Home » Archived » BIRT » Problem with Mysql Stored Procedure
Re: Problem with Mysql Stored Procedure [message #884890 is a reply to message #884727] |
Mon, 11 June 2012 23:06   |
Just in case it might help, here is the stored procedure. It is working fine in MySql workbench. It has 2 cursors and a temporary table that is created, filled, queried and then deleted.
-- Routine DDL
-- Note: comments before and after the routine body will not be stored by the server
DELIMITER $$
CREATE DEFINER=`root`@`localhost` PROCEDURE `KPIDebtor`(dtFrom DATE, dtTo DATE)
READS SQL DATA
BEGIN
-- DECLARATIONS:
-- Declare variables used just for cursor and loop control
DECLARE no_more_rows BOOLEAN;
DECLARE loop_cntr INT DEFAULT 0;
DECLARE num_rows INT DEFAULT 0;
-- declare some variables
DECLARE sales DECIMAL(12,2);
DECLARE revenue DECIMAL(12,2);
DECLARE openingBalance DECIMAL(12,2);
DECLARE monthPeriod VARCHAR(20);
-- declare the opening debtor balance into the cursor openBalCur
DECLARE openBalCur CURSOR FOR
SELECT IFNULL(SUM(AccDue),0) AS Sales, IFNULL(SUM(AccPaid),0) AS Inflow
FROM tblPatientAcc
WHERE TxDt < dtFrom;
-- declare the monthly sales and revenue cursor montlyTransCur
DECLARE montlyTransCur CURSOR FOR
SELECT
DATE_FORMAT(TxDt, '%Y-%m-01') AS Yr_month,
SUM(AccDue) AS MonthSales,
SUM(AccPaid) AS MonthRevenue
FROM
tblPatientAcc WHERE TxDt BETWEEN dtFrom AND dtTo
GROUP BY DATE_FORMAT(TxDt, '%Y-%m-01')
ORDER BY EXTRACT(YEAR FROM TxDt),
EXTRACT(MONTH FROM TxDt);
-- Declare 'handlers' for exceptions
DECLARE CONTINUE HANDLER FOR NOT FOUND
SET no_more_rows = TRUE;
-- PROGRAM LOGIC:
SET sales = 0.00;
SET revenue = 0.00;
SET openingBalance = 0.00;
-- create the temporary table
DROP TEMPORARY TABLE IF EXISTS tmp;
CREATE TEMPORARY TABLE tmp
PERIOD DATE,
SALES DECIMAL(12,2) NOT NULL DEFAULT 0.00,
INFLOW DECIMAL(12,2) NOT NULL DEFAULT 0.00,
DEBTOR DECIMAL(12,2) NOT NULL DEFAULT 0.00
-- open the opening balance cursor
OPEN openBalCur;
SELECT FOUND_ROWS() into num_rows;
openBalLoop: LOOP
FETCH openBalCur
INTO sales, revenue;
-- break out of the loop if
-- 1) there were no records, or
-- 2) we've processed them all
IF no_more_rows THEN
CLOSE openBalCur;
LEAVE openBalLoop;
END IF;
SET openingBalance = (sales-revenue);
-- count the number of times looped
SET loop_cntr = loop_cntr + 1;
END LOOP openBalLoop;
-- open the monthly transactions cursor
SET sales = 0.00;
SET revenue = 0.00;
SET num_rows = 0;
SET loop_cntr = 0;
SET no_more_rows = FALSE;
OPEN montlyTransCur;
monthlyTransLoop: LOOP
FETCH montlyTransCur
INTO monthPeriod, sales, revenue;
CLOSE montlyTransCur;
LEAVE monthlyTransLoop;
END IF;
SET openingBalance = openingBalance + (sales-revenue);
INSERT INTO tmp (PERIOD, SALES, INFLOW, DEBTOR) VALUES (monthPeriod, sales, revenue, openingBalance);
END LOOP monthlyTransLoop;
SELECT * FROM tmp;
END
Re: Problem with Mysql Stored Procedure [message #885160 is a reply to message #884890] |
Tue, 12 June 2012 10:44   |
Any chance you could alter the sp to return 1 row of dummy data?
Jason
> -- Routine DDL
> by the server
> DELIMITER $$
> dtTo DATE)
> READS SQL DATA
> BEGIN
> -- DECLARATIONS:
> FROM tblPatientAcc WHERE TxDt < dtFrom;
> SELECT DATE_FORMAT(TxDt, '%Y-%m-01') AS Yr_month,
> SUM(AccDue) AS MonthSales, SUM(AccPaid) AS MonthRevenue FROM
> ORDER BY EXTRACT(YEAR FROM TxDt), EXTRACT(MONTH FROM TxDt);
> -- PROGRAM LOGIC:
> SET sales = 0.00;
> SET revenue = 0.00;
> PERIOD DATE,
> OPEN openBalCur;
> openBalLoop: LOOP
> FETCH openBalCur
> CLOSE openBalCur;
> LEAVE openBalLoop;
> END IF;
> -- open the monthly transactions cursor SET sales = 0.00;
> SET revenue = 0.00;
> SET num_rows = 0;
> SET loop_cntr = 0;
> END IF;
> SELECT * FROM tmp;
> END
Re: Problem with Mysql Stored Procedure [message #885454 is a reply to message #885160] |
Tue, 12 June 2012 23:10  |
Dear Jason,
I found the problem.
In the store procedure declaration, i missed the IN setting for the parameter
CREATE DEFINER=`root`@`localhost` PROCEDURE `KPIDebtor`(IN dtFrom DATE, IN dtTo DATE)
It is working fine now..
Thanks a lot!
Karvesh
Current Time: Sat Jul 26 09:03:46 EDT 2025
Powered by FUDForum. Page generated in 0.07985 seconds
