Home » Language IDEs » C / C++ IDE (CDT) » SSE intrinsics and intellesense not working(intellisense autocomplete c++)
SSE intrinsics and intellesense not working [message #883136] Thu, 07 June 2012 18:30 Go to next message
Hello all,
I have a question regarding the eclipse c++ toolkit. it seems to be working great but i'm having some issues with the autocomplete/intellisense technology. as a simple example im trying to use sse intrisnics in the simplest way
#include "xmmintrin.h"
__m128 func(void)
__m128 m;
m = _mm_setzero_ps();
return m;
this example i added the -msse2 compiler flag and this compiles perfectly, however the intellisense/autocomplete still doens't recgonize the types or functions in the header.
In an attempt to fix this i manually added the __SSE__ and __MMX__ includes to the c++ preprocessor. this had the effect of changing the highlighing in the #if/#else paths of the header xmmintrin.h to the correct branches. ie it highlights the choices the preprocessor is currently taking. i figured this would clear up the issue because it seemed to be modifying how the intellisense/autocomplete was viewing the header files(ie highlighting the correct path instead of the incorrect one)
still though, it's not working. any suggestions? it compiles fine and i know i can just ignore the red squigglies but i really want to learn to set it up properly for the type of work i'll be doing with it in the future.
Thanks for all your time!
Tim
Re: SSE intrinsics and intellesense not working [message #884950 is a reply to message #883136] Tue, 12 June 2012 02:52 Go to previous message
Add the -msse2 compiler flag to the discovery options http://help.eclipse.org/indigo/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_build_discovery.htm and then rebuild your index (Project Properties->Index..)
Previous Topic:project work space Demo/Tutorial
Next Topic:Excluding a directory but re-including certain files?
Current Time: Sat Jul 26 11:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.04574 seconds
