[TEXO] Enum documentation [message #883308] |
Fri, 08 June 2012 05:03  |
Hi Martin,
How can I ensure documentation is added to the generated Enum please?
Example XSD section:
<xs:simpleType name="TelephoneType">
<xs:restriction base="xs:string">
<xs:enumeration value="TETY1">
<xs:annotation>
<xs:documentation>Mobile</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="TETY2">
<xs:annotation>
<xs:documentation>LandLine</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
</xs:simpleType>
The .ecore correctly extracts the required documentation:
<eClassifiers xsi:type="ecore:EEnum" name="TelephoneType">
<eAnnotations source="org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="TelephoneType"/>
</eAnnotations>
<eLiterals name="TETY1">
<eAnnotations source="org/emf/2002/GenModel">
<details key="documentation" value="Mobile"/>
</eAnnotations>
</eLiterals>
<eLiterals name="TETY2" value="1">
<details key="documentation" value="LandLine"/>
</eAnnotations>
</eLiterals>
</eClassifiers>
In enum.xpt I cannot though determine how to access the value. e.g. Mobile or LandLine
The key section of my enum.xpt is:
«FOREACH eEnum.ELiterals AS e SEPARATOR ","-»
«LET ((EEnumLiteral)e) AS el-»
* The enum: «toUpperCase(el.literal)»
* <!-- begin-user-doc -->
Trying to add Mobile / Landline here
* <!-- end-user-doc -->
* @generated
«modelController.getJavaAnnotations(el, "field")-»
«ENDLET-»
«ENDFOREACH-»;
Gary
[Updated on: Fri, 08 June 2012 05:24] by Moderator
Re: Enum documentation [message #883359 is a reply to message #883308] |
Fri, 08 June 2012 07:07   |
Hi Gary,
Can you try something like this:
«IF this.documentation != null-»
* <!-- begin-model-doc -->
* «this.documentation»
* <!-- end-model-doc -->
«ENDIF-»
gr. Martin
On 06/08/2012 11:03 AM, Gary Godfrey wrote:
> Hi Martin,
> <xs:annotation>
> </xs:annotation>
> </xs:enumeration>
> <xs:annotation>
> </xs:annotation>
> </xs:enumeration>
> </xs:restriction>
> </xs:simpleType>
> </eAnnotations>
> </eAnnotations>
> </eLiterals>
> </eAnnotations>
> </eLiterals>
> </eClassifiers>
> * @generated
> «ENDLET-»
> «ENDFOREACH-»;
> Regards,
> Gary
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Enum documentation [message #883450 is a reply to message #883431] |
Fri, 08 June 2012 11:02   |
Okay, let me test it locally, I will do a new build later today which then also should solve this.
gr. Martin
On 06/08/2012 04:10 PM, Gary Godfrey wrote:
> Hi Martin,
> Tried this but didn't work:
> «ENDIF-»
> * @generated
> «ENDLET-»
> «ENDFOREACH-»;
> The corresponding Enum prints:
> public enum TelephoneType
> * The enum: TETY1 <!-- begin-user-doc --> TETY1 <!-- end-user-doc --> <!--
> * begin-model-doc -->
> * * @generated
> TETY1
> * The enum: TETY2 <!-- begin-user-doc --> TETY2 <!-- end-user-doc -->
> * * @generated
> TETY2
The Netherlands
Re: Enum documentation [message #883543 is a reply to message #883431] |
Fri, 08 June 2012 14:43  |
Hi Gary,
I published a new build which should work, to get the documentation you have to do this:
«IF getDocumentation(el) != null-»
* «getDocumentation(el)»
«ENDIF-»
gr. Martin
> Hi Martin,
> «ENDIF-»
> * @generated
> «ENDLET-»
> «ENDFOREACH-»;
> * * @generated
> TETY1
> * * @generated
> TETY2
The Netherlands
FUDForum. Page generated in 0.03699 seconds
