Home » Modeling » EMF » [CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal
[CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal [message #883327] Fri, 08 June 2012 05:47 Go to next message
I've been testing the CDO export with Teneo and Hibernate again and got an error:
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.type(CDOServerExporter.java:702)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportFeature(CDOServerExporter.java:582)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportFeature(CDOServerExporter.java:537)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportRevision(CDOServerExporter.java:525)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportRevision(CDOServerExporter.java:1)
	at org.eclipse.emf.cdo.server.CDOServerExporter$2.handleRevision(CDOServerExporter.java:192)
	at org.eclipse.emf.cdo.common.revision.CDORevisionHandler$Filtered.handleRevision(CDORevisionHandler.java:55)
	at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.handleRevisionsByEClass(HibernateStoreAccessor.java:461)
	at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.handleRevisions(HibernateStoreAccessor.java:444)
	at org.eclipse.emf.cdo.internal.server.Repository.handleRevisions(Repository.java:1398)
	at org.eclipse.emf.cdo.server.CDOServerExporter.exportRevisions(CDOServerExporter.java:185)
	at org.eclipse.emf.cdo.server.CDOServerExporter.exportBranch(CDOServerExporter.java:180)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportBranch(CDOServerExporter.java:464)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportBranch(CDOServerExporter.java:1)
	at org.eclipse.emf.cdo.server.CDOServerExporter.exportBranches(CDOServerExporter.java:157)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportBranches(CDOServerExporter.java:447)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportBranches(CDOServerExporter.java:1)
	at org.eclipse.emf.cdo.server.CDOServerExporter.exportAll(CDOServerExporter.java:113)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportAll(CDOServerExporter.java:402)
	at org.eclipse.emf.cdo.server.CDOServerExporter$XML.exportAll(CDOServerExporter.java:1)
	at org.eclipse.emf.cdo.server.CDOServerExporter.exportRepository(CDOServerExporter.java:92)
	at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider.exportXML(CDOCommandProvider.java:208)
	at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider._cdo(CDOCommandProvider.java:104)
	at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:209)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:155)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:140)
	at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:104)
I'm currently using a CDO 4.1 from May 8th.
Re: [CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal [message #885003 is a reply to message #883327] Tue, 12 June 2012 04:53 Go to previous messageGo to next message
Using git master: it seems there is no support for BigDecimals in the exporter/importer.
@Eike
Is it too late for contributions to 4.1?
Re: [CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal [message #885072 is a reply to message #885003] Tue, 12 June 2012 08:11 Go to previous messageGo to next message
There is a bug report which is already fixed in git master:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=382346
Re: [CDO/Teneo/Hibernate] java.lang.IllegalArgumentException: Invalid type: java.math.BigDecimal [message #888536 is a reply to message #885072] Mon, 18 June 2012 04:49 Go to previous message
Tried it with the build from Friday and it works. Thanks for fixing this.
Previous Topic:XML file reading using ecore and java program
Next Topic:[CDO/Dawn] Deadlock on accessing CDOView
Current Time: Sun Aug 31 04:10:47 EDT 2025
Powered by FUDForum. Page generated in 0.05381 seconds
