Home » Eclipse Projects » Remote Application Platform (RAP) » RAP in Tomcat strange Problem with IE
RAP in Tomcat strange Problem with IE [message #88018] Fri, 16 May 2008 09:04 Go to next message
i have debuged the problem a litte bit. When I use the
-Dorg.eclipse.rwt.clientLibraryVariant=DEBUG flag which uses the
debug client lib the error doesn't occur. It looks like that there
is a problem with the non debug version of the js library.
Again, this problem only occures in a Tomcat Servlet Container.
Thomas
Thomas Kühne schrieb:
> I have a problem running RAP in a Tomcat Servlet container since
> move to M4. I have a composite which contains a tab control
> with 3 Tabs. When I click on the last (right) tab the following
> error occurs:
> Could not evaluate javascript response:
> Ungültiger Eigenschaftswert.
> org.eclipse.swt.EventUtil.suspendEventHandling();var req =
> org.eclipse.swt.Request.getInstance();req.setRequestCounter( "12" );var
> wm = org.eclipse.swt.WidgetManager.getInstance();var w =
> wm.findWidgetById( "w343" );w.setSelected( false );var w =
> wm.findWidgetById( "w344" );w.setSelected( true );var w =
> wm.findWidgetById( "w317" );w.setVisibility( false );var w =
> wm.findWidgetById( "w325" );w.setSpace( 3, 769, 32, 300
> );w.setVisibility( true );var w = wm.findWidgetById( "w324"
> );w.setSpace( 0, 769, 0, 300 );var w = wm.findWidgetById( "w333"
> );w.setSpace( 0, 383, 0, 300 );var w = wm.findWidgetById( "w318"
> );w.setSpace( 0, 383, 0, 300 );var w = wm.findWidgetById( "w320"
> );w.setSpace( 6, 342, 47, 26 );var w = wm.findWidgetById( "w319"
> );w.setSpace( 353, 24, 47, 26 );var w = wm.findWidgetById( "w364"
> );w.setSpace( 6, 371, 79, 215 );var w = wm.findWidgetById( "w365"
> );w.setWidth( 341 );var w = wm.findWidgetById( "w334" );w.setSpace( 386,
> 383, 0, 300 );var w = wm.findWidgetById( "w321" );w.setSpace( 0, 383, 0,
> 300 );var w = wm.findWidgetById( "w323" );w.setSpace( 6, 342, 47, 26
> );var w = wm.findWidgetById( "w322" );w.setSpace( 353, 24, 47, 26 );var
> w = wm.findWidgetById( "w369" );w.setSpace( 6, 371, 79, 215 );var w =
> wm.findWidgetById( "w370" );w.setWidth( 341 );var w = wm.newWidget(
> "w371", "w324", true, null, 'org.eclipse.swt.widgets.Sash'
> );w.setOrientation( qx.constant.Layout.ORIENTATION_VERTICAL
> );w.setSpace( 383, 3, 0, 300 );w.setZIndex( 298
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
> This happens only on IE with RAP deployed in Tomcat. When I run the
> RAP Application on my Workstation and connect with the same IE this
> error does not appear ? It also doesn't appear when I use Mozilla in
> both cases.
> Any ideas ?
> Regards,
> Thomas
Re: RAP in Tomcat strange Problem with IE [message #88313 is a reply to message #88018] Mon, 19 May 2008 05:54 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
we are currently discussing what can cause this problem, but we don't
have a clue yet. Feel free to file a bug so the progress on this gets
traceable.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Thomas Kühne [mailto:tkuehne@todo.de]
Bereitgestellt: Freitag, 16. Mai 2008 15:05
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: RAP in Tomcat strange Problem with IE
Betreff: RAP in Tomcat strange Problem with IE
-Dorg.eclipse.rwt.clientLibraryVariant=DEBUG flag which uses the debug
client lib the error doesn't occur. It looks like that there is a
Thomas
> I have a problem running RAP in a Tomcat Servlet container since >
move to M4. I have a composite which contains a tab control > with 3
Tabs. When I click on the last (right) tab the following > error
occurs:
> org.eclipse.swt.EventUtil.suspendEventHandling();var req = >
> wm = org.eclipse.swt.WidgetManager.getInstance();var w = >
wm.findWidgetById( "w343" );w.setSelected( false );var w = >
wm.findWidgetById( "w344" );w.setSelected( true );var w = >
wm.findWidgetById( "w317" );w.setVisibility( false );var w = >
wm.findWidgetById( "w325" );w.setSpace( 3, 769, 32, 300 >
386, > 383, 0, 300 );var w = wm.findWidgetById( "w321" );w.setSpace( 0,
383, 0, > 300 );var w = wm.findWidgetById( "w323" );w.setSpace( 6, 342,
47, 26 > );var w = wm.findWidgetById( "w322" );w.setSpace( 353, 24, 47,
26 );var > w = wm.findWidgetById( "w369" );w.setSpace( 6, 371, 79, 215
);var w = > wm.findWidgetById( "w370" );w.setWidth( 341 );var w =
wm.newWidget( > "w371", "w324", true, null,
> );w.setSpace( 383, 3, 0, 300 );w.setZIndex( 298 >
EventHandling();
> RAP Application on my Workstation and connect with the same IE this >
error does not appear ? It also doesn't appear when I use Mozilla in >
both cases.
> Any ideas ?
> Regards,
> Thomas
Re: RAP in Tomcat strange Problem with IE [message #88417 is a reply to message #88313] Mon, 19 May 2008 10:04 Go to previous message
thank you. I filed a bug #232799. Let me know if you
need more info's.
Thomas
Frank Appel schrieb:
> traceable.
> Ciao
> Frank
> Regards,
> Thomas
> > Hi,
> occurs:
> EventHandling();
> both cases.
> > Any ideas ?
> > Regards,
> > Thomas
Previous Topic:Toolbar background color in ScrolledForm
Next Topic:Multi-Line Tooltip
Current Time: Sun Jul 27 06:53:17 EDT 2025
Powered by FUDForum. Page generated in 0.03714 seconds
