Undo/Redo Buttons stay disabled [message #882604] |
Wed, 06 June 2012 16:42  |
Hey,
so I got the issue on my previous post fixed and managed to put Commands via EditPolicies on the CommandStack and execute them. It all works fine and I'm even to determine the dirty state of the stack to be able to save the model to a file.
My problem now is that I can't click on undo/redo, because it stays disabled after model changes. I already made an ActionBarContributor like this and set it in the plugin.xml:
public class GameModelerActionBarContributor extends ActionBarContributor {
protected void buildActions() {
addRetargetAction(new UndoRetargetAction());
addRetargetAction(new RedoRetargetAction());
protected void declareGlobalActionKeys() {
// TODO Auto-generated method stub
public void contributeToToolBar(IToolBarManager toolBarManager){
toolBarManager.add(getAction(ActionFactory.UNDO.getId()));
toolBarManager.add(getAction(ActionFactory.REDO.getId()));
Did I miss something? Where do I have to tell Eclipse that there's something to undo?
Christoph
Re: Undo/Redo Buttons stay disabled [message #882615 is a reply to message #882604] |
Wed, 06 June 2012 17:09   |
from what you describe a cannot precisely determine the underlying cause, so let me clarify some things and point you to some pitfalls you should check:
1) The EditPolicies are not responsible for executing command on the command stack. They only have the responsibility to return commands in oder to respond to request (see getCommand(Request)). The commands returned by the edit policies are chained together by their host edit part and returned in its getCommand(Request) method respectively. This method gets called by either the currently active tool, or by a selected action, which is responsible of finally executing the returned compound command on the stack. In order to get undo/redo working, the compound command returned by your edit part has to be undoable (isUndoable() has to return true), which is the case if all chained commands returned by its edit policies are undoable.
2) The undo and redo actions are not updated upon model changes, but upon changes of the command stack (they are referred to as stack actions). Besides the action bar contributor with the retarget actions, the mechanism for undo/redo requires that undo and redo actions are registered in the action registry of your editor and that these actions are updated by means of a CommandStackChangeListener whenever the stack changes. If your editor inherits from GraphicalEditor this should be the case. It registeres the action in the action registry in its initializeActionRegistry() method, maintains them in the list of stack actions, and updates them from within commandStackChanged(EventObject); the editor registered itself as CommandStackListener in its init(IEditorSite, IEditorInput).
Hope that clears things up a bit....
Alexander
FUDForum. Page generated in 0.04585 seconds
