Home » Modeling » TMF (Xtext) » Error: Duplicate VarDecl 'i' (scoping problem)
Error: Duplicate VarDecl 'i' (scoping problem) [message #884609] Mon, 11 June 2012 09:23 Go to next message
Hi, i need some support to solve my problem (don't understand how to get it working)
I get an error message for the 'FOR' statements in following simple example:
PROCEDURE test_1
  DIM a : BYTE
  LET a = 1
  FOR i = 1 TO 5              // <-------- Error: Duplicate VarDecl 'i'
    LET a = a + i
  NEXT
  FOR i = 5 TO 1 STEP -1      // <-------- Error: Duplicate VarDecl 'i'
    LET a = a * (i * i)
  NEXT
END
Corresponded xText definition:
Programm: procs+=Procedure*;
enum Type: BYTE | SINGLE | INTEGER;
VarDecl: name=ID (':' type=Type)?;
// Expressions
Primary returns Expression:
  {SubExpression} '(' expr=Expression ')'
  | {Literal} val=INT
  | {Reference} varRef=[VarDecl]
Term returns Expression: sign=('+'|'-')?	expr=Primary;
Multiplication returns Expression: left=Term (op=('*' | '/') right=Multiplication)?;
Expression returns Expression: left=Multiplication (op=('+' | '-') right=Expression)?;
// Statements
Statement returns Statement:
  {DimStmt} 'DIM' var=VarDecl
  | {LetStmt} 'LET' ref=[VarDecl] '=' expr=Expression
  | {ForStmt} 'FOR' var=VarDecl '=' from=Expression 'TO' to=Expression ('STEP' step=Expression)? stmts+=Statement* 'NEXT'
Procedure:
  'PROCEDURE' name=ID ('(' parameters+=VarDecl* ')')?
  stmts+=Statement*
  'END'
MWE2:
fragment = validation.JavaValidatorFragment {
  //    composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
        composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
[Updated on: Mon, 11 June 2012 09:43] by Moderator
Re: Error: Duplicate VarDecl 'i' (scoping problem) [message #884623 is a reply to message #884609] Mon, 11 June 2012 09:54 Go to previous messageGo to next message
the QualifiedName is used to reference elements. The variable i is
contained in ForStmt and then in Procedure. ForStmt has no name so the
QualifiedName for i is test_1.i for both variables.
You need to specify a custom QualifiedNameProviderImplementation where
you could give the ForStmt a syntectic name so that i is unique in the
meaning of the QualifiedName. Something like test_1.statement0.i
Holger
Am 11.06.12 15:23, schrieb Cash Ko:
> it working)
> I get an error message for the 'FOR' statements in the following simple
> example:
> PROCEDURE test_1
> DIM a : BYTE
> LET a = 1
> LET a = a + i
> NEXT
> LET a = a * (i * i)
> NEXT
> END
> // Expressions
> {SubExpression} '(' expr=Expression ')' | {Literal} val=INT
> Term returns Expression: (sign='+'|'-')? expr=Primary;
> right=Expression)?;
> // Statements
> ('STEP' step=Expression)? stmts+=Statement* 'NEXT' ;
> Procedure:
> 'PROCEDURE' name=ID ('(' parameters+=VarDecl ')')?
> stmts+=Statement*
> 'END'
> MWE2:
Re: Error: Duplicate VarDecl 'i' (scoping problem) [message #884739 is a reply to message #884623] Mon, 11 June 2012 13:57 Go to previous messageGo to next message
Thank you Holger for quick response to my question.
Would someone please check if the following implementation can be an acceptable solution to this problem (if it does not have any hidden side effects) -- Thank You.
package org.xtext.example.mydsl;
import org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider;
import org.eclipse.xtext.naming.QualifiedName;
import org.xtext.example.mydsl.myDsl.ForStmt;
public class MyDslQNP extends DefaultDeclarativeQualifiedNameProvider {
	QualifiedName qualifiedName(ForStmt s) {
		String stmtName = "STMT:" + Integer.toString(s.hashCode());
		return QualifiedName.create(stmtName);
[Updated on: Tue, 12 June 2012 02:23] by Moderator
Re: Error: Duplicate VarDecl 'i' (scoping problem) [message #884965 is a reply to message #884739] Tue, 12 June 2012 03:25 Go to previous message
Does it work for you? You should include the name of the father of the
statement to make it unique. I would not use the hashCode. I would use
the index of the Statement in the list stmts of the procedure.
Am 11.06.12 19:57, schrieb Cash Ko:
> Thank you Holger for quick respond to my question.
> Would someone check please if the following implementation can be an
Previous Topic:Problems with referencing ecore's
Next Topic:[Xcore] derived feature and notification
Current Time: Wed Jul 23 10:45:55 EDT 2025
Powered by FUDForum. Page generated in 0.34167 seconds
