Home » Archived » BIRT » Get Logged in user(Is there a way to get the currently logged in user from Tomcat?)
Get Logged in user [message #883313] Fri, 08 June 2012 05:16 Go to next message
We're running Tomcat 3.7.1. on Tomcat 5.5.
Tomcat 5.5 is running on Linux, the clients are Windows clients in an AD Domain.
What would be the best way to get the username of the user requesting the report? I should be able to get it from Tomcat using this method?
Unfortunately, i'm unable to post links, but googling for this gives the post i'm talking about:
20140-accessing-servlet-context-in-the-report
I've been trying to get this working, but i can't figure it out entirely.
Re: Get Logged in user [message #883501 is a reply to message #883313] Fri, 08 June 2012 13:12 Go to previous messageGo to next message
You can get session variables in a report expression or script like:
var sess = reportContext.getHttpServletRequest().getSession();
var myvar = sess.getAttribute("youvariable");
I am not sure how you would get the user into session.
Jason
> Domain. What would be the best way to get the username of the user
> method?
Re: Get Logged in user [message #884635 is a reply to message #883501] Mon, 11 June 2012 10:25 Go to previous messageGo to next message
Thanks for your reply Jason. Further investigation based on your response made me find the solution Wink
This describes is (cp, because i can't post urls)
A. Application server configuration (e.g. Tomcat)
Add the jcifs-x.jar to the '<BIRT_VIEWER_HOME>\WEB-INF\lib' directory
Configure the BIRT-viewer application to authenticate via NTLM by adding the NTLM-filter to the web.xml:
<filter>
<filter-name>NtlmHttpFilter</filter-name>
<filter-class>jcifs.http.NtlmHttpFilter</filter-class>
<init-param>
<param-name>jcifs.smb.client.domain</param-name>
<param-value>your.domain</param-value>
</init-param>
<init-param>
<param-name>jcifs.netbios.wins</param-name>
<param-value>domain-controller.your.domain</param-value>
</init-param>
<init-param>
<param-name>jcifs.util.loglevel</param-name>
<param-value>2</param-value>
</init-param>
</filter>
<filter-mapping>
<servlet-name>ViewerServlet</servlet-name>
</filter-mapping>
<filter-mapping>
<servlet-name>EngineServlet</servlet-name>
</filter-mapping>
</filter>
Restart your Tomcat application server
Test if your BIRT-application is secured:
--> You should now be prompted for your username & password
NTLM Authentication
B. BIRT Report design
Once authenticated, you can check authorization via your Report using the BIRT Rhino Javascript.
On your dataset you can add a parameter using a default scripted value like:
var myLoginName = null;
var request = reportContext.getHttpServletRequest();
if (request!=null) {
if (request.getRemoteUser()!=null) {
myLoginName = request.getRemoteUser();
myLoginName;
BIRT authentication: scripted parameter
This parameter you can use in your query / stored procedure to filter data matching the logged-in username.
Download report-authentication example
When you run this example report on your NTLM-enabled application server (see A.), you get prompted for username & password and will see a list of products (our example query simply checks if the username is not null)
optional: you can also embed this into a global getLoggedInUsername()-function, so you can simply call getLoggedInUsername() to get the logged-in user (*).
function getLoggedInUsername() {
return myLoginName;
Re: Get Logged in user [message #884711 is a reply to message #884635] Mon, 11 June 2012 12:44 Go to previous messageGo to next message
Thanks for posting your solution.
Jason
> response made me find the solution ;)
> <filter>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </filter>
> <filter-mapping>
> </filter-mapping>
> <filter-mapping>
> </filter-mapping>
> </filter>
> Restart your Tomcat application server Test if your BIRT-application is
> secured:
> NTLM Authentication
> like:
> myLoginName;
> return myLoginName;
Re: Get Logged in user [message #1387328 is a reply to message #884711] Tue, 24 June 2014 20:33 Go to previous message
If we are using form based authentication and not NTLM, what would be the script for retrieving the username etc?
Arif
Previous Topic:Programmatically get list of report parameters
Next Topic:Birt Migration 2.2.2 to 3.7.2
Current Time: Wed Jul 23 13:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.07535 seconds
