BIRT Preview Report [message #882944] |
Thu, 07 June 2012 10:03  |
I have the following sql which works when previewing from the edit data set:
SELECT A.XREF_OIMS_SID_NO,
D.OIMS_NAME,
E.OFFT_PAR_ELIG_DATE,
E.OFFT_MAX_EXP_DATE,
DATE(F.WTSK_TME_CMPLTD) CS_SMRY_CMPLTD_DTE,
(CASE
WHEN (B.CPL_RVW_STATUS = 'x' AND
B.CPL_RVW_STS_DATE > E.OFFT_PAR_ELIG_DATE)
THEN B.CPL_RVW_STS_DATE
E.OFFT_PAR_ELIG_DATE > B.CPL_RVW_STS_DATE)
THEN E.OFFT_PAR_ELIG_DATE
ELSE
END) DOCKET_DATE
FROM TPRELEASE_XREF A,
TPCASEPOOL B,
TPOFFENDER_STATUS C,
TAMASTER D,
TAOFFTIME E,
TPWF_TASK F
WHERE XREF_PRIMARY = x
AND A.XREF_CPL_ID = B.CPL_ID
AND A.XREF_ID = B.CPL_XREF_ID
AND B.CPL_OIMS_PREL_STS = 'A'
AND A.XREF_OIMS_SID_NO = C.OSTS_SID_NO
AND C.OSTS_STATUS = 102
AND A.XREF_OIMS_SID_NO = D.OIMS_SID_NO
AND A.XREF_OIMS_SETUP_DT = D.OIMS_SETUP_DTE
AND A.XREF_OIMS_SID_NO = E.OFFT_SID_NO
AND A.XREF_OIMS_SID_NO = F.WTSK_SID_NO
AND A.XREF_ID = F.WTSK_XREF_ID
AND A.XREF_CPL_ID = F.WTSK_CPL_ID
AND (
B.CPL_RVW_STS_DATE > E.OFFT_PAR_ELIG_DATE AND
DATE(F.WTSK_TME_CMPLTD) + xx DAYS > B.CPL_RVW_STS_DATE
) OR
E.OFFT_PAR_ELIG_DATE > B.CPL_RVW_STS_DATE AND
DATE(F.WTSK_TME_CMPLTD) + xx DAYS > E.OFFT_PAR_ELIG_DATE
) OR
B.CPL_RVW_STATUS <> 'N' AND
AND F.WTSK_TASK_CODE = xI'
AND F.WTSK_STATUS = 'x'
AND F.WTSK_UPDATE_DATE =
SELECT MAX(WTSK_UPDATE_DATE)
FROM TPWF_TASK G
WHERE G.WTSK_SID_NO = A.XREF_OIMS_SID_NO
AND G.WTSK_XREF_ID = A.XREF_ID
AND G.WTSK_CPL_ID = A.XREF_CPL_ID
AND G.WTSK_TASK_CODE = 'x'
AND G.WTSK_STATUS = 'x'
ORDER BY XREF_OIMS_SID_NO
WITH UR
I am getting the following error when trying to preview the report:
Table (id = 128):
+ Column binding "WTSK_TME_CMPLTD" has referred to a data set column "WTSK_TME_CMPLTD" which does not exist. (Element ID:128)
data.engine.ColumnBindingReferToInexistColumn ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Column binding "WTSK_TME_CMPLTD" has referred to a data set column "WTSK_TME_CMPLTD" which does not exist. (Element ID:128)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
It doesn't like DATE(F.WTSK_TME_CMPLTD) CS_SMRY_CMPLTD_DTE. CS_SMRY_CMPLTD_DTE is being displayed as a column under the data set. I dragged CS_SMRY_CMPLTD_DTE to my table column and tried to preview it.
How do I get BIRT to recognize this column?
Thanks.
Re: BIRT Preview Report [message #883123 is a reply to message #882944] |
Thu, 07 June 2012 17:54   |
If you drag the whole data set to the canvas, which creates the table,
does it work?
Jason
> set:
> D.OIMS_NAME,
> (CASE
> B.CPL_RVW_STS_DATE > E.OFFT_PAR_ELIG_DATE) THEN B.CPL_RVW_STS_DATE
> E.OFFT_PAR_ELIG_DATE > B.CPL_RVW_STS_DATE) THEN E.OFFT_PAR_ELIG_DATE
> ELSE
> END) DOCKET_DATE
> TPCASEPOOL B,
> TAMASTER D,
> TAOFFTIME E,
> TPWF_TASK F
> AND (
> ) OR
> ) OR
> DATE(F.WTSK_TME_CMPLTD) + xx DAYS > E.OFFT_PAR_ELIG_DATE )
> AND F.WTSK_UPDATE_DATE = (
> FROM TPWF_TASK G
> WITH UR
> Table (id = 128): + Column binding "WTSK_TME_CMPLTD" has referred to a
> at
> Thanks.
FUDForum. Page generated in 0.25640 seconds
