Table LISTING not found in greenpages example [message #683938] |
Tue, 14 June 2011 13:40  |
I get the following error after completing the Greenpages tutorial, Sec. 5.4, Trying out the JPA middle tier:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.0 (Build 1.0 - 20080707)): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.h2.jdbc.JdbcSQLException: Table LISTING not found; SQL statement:
SELECT LISTING_NUMBER, FIRST_NAME, LAST_NAME, EMAIL_ADDRESS FROM LISTING WHERE (UPPER(LAST_NAME) LIKE ?) [42102-71]
Error Code: 42102
Call: SELECT LISTING_NUMBER, FIRST_NAME, LAST_NAME, EMAIL_ADDRESS FROM LISTING WHERE (UPPER(LAST_NAME) LIKE ?)
bind => [%%]
Query: ReadAllQuery(greenpages.jpa.JpaListing)
org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:322)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:646)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:500)
org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:522)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:204)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:190)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:261)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:594)
org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2505)
org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRows(ExpressionQueryMechanism.java:2463)
org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:478)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:883)
org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:666)
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:844)
org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:456)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:906)
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2588)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1178)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1162)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1136)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1118)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:399)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:517)
greenpages.jpa.JpaDirectory.search(JpaDirectory.java:37)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
$Proxy146.search(Unknown Source)
greenpages.web.GreenPagesController.search(GreenPagesController.java:27)
org.springframework.web.bind.annotation.support.HandlerMethodInvoker.doInvokeMethod(HandlerMethodInvoker.java:710)
org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:167)
org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:414)
org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:402)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:771)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:716)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:647)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:552)
javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
root cause
org.h2.message.Message.getSQLException(Message.java:92)
org.h2.message.Message.getSQLException(Message.java:96)
org.h2.message.Message.getSQLException(Message.java:74)
org.h2.command.Parser.readTableOrView(Parser.java:4030)
org.h2.command.Parser.readTableFilter(Parser.java:911)
org.h2.command.Parser.parseSelectSimpleFromPart(Parser.java:1406)
org.h2.command.Parser.parseSelectSimple(Parser.java:1504)
org.h2.command.Parser.parseSelectSub(Parser.java:1400)
org.h2.command.Parser.parseSelectUnion(Parser.java:1279)
org.h2.command.Parser.parseSelect(Parser.java:1267)
org.h2.command.Parser.parsePrepared(Parser.java:390)
org.h2.command.Parser.parse(Parser.java:286)
org.h2.command.Parser.parse(Parser.java:258)
org.h2.command.Parser.prepareCommand(Parser.java:230)
org.h2.engine.Session.prepareLocal(Session.java:283)
org.h2.engine.Session.prepareCommand(Session.java:244)
org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1020)
org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:1216)
org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:163)
org.apache.commons.dbcp.DelegatingConnection.prepareStatement(DelegatingConnection.java:248)
org.apache.commons.dbcp.PoolingDataSource$PoolGuardConnectionWrapper.prepareStatement(PoolingDataSource.java:302)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1340)
org.eclipse.persistence.internal.databaseaccess.DatabaseCall.prepareStatement(DatabaseCall.java:648)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:550)
I've checked all the configuration files in greenpages.db, greenpages.app, greenpages.jpa, etc., and all is according to the documentation in, "Creating an application with EclipseRT Virgo Web Server". The H2 server is running and all the bundles load and are started in OSGI. What could be wrong?
Re: Table LISTING not found in greenpages example [message #885320 is a reply to message #683938] |
Tue, 12 June 2012 16:04   |
I get this same error. And yes I did run the data.bat script. If I stop the Virgo server and log into the H2 web console I can successfully query for the table LISTING. I see this in the log file:
[EL Info]: 2012.06.12 15:21:07.792--ServerSession(1089104378)--Thread(Thread[http-bio-8081-exec-6,5,main])--EclipseLink, version: Eclipse Persistence Services - 1.0 (Build 1.0 - 20080707)
[EL Config]: 2012.06.12 15:21:07.801--ServerSession(1089104378)--Connection(1030059569)--Thread(Thread[http-bio-8081-exec-6,5,main])--connecting(DatabaseLogin(
platform=>HSQLPlatform
user name=> ""
connector=>JNDIConnector datasource name=>null
[EL Config]: 2012.06.12 15:21:07.925--ServerSession(1089104378)--Connection(1452500205)--Thread(Thread[http-bio-8081-exec-6,5,main])--Connected: jdbc:h2:~/greenpages-db/greenpages
User: GREENPAGES
Database: H2 Version: 1.0.71 (2008-04-25)
Driver: H2 JDBC Driver Version: 1.0.71 (2008-04-25)
[EL Config]: 2012.06.12 15:21:07.957--ServerSession(1089104378)--Connection(1724329986)--Thread(Thread[http-bio-8081-exec-6,5,main])--connecting(DatabaseLogin(
user name=> ""
[EL Config]: 2012.06.12 15:21:07.958--ServerSession(1089104378)--Connection(522258437)--Thread(Thread[http-bio-8081-exec-6,5,main])--Connected: jdbc:h2:~/greenpages-db/greenpages
User: GREENPAGES
[EL Info]: 2012.06.12 15:21:07.978--ServerSession(1089104378)--Thread(Thread[http-bio-8081-exec-6,5,main])--file:/C:/Virgo/VIRGO-~2.REL/work/org.eclipse.virgo.kernel.deployer_3.0.3.RELEASE/staging/greenpages-2.6.0.RELEASE/bundle/greenpages-2.6.0.RELEASE-greenpages.jpa/2.5.0/greenpages.jpa.jar/-GreenPages login successful
[EL Fine]: 2012.06.12 15:21:08.055--ServerSession(1089104378)--Connection(1137425244)--Thread(Thread[http-bio-8081-exec-6,5,main])--SELECT LISTING_NUMBER, FIRST_NAME, LAST_NAME, EMAIL_ADDRESS FROM LISTING WHERE (UPPER(LAST_NAME) LIKE ?)
bind => [%ROD%]
[EL Warning]: 2012.06.12 15:21:08.070--UnitOfWork(2017618908)--Thread(Thread[http-bio-8081-exec-6,5,main])--Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.0 (Build 1.0 - 20080707)): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 42102
bind => [%ROD%]
Servlet.service() for servlet in context with path [/greenpages] threw exception [Request processing failed; nested exception is Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.0 (Build 1.0 - 20080707)): org.eclipse.persistence.exceptions.DatabaseException
[Updated on: Tue, 12 June 2012 16:04] by Moderator
Re: Table LISTING not found in greenpages example [message #989613 is a reply to message #885698] |
Thu, 06 December 2012 18:06  |
Jay Flowers,
Thanks very much! That solved my problem too. Basically the run script and the pom.xml were using 2 different versions of H2. So you have to make the bat script point to the correct version. Note that after making Jay's change, you may have to pop another command prompt window so that the variables set are unset (the script called h2.bat and sets an H2DB variable.) Thanks again, Jay!
FUDForum. Page generated in 0.19914 seconds
