Home » Modeling » TMF (Xtext) » How to support implicit imports?
How to support implicit imports? [message #882935] Thu, 07 June 2012 09:52 Go to next message
Would appreciate pointers on how to provide implicit imports. For example, I can currently write:
Domain Banking {
	Datatype Identifier {}
	Datatype Integer {}
Subsystem Portfolio of domain Banking {
	import Banking.*
	Class Account {
		number: Identifier {I}
		balance: Integer
        //..etc.
I'd like to remove the need for the explicit 'import' statement and have it inferred automatically from the Subsystem declaration.
I'm thinking the answer might be a custom scope provider - possibly subtyping ImportedNamespaceAwareLocalScopeProvider? However that doesn't look trivial on the face of it so would appreciate any pointers before I disappear down a dead end.
Thanks.
Re: How to support implicit imports? [message #882946 is a reply to message #882935] Thu, 07 June 2012 10:04 Go to previous messageGo to next message
have a look at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getImportedNamespaceResolvers(EObject, boolean)
~Christian
[Updated on: Thu, 07 June 2012 10:05] by Moderator
Re: How to support implicit imports? [message #883072 is a reply to message #882935] Thu, 07 June 2012 15:45 Go to previous message
If your imports depend on a context object, you have to override
ImportedNamespaceScopeProvider.internalGetImportedNamespaceResolvers(EObject,
boolean)
and add your imports as an ImportNormalizer. The method
createImportedNamespaceResolver(String, boolean) helps you create such
an object. The XtendImportedNamespaceScopeProvider does something similar.
If they are fixed (such as java.lang.* in Java), the hook is
ImportedNamespaceScopeProvider.getImplicitImports(boolean). For an
example, have a look at the XbaseImportedNamespaceScopeProvider.
Don't forget to bind your subclass of the
ImportedNamespaceAwareScopeProviderin the runtime module of your language.
Am 07.06.12 15:52, schrieb Scott Finnie:
> Domain Banking {
> Datatype Integer {}
> import Banking.*
> Class Account {
> balance: Integer
> //..etc.
> Thanks.
Previous Topic:Problem with XtextLinkingDiagnostic
Next Topic:Scoping docs
Current Time: Sun Jul 27 07:59:17 EDT 2025
Powered by FUDForum. Page generated in 0.02794 seconds
