Home » Modeling » UML2 » Load uml resource from an uploaded file
Load uml resource from an uploaded file [message #885670] Wed, 13 June 2012 08:21 Go to next message
Hi All!
I'm trying to get an uml-model from an uploaded xmi-file.
For extracting the uml model I used following code:
ResourceSet resourceSet = new ResourceSetImpl();
Registry packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put("http:||schema.omg.org/spec/XMI/2.1", UMLPackage.eINSTANCE);
packageRegistry.put("http:||schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION, new XMIResourceFactoryImpl());
resourceSet.getLoadOptions().put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
URI uri = URI.createURI("model.xmi");
Package root = UML2Util.load(resourceSet, uri, UMLPackage.Literals.PACKAGE);
System.out.println(root);
This code works for files with a known name that are located in my eclipse workspace. What I want to do is to upload a file via my web application and then extract a model from it. For upload I'm using the org.apache.commons.fileupload.FileItem; The upload itself works fine. I have the input stream of the file.
To extract the model from that inputstream I tried to do following (since it worked i.e. for ecore-files):
Resource xmiResource = resourceSet.createResource(URI.createURI(uploadedFile.getName()));
xmiResource.load(uploadedFile.getInputStream(), getLoadParams());
But the resource could not be loaded. It seems that only UML2Util.load can load the UML model from xmi-files in a correct way.
Is there a way to use the input stream with UML2Util or, maybe, another solution for my problem?
Many thanks in advance!
[Updated on: Wed, 13 June 2012 10:49] by Moderator
Re: Load uml resource from an uploaded file [message #885814 is a reply to message #885670] Wed, 13 June 2012 12:38 Go to previous messageGo to next message
Hi Max,
Comments below.
On 13.06.2012 14:21, max power wrote:
> Hi All!
This registers the generic XMIResourceFactory for the .xmi file extension.
In this case, the URI actually points to an existing resource (i.e. model
file). In this case, despite associating the .xmi extension with the generic
XMIResourceFactory above, the actual content of the file can be used to
detect the content type and correct resource factory
(UMLResourceFactoryImpl). This way, an UMLResource is actually created and
used for loading.
> This code works for files with a known name that a located in my eclipse workspace. What I want to do is to upload a file via my web application and then extract a model from it. For upload I'm using the org.apache.commons.fileupload.FileItem; The upload itself works fine. I have the input stream of the file.
In this case, you are creating the resource with an URI that doesn't point
to an existing resource, just with its name. In this case, the registration
you did above catches and a plain XMIResource is created, which will just
load generic dynamic eobjects, since it has no association with eth UML
metamodel.
You could
- use ResourceSet.createResource(URI, String) to pass the expected content
type of the resource ("org.eclipse.uml2.uml"), provided you did set up the
resource factory registry correcty and registered that content type (since
it worked in the local version, this seems to be the case).
- actually use the remote URI to create and load the resource
- register the UMLResourceFactoryImpl for the .xmi extension (probably not a
good idea, because an .xmi file could contain pretty much any kind of model)
Re: Load uml resource from an uploaded file [message #886167 is a reply to message #885814] Thu, 14 June 2012 07:19 Go to previous message
Carsten, thank you very much for your detailed reply!
It works now:
extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION, new UMLResourceFactoryImpl());
URI uri = URI.createURI(file.getName());
Resource xmiResource = resourceSet.createResource(URI.createURI(file.getName()));
xmiResource.load(xmiModelFile.getInputStream(), getLoadParams());
[Updated on: Thu, 14 June 2012 07:19] by Moderator
Previous Topic:Convert to Ecore Model
Next Topic:how to load int generals from Integer
Current Time: Wed Jul 23 12:35:24 EDT 2025
Powered by FUDForum. Page generated in 0.07244 seconds
