Home » Modeling » OCL » OCL constraint using Ecore classifiers - Unknow type exception
OCL constraint using Ecore classifiers - Unknow type exception [message #882818] Thu, 07 June 2012 05:07 Go to next message
I'm developing an Ecore model with some invariants defined in OCL, using the OCLinEcore editor. In my model, some elements have references to EClassifier; in some OCL constraints, I need to check if the EClassifier referred to is an EDataType or an EClass. Here is, in OCLinEcore, a model similar to the one I have:
import ecore : '<namespace_ecore>/Ecore#/';
package Foo : foo = 'some_namespace'
  class EndPoint
    attribute name : String[1];
    property type : ecore::EClassifier[1];
  class Coupling
    invariant Compatibility:
      (destination.type.oclIsKindOf(ecore::EDataType) and source.type = destination.type) or
      let destinationClass : ecore::EClass = destination.type.oclAsType(ecore::EClass) in
      destinationClass.isSuperTypeOf(source.type.oclAsType(ecore::EClass));
    property source : EndPoint[1];
    property destination : EndPoint[1];
However, when I try to validate a dynamic instance of my model, an exception occur with the following message:
An exception occured while delegating evaluation of the 'Compatibility' constraint on 'Coupling': Unknow type ([ecore, EDataType])
When I try the expression in the OCL interactive console, I obtain the correct result. Am I doing something wrong when defining my invariant? How can I write an invariant using Ecore types?
[Updated on: Thu, 07 June 2012 05:08] by Moderator
Re: OCL constraint using Ecore classifiers - Unknow type exception [message #882849 is a reply to message #882818] Thu, 07 June 2012 06:05 Go to previous messageGo to next message
Naked OCL does not support the binding of ecore to something useful, so
the oclAsType(ecore::EClass) has an unresolved reference since each
ecxpression is an independent snippet in the ECore file.
The Juno release therefore adds an extension whereby a package qualifier
may be a URI, so that if you saw the above serialized it might be
oclAsType(_'http://www.eclipse.org/emf/2002/Ecore'::ecore::EClass).
The Juno release also adds flexibility as to whether you use the new
Pivot-binding with this extended functionality. In the
Window->Preferences->OCL page make sure that the selected executor for
the default delegate is http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot.
HTH
Ed Willink
On 07/06/2012 10:07, Luc Touraille wrote:
> class EndPoint
> class Coupling
> EDataType])
Re: OCL constraint using Ecore classifiers - Unknow type exception [message #882979 is a reply to message #882818] Thu, 07 June 2012 11:16 Go to previous message
Ok, thank you very much for the swift reply!
Luc
[Updated on: Tue, 12 June 2012 05:14] by Moderator
Previous Topic:[Announce] Eclipse OCL 4.0.0 (Juno) RC3 is now available
Next Topic:[Announce] Eclipse OCL 4.0.0 (Juno) RC4 is now available
Current Time: Sat Jul 26 23:32:00 EDT 2025
Powered by FUDForum. Page generated in 0.07087 seconds
