia) that
work properly when I run the project as an Eclipse Application.
Therefore, when I export it as an Eclipse Product, the wizards do not
appear in the resulting RCP application. I've added the plugin contaning
the EWL in the dependencies of the main application project.
[Updated on: Tue, 12 June 2012 22:18] by Moderator
Re: [EWL] Wizards is not appearing in RCP Application [message #885567 is a reply to message #885429] Wed, 13 June 2012 04:58 Go to previous messageGo to next message
Hi Robson,
Which version of Eclipse are you using? Is it Indigo, or Juno?
Just yesterday, I fixed a bug in which EWL wizards would not appear after right-clicking several times on a model. It's been happening since I switched to Juno, I think.
Please have a look at the Error Log view and check if there's something related to EWL in there.
Antonio
Re: [EWL] Wizards is not appearing in RCP Application [message #885760 is a reply to message #885567] Wed, 13 June 2012 10:43 Go to previous messageGo to next message
Hi Robson,
Make sure that you are exporting all the epsilon plugins to your RCP, i.e. add the epsilon plugins to your xxx.rcp.prodcut dependencies (or just the ones you need if you know what you are doing). Also, double check that your wizard sources are added to the build path of your plugins.
When you run as an Eclipse Application, the eclipse application is a "copy" of your current environment (actually in the Plugin-ins tab of your run configuration you can select which plugins to run), and plugins are loaded from the sources as in the workspace. When you export your RCP the resulting eclipse will only have the plugins you added to the dependencies (.product file) and plugins in the workspace would be built (only adding things in the build-path) and added as jars to your rcp. You can go to your rco folder and look at the plugins folder and see what is exactly being exported.
Re: [EWL] Wizards is not appearing in RCP Application [message #885933 is a reply to message #885567] Wed, 13 June 2012 18:17 Go to previous messageGo to next message
Hi Antonio,
I'm using the Indigo version.
Version: Indigo Service Release 1
Build id: 20110916-0149
In the Error Log View no messages related to EWL appears.
Robson
Re: [EWL] Wizards is not appearing in RCP Application [message #885939 is a reply to message #885760] Wed, 13 June 2012 18:39 Go to previous messageGo to next message
Hi Horacio,
I'm exporting all the epsilon plugins to my RCP. Additionaly, I use the
option "Add Required Plug-ins" located in the "Dependencies" tab of the
xxx.product to add all other plugins.
I also checked that my wizard sources are added to the build path.
I also checked the exported .jar in the RCP plugins folder and the .ewl is there.
Therefore, the wizards is not available in any of RCP menus. Sad
Robson
Re: [EWL] Wizards is not appearing in RCP Application [message #889898 is a reply to message #885939] Wed, 20 June 2012 03:55 Go to previous message
Well, I'm a bit at a loss. Could you provide us with a minimal example that reproduces the problem?
Previous Topic:[EUnit] - Some thoughts and considerations about mode testing with EUnit
Next Topic:how to set the property by only name?
Current Time: Sat Jul 26 18:51:52 EDT 2025
Powered by FUDForum. Page generated in 0.10198 seconds
