Resolving imports in standalone generator [message #775090] |
Thu, 05 January 2012 04:59  |
I realize that this has been asked before, but I just can't find the solution.
So bear with me as I try to ask this question in a simple way instead of posting heaps of code that doesn't work, I'll just post some simpler more naive code that doesn't work either ;-)
I am trying to write a standalone wrapper for my code generator, and I am having trouble with the imports.
I have this simple domainmodel derived model:
* I is not based om XBase
* Uses namespace imports
grammar com.mydsl.SchemaDSL with org.eclipse.xtext.common.Terminals
generate schemaDSL "http://com.mydsl.SchemaDSL"
SchemaDSL:
PackageDeclaration
imports+=Import*
elements+=Entity*;
PackageDeclaration:
'namespace' name=QualifiedName;
Import:
'import' importedNamespace=QualifiedName;
Entity: Element;
Element:
'element' name=ValidID ('extends' superType=[Entity])? '{'
properties+=Property*
Property:
name=ValidID ':' type=[Entity];
QualifiedName:
ID ('.' ID)*;
ValidID:
ID
The above model is slightly simplified. I can post the real one if needed.
Using this model I can create the following simple files:
main.model:
namespace com.mydsl.main
import com.mydsl.ref.ReferencedEntity
element MainEntity {
x : LocalEntity
y : ReferencedEntity
element LocalEntity {
ref.model:
namespace com.mydsl.ref
element ReferencedEntity {
number : Integer
I can launch the generated eclipse UI, and it generates files beautifully.
This standalone generator is inspired by the one from the state machine example.
Injector injector = new SchemaDSLStandaloneSetupGenerated().createInjectorAndDoEMFRegistration();
Main2 main = injector.getInstance(Main2.class);
// load the resource
ResourceSet set = main.resourceSetProvider.get();
Resource resource = set.getResource(URI.createURI(args[0]), true);
// validate the resource
List<Issue> list = main.validator.validate(resource, CheckMode.ALL, CancelIndicator.NullImpl);
if (!list.isEmpty()) {
for (Issue issue : list) {
System.err.println(issue);
System.exit(-1);
// configure and start the generator
main.fileAccess.setOutputPath("src-gen/");
main.generator.doGenerate(resource, main.fileAccess);
System.out.println("Code generation finished.");
After adding all dependencies to my classpath I can use that to compile ref.model without errors.
When I compile main.model, it fails in the validator:
ERROR:Couldn't resolve reference to Entity 'ReferencedEntity'. (src\main.model line : 7)
I have put ref.model on my classpath, but that didn't make any difference.
http://www.eclipse.org/Xtext/documentation/1_0_1/xtext.html#processing_Xtext_models
Quote:If one Resource references another Resource, EMF will automatically load that other Resource into the same ResourceSet as soon as the cross-reference is resolved. Resolution of cross-references is done lazy, i.e. on first access.
Somehow I need to get my standalone EMF setup to resolve the resources, but I just can't find out how to do it.
The closest I got was manually scanning my file system and adding all files to the resourceset like this:
for (String modelFile : getSourceFiles(srcFolder) {
Resource modelResource = set.getResource(URI.createURI(modelFile), true);
resource.getContents().addAll(modelResource.getContents());
I could make this post a lot longer by trying to explain all the things I have tried and failed with. But I think it is already too long.
This must have been solved many times by the community, since a standalone generator for any DSL must be the first requirement for deployment.
I hope that you can help me in the right direction.
Thanks in advance.
Re: Resolving imports in standalone generator [message #775149 is a reply to message #775126] |
Thu, 05 January 2012 07:59   |
Thank you for your reply.
I have been down this path, but I ran into another problem, so I thought that I would backtrack a little in my original question, to find out if I should have gone down that road in the first place.
Ok, so here is my standalone generator that manually loads all referenced files:
String folderName = args[0];
Resource resource = null;
for (String fileName : getSourceFiles(folderName)) {
if (resource == null) {
resource = set.getResource(URI.createURI(fileName), true);
} else {
Resource modelResource = set.getResource(URI.createURI(fileName), true);
// validator disabled for now
(I pass in 'src' and it discovers 'src/*.model')
This works for the two files main.model and ref.model above.
However if I introduce ref2.model:
namespace com.mydsl.ref2 r2
element ReferencedEntity2 {
number : Integer
and change ref.model to:
namespace com.mydsl.ref r
import com.mydsl.ref2.ReferencedEntity2
number : Integer
ref2 : ReferencedEntity2
0 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.1.0.2.1::2::/4' failed.
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:352)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.resolveShortFragment(LazyURIEncoder.java:92)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:80)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:162)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:219)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:202)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:262)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1475)
at com.mydsl.schemaDSL.impl.PropertyImpl.getType(PropertyImpl.java:204)
I get the error when I try to access a referenced type:
def mapType(Property p) {
var type = p.type // type is a reference to Entity
My guess is that I should read the resources in some different way, but I am stumped on what that way might be.
Re: Resolving imports in standalone generator [message #885305 is a reply to message #775345] |
Tue, 12 June 2012 15:28   |
Lasse,
I tried your example because I was running into the same problem you had. However, when I do, I get the following stack trace when I run my compiler at the command line in cygwin:
$ java edu.byu.ee.phdl.Compile fmc_module
1 [main] ERROR xt.linking.lazy.LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.3.0.3.5::5::/8' failed.
java.lang.StringIndexOutOfBoundsException: String index out of range: 402
at java.lang.String.substring(String.java:1934)
at org.eclipse.xtext.nodemodel.impl.AbstractNode.getText(AbstractNode.java:84)
at org.eclipse.xtext.nodemodel.util.NodeModelUtils.getTokenText(NodeModelUtils.java:351)
at org.eclipse.xtext.linking.impl.LinkingHelper.getCrossRefNodeAsString(LinkingHelper.java:51)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getCrossRefNodeAsString(DefaultLinkingService.java:132)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:113)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:175)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:143)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:104)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:491)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:127)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:62)
at edu.byu.ee.phdl.Compile.run(Compile.java:81)
at edu.byu.ee.phdl.Compile.main(Compile.java:117)
Unexpected error
org.eclipse.emf.common.util.WrappedException: java.lang.StringIndexOutOfBoundsException: String index out of range: 402
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:209)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 402
... 7 more
However, when I create a run configuration in Eclipse, give it my main class (from your example) I get expected output in the console window:
The program also generates all the output files as expected. As far as I can tell, I have all of the jar dependencies on my classpath for running the standalone application outside of eclipse:
CLASSPATH=.;
C:\Users\brad\eclipse\edu.byu.ee.phdl.xtext\bin;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.xtext_2.2.1.v201112130541.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.emf.ecore_2.7.0.v20120127-1122.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.emf.common_2.7.0.v20120127-1122.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122.jar;
C:\Program Files\eclipse Indigo\plugins\com.google.inject_3.0.0.no_aop.jar;
C:\Program Files\eclipse Indigo\plugins\javax.inject_1.0.0.v20091030.jar;
C:\Program Files\eclipse Indigo\plugins\org.apache.log4j_1.2.15.v201012070815.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.xtext.common.types_2.2.1.v201112130541.jar;
C:\Program Files\eclipse Indigo\plugins\com.google.guava_10.0.1.1.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.xtext.util_2.2.1.v201112130541.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.xtext.xbase.lib_2.2.1.v201112130541.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.emf.mwe.utils_1.2.1.v201112070431.jar;
C:\Program Files\eclipse Indigo\plugins\org.eclipse.emf.mwe.core_1.2.1.v201112070431.jar;
C:\Program Files\eclipse Indigo\plugins\org.apache.commons.logging_1.0.4.v201101211617.jar
I have tried closing my currently running instance of Eclipse to rule out any global registry issues. I end up with the same problem with the linking. My intuition says it has something to do with the URI, since it works inside Eclipse but not from the command line. Do I need to add a line in the main class that sets the platformURI? such as:
new org.eclipse.emf.mwe.utils.StandaloneSetup().setPlatformUri(<cwd>);
where <cwd> is the current working directory (specified by your source folder argument in the main method).
I'm really stumped, as the error reporting doesn't appear to offer me any good direction.
My question is: have you been able to run this outside of the Eclipse platform, truly from the command-line with Eclipse completely closed? If so, would you mind sharing how you did it?
FUDForum. Page generated in 0.09300 seconds
