Home » Modeling » UML2 Tools » Unable to load UML model in stand alone application
Unable to load UML model in stand alone application [message #884601] Mon, 11 June 2012 09:07 Go to next message
Hello everybody,
I am really new to the Eclipse UML 2 project and I am trying to load a UML model in my standalone application. To do so I have created a new java project and I have included the following jars
org.eclipse.emf.common_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore_2.7.0.v20120127-1122.jar
org.eclipse.uml2.common_1.6.0.v201105021727.jar
org.eclipse.uml2.uml_3.2.100.v201108110105.jar
Then I have this code trying to load the UML model from the getting started guide saved under C:/ExtendedPO2.uml
public class Main {
	public static void main(String[] args){
		String location="c:/ExtendedPO2.uml";
		Model m=load(URI.createFileURI(location));
		System.out.println(m.getQualifiedName());
	protected static Model load(URI pathToModel)
		ResourceSet set = new ResourceSetImpl();
		set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
		set.getResourceFactoryRegistry().getExtensionToFactoryMap()
				.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		UMLPackage.eINSTANCE.eClass();
		set.createResource(pathToModel);
		Resource r = null;
		r = set.getResource(pathToModel, true);
		Model m = (Model) EcoreUtil.getObjectByType(r.getContents(),
					UMLPackage.Literals.MODEL);
		return m;
Unfortunately the loaded model is null and I am not able to print the qualified name.
Can someone please help me understanding what's going on?
Thank you for your help
Re: Unable to load UML model in stand alone application [message #885046 is a reply to message #884601] Tue, 12 June 2012 06:45 Go to previous messageGo to next message
HI
It looks like your package registrations are wrong, but since you
haven't provided your ExtendedPO2.uml it's difficult to check.
Juno makes this all much easier by providing
UMLResourcesUtil.init(set);
Ed Willink
On 11/06/2012 14:07, Alfredo Motta wrote:
> Hello everybody,
> public class Main {
> { ResourceSet set = new ResourceSetImpl();
> Resource r = null;
> return m;
> qualified name.
Re: Unable to load UML model in stand alone application [message #885848 is a reply to message #885046] Wed, 13 June 2012 14:06 Go to previous messageGo to next message
Edward Willink wrote on Tue, 12 June 2012 06:45
HI
Thank you, still not clear to me what is the problem ,attached there is the .uml file, hope it helps
Re: Unable to load UML model in stand alone application [message #885851 is a reply to message #885848] Wed, 13 June 2012 14:11 Go to previous messageGo to next message
I finally got fed up with answering this generic question. I looked at
http://wiki.eclipse.org/MDT/UML2/Getting_Started_with_UML2; it has a
major howler in it regarding "save" that makes life very hard for new
users. https://bugs.eclipse.org/bugs/show_bug.cgi?id=382342 raised. Wiki
corrected.
There is an attachment to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=382342 that you may
download to give a working example standalone project.
Ed Willink
>> HI
Re: Unable to load UML model in stand alone application [message #885947 is a reply to message #885851] Wed, 13 June 2012 19:02 Go to previous messageGo to next message
Ok thank you.
I am not sure on how this was related to my loading problem, as you said probably it was a namespace problem. However this is the code that I have now in place together with the sample .uml file. This one works
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
public class Main {
	private URI typesUri = null;
		Model m=new Main().getModel("C:/mylocalpathto/ExtendedPO2.uml");
		System.out.println(m.getName());
	public Model getModel(String pathToModel) {
		typesUri = URI.createFileURI(pathToModel);
		set.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		set.createResource(typesUri);
		Resource r = set.getResource(typesUri, true);
        Model m = (Model) EcoreUtil.getObjectByType(r.getContents(), UMLPackage.Literals.MODEL);
		return m;
and these are the libraries I am using
org.eclipse.emf.mapping.ecore2xml_2.7.0.v20120130-0943.jar
[Updated on: Wed, 13 June 2012 19:03] by Moderator
Re: Unable to load UML model in stand alone application [message #1438639 is a reply to message #885947] Mon, 06 October 2014 05:56 Go to previous message
Alfredo Motta wrote on Wed, 13 June 2012 19:02
Ok thank
thanks for the attachments
Previous Topic:Install UML2 for Kepler
Next Topic:Java code Generation from UML diagrams
Current Time: Sat Jul 26 08:11:49 EDT 2025
Powered by FUDForum. Page generated in 0.04604 seconds
