[CDO] FileNotFoundException when using object.eGet() [message #885614] |
Wed, 13 June 2012 06:23  |
I had this before, but never paid much attention to it, now it's actually a reproducable problem, so I am investigating.
So, somehow CDO tries to resolve a reference, which ends up in a ResourceSet demand loading
an object. The resource holding this object is really a CDOResource, so I am puzzled how this can happen?
Any idea on how to trouble shoot? (Could my code accidently put a referenced object in a non-CDO resource?)
I am going to try by trapping the exception, and see what the resource URI is...
thanx Christophe
java.io.FileNotFoundException: temp (No such file or directory)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:216)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1001)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:668)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:636)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:187)
at org.eclipse.emf.internal.cdo.CDOObjectImpl.dynamicGet(CDOObjectImpl.java:492)
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateSingleEObject.dynamicGet(EStructuralFeatureImpl.java:2330)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1037)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1008)
at com.netxforge.netxstudio.models.export.MasterDataExporterRevenge.processAttributeData(MasterDataExporterRevenge.java:320)
at com.netxforge.netxstudio.models.export.MasterDataExporterRevenge.processAttributesClass(MasterDataExporterRevenge.java:261)
at com.netxforge.netxstudio.models.export.MasterDataExporterRevenge.processAttributeClassifier(MasterDataExporterRevenge.java:222)
at com.netxforge.netxstudio.models.export.MasterDataExporterRevenge.processPackages(MasterDataExporterRevenge.java:95)
at com.netxforge.netxstudio.models.export.MasterDataExporterRevenge.process(MasterDataExporterRevenge.java:70)
... 3 more
Caused by: java.io.FileNotFoundException: temp (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:105)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:350)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1262)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 20 more
Re: [CDO] FileNotFoundException when using object.eGet() [message #885682 is a reply to message #885614] |
Wed, 13 June 2012 08:35   |
Hi Christophe,
Is it possible for you to write a small test case that reproduces this issue? Please have a look at our other test cases
and see how simple it is ;-)
Cheers
/Eike
http://www.esc-net.de
Am 13.06.2012 12:23, schrieb Christophe Bouhier:
> an object. The resource holding this object is really a CDOResource, so I am puzzled how this can happen? Any idea on
> thanx Christophe
> at
> at
> at
> at
> ... 3 more
> at
> ... 20 more
Re: [CDO] FileNotFoundException when using object.eGet() [message #886161 is a reply to message #885682] |
Thu, 14 June 2012 07:04  |
Hi Eike,
As you know, I have frequently these similar type of issues which seem to relate to database issues.... actually to be honest I don't know why this happens. (The root cause).
What I do know is that, it doesn't show up in unit test and usage of the system in an early phase. These things tend to occure after while, so reproducing them
is very challenging. I am in the process to setup a test environment which mimics the customer set up, where I want to do load/stress testing the system, hopefully this will
produce better insight in what is going on my (unfortunately) unstable system.
Cheers Christophe
FUDForum. Page generated in 0.07585 seconds
