Aligment in a TableViewer [message #885116] |
Tue, 12 June 2012 09:46  |
Hi all,
I have the following problem with a TableViewer. I have a TableViwer that is displaying a set of properties with their values. Some of these properties has values that are just text and some are better displayed as images. The problem is that the viewer reserve space for the images in all the rows, doesn't matter if there image or not.
| prop1 | val1 |
| prop1 | val2 |
| prop3 | < image > |
but I will like to have:
| prop1 | val1 |
| prop1 | val2 |
| prop3 | < image > |
Any ideas how can I get that alignment?
Thank you very much.
Joaquin Morcate
Re: Aligment in a TableViewer [message #890011 is a reply to message #889797] |
Wed, 20 June 2012 10:51   |
Still I am not able to find a good solution to my problem. If I use a OwnerDrawLabelProvider as Grant suggested yesterday, I get a good rendering of my values (i.e. the text entries are aligned to the left without space for the images). This is the code:
valueColumn.setLabelProvider(new OwnerDrawLabelProvider() {
public void update(ViewerCell cell) {
ReadoutEntry entry = (ReadoutEntry) cell.getElement();
cell.setText(entry.getStringValue());
cell.setImage(entry.getImageValue(Display.getDefault()));
protected void paint(Event event, Object element) {
ReadoutEntry entry = (ReadoutEntry) element;
GC gc = event.gc;
Table table = (Table) event.widget;
int width = table.getColumn(0).getWidth();
if (entry.getImageValue(table) != null) {
gc.drawImage(entry.getImageValue(Display.getDefault()),
width + 2, event.y + 2);
} else {
gc.drawText(entry.getStringValue(), width + 2, event.y + 2,
true);
protected void erase(Event event, Object element) {
event.detail &= ~SWT.FOREGROUND;
protected void measure(Event event, Object element) {
But if I enable the editors they are placed in the space defined by textBounds. This is a snapshot:
The problem, I guess, is that I am not able to modify the image and text bounds in the TableItem's. But I'm really confused now. May be there is a simpler solution or I'm doing something wrong.
Any help?
Joaquin
FUDForum. Page generated in 0.03779 seconds
