Home » Modeling » EMF » EMF Transaction find deleted elements
EMF Transaction find deleted elements [message #885281] Tue, 12 June 2012 14:28 Go to next message
I need to respond with some action if one or more elements are deleted
from a TransactionalResourceSet. Previously we just adapted the
DeleteCommand with a homegrown notification mechanism, but someone
raised an objection. I now try to "detect" elements that are deleted on
a per-transaction base via an EMFT ResourceSetListener somehow like this:
resourceSetChanged(RSCEvent event){
Set orphaned = new HashSet();
switch (Notificationtype){
case Add: orphaned.remove(...)
case Remove: orphaned.add(...)
It seems to work but it does feel somewhat hackish..
Maybe there's a better solution? I tried
event.getTransaction().getChangeModel().getDetachedObjects() but that
doesn't return anything.
Thanks for comments,
Felix
Re: EMF Transaction find deleted elements [message #885289 is a reply to message #885281] Tue, 12 June 2012 14:42 Go to previous messageGo to next message
Uhm very pseudocodish.. I just do that for each notification and look at
the orphaned set in the end. Deleted elements should be in the set
after all notifications have been processed.
> Felix
Re: EMF Transaction find deleted elements [message #885331 is a reply to message #885281] Tue, 12 June 2012 16:32 Go to previous messageGo to next message
Hi, Felix,
Objects that were deleted will no longer be attached to a resource. I
think you need only process the "old value" objects of REMOVE and
REMOVE_MANY notifications for which eResource() is now null.
HTH,
Christian
On 2012-06-12 18:28:54 +0000, Felix Dorner said:
> this:
> Felix
Re: EMF Transaction find deleted elements [message #885346 is a reply to message #885331] Tue, 12 June 2012 17:05 Go to previous messageGo to next message
El 12/06/2012 22:32, Christian W. Damus escribió:
> Hi, Felix,
Oh yes, that's better. I thought doing so would accidentially count the
'moved' ones, but forgot the fact that I am in fact notified after the
whole thing already happened, not in between remove/add as with normal
EMF notifications.
Thanks Christian. Btw it's a pleasure to read your code.
> HTH,
> Christian
>> Hi,
>> on a per-transaction base via an EMFT ResourceSetListener somehow like
>> this:
>> Felix
Re: EMF Transaction find deleted elements [message #885438 is a reply to message #885346] Tue, 12 June 2012 21:56 Go to previous message
Felix,
I'm glad it's working for you.
And thanks! I'm glad to be able to give you something good to read.
There's so much junk on the Interwebs. ;-)
Yes, that displacement in time can be a blessing but it can also bite,
because for any feature that changed more than once, only the last
notification makes sense when interpreted as a delta from the object's
current state to the previous. All prior notifications are relative to
earlier states that the object isn't in, now.
cW
>> Hi, Felix,
> EMF notifications.
>> HTH,
>> Christian
>>> Hi,
>>> this:
>>> Felix
Previous Topic:XPand - JMerge Protected Region
Next Topic:[Teneo] Hibernate Auditing Support
Current Time: Wed Jul 23 21:43:18 EDT 2025
Powered by FUDForum. Page generated in 0.06753 seconds
