Home » Modeling » EMF » [xcore] Two metamodels where one refers to the other
[xcore] Two metamodels where one refers to the other [message #884591] Mon, 11 June 2012 08:31 Go to next message
This is the current experiment:
* Create two metamodels with xcore [MA = Metamodel A, MB = Metamodel B].
*?? Use classes from MA in MB as types by using the XCore Datatype
mechanism. Is this the proper way to use A in B??
import metamodelA.Thing
class Something {
Thingy thingy
type Thingy wraps Thing
-H
Re: [xcore] Two metamodels where one refers to the other [message #884597 is a reply to message #884591] Mon, 11 June 2012 08:49 Go to previous messageGo to next message
Hugo,
Comments below.
On 11/06/2012 2:31 PM, Hugo Garcia wrote:
> Hi
> class Something {
> Thingy thingy
What's Thing? A data type from the other model? You can use data types
Thing directly for attributes, i.e., Thing thingy.
> -H
Re: [xcore] Two metamodels where one refers to the other [message #884633 is a reply to message #884597] Mon, 11 June 2012 10:20 Go to previous messageGo to next message
On 06/11/2012 02:49 PM, Ed Merks wrote:
> Hugo,
> Comments below.
>> Hi
>> class Something {
>> Thingy thingy
>> -H
Not a datatype.
Seems that the solution is using refers like this:
in one xcore project:
package be.kul.thing
class Thing {
String name
and in the other xcore project that has a dependcy in the manifest to
the first project:
package be.kul.something
import be.kul.thing.Thing
class Something {
String name
refers Thing thing
right?
-H
Re: [xcore] Two metamodels where one refers to the other [message #884806 is a reply to message #884633] Mon, 11 June 2012 17:41 Go to previous message
Hugo,
Yes, references need to use the keyword "refers", "contains", or
"container" and yes, you need to use plugin-in dependencies to be able
to refer to things in other Xcore resources.
>> Hugo,
>> Comments below.
>>> Hi
>>> B].
>>> class Something {
>>> Thingy thingy
>>> -H
> Not a datatype.
> class Thing {
> String name
> the first project:
> class Something {
> String name
> refers Thing thing
> right?
> -H
Previous Topic:Implementation of instance-of references
Next Topic:[Xcore] Problems using opposite
Current Time: Fri Jul 25 19:32:45 EDT 2025
Powered by FUDForum. Page generated in 0.06113 seconds
