Home » Eclipse Projects » Eclipse Scout » failed to load data(Impossible to do getCompanyTableData)
failed to load data [message #882797] Thu, 07 June 2012 04:15 Go to next message
Hi, I tried to make the minicrm tutorial but I have a problem with getCompanyTableData when I launch the client :
org.eclipse.scout.rt.client.services.common.exceptionhandler.internal.InternalClientExceptionHandlerService.differentiatedLog(InternalClientExceptionHandlerService.java:112) ProcessingException: ProcessingStatus[ERROR code=0 Calling IStandardOutlineService.getCompanyTableData() / Erreur d'emploi]
!STACK 0
ProcessingException[ProcessingStatus[ERROR code=0 Calling IStandardOutlineService.getCompanyTableData() / Erreur d'emploi]]
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:159)
at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:184)
at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:123)
at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:43)
at $Proxy9.getCompanyTableData(Unknown Source)
at org.eclipse.minicrm.client.ui.desktop.outlines.pages.CompanyTablePage.execLoadTableData(CompanyTablePage.java:23)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.execPopulateTable(AbstractPageWithTable.java:188)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.loadTableDataImpl(AbstractPageWithTable.java:541)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.loadChildren(AbstractPageWithTable.java:589)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTreeNode.ensureChildrenLoaded(AbstractTreeNode.java:836)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.handleActivePageChanged(AbstractOutline.java:359)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.access$0(AbstractOutline.java:347)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline$P_OutlineListener.treeChanged(AbstractOutline.java:415)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireTreeEventInternal(AbstractTree.java:1833)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireNodesSelected(AbstractTree.java:1685)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNodes(AbstractTree.java:1360)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNode(AbstractTree.java:1321)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop.setOutline(AbstractDesktop.java:730)
at org.eclipse.minicrm.client.ui.desktop.Desktop.execOpened(Desktop.java:65)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop$P_UIFacade.fireDesktopOpenedFromUI(AbstractDesktop.java:1297)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment$3.run(AbstractSwtEnvironment.java:545)
at org.eclipse.scout.rt.ui.swt.concurrency.SwtScoutSynchronizer$1.runVoid(SwtScoutSynchronizer.java:61)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:153)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I really don't understand my mistake I start again and again the tuto and always the same error appeared.
Thanks in advance for your help.
Re: failed to load data [message #882806 is a reply to message #882797] Thu, 07 June 2012 04:42 Go to previous messageGo to next message
Hi and sorry for the inconvenience.
At first sight it looks as the server is not started.
1. Can you check in the eclipse IDE Console tab:
Are there 2 processes running (swing-client and equinox-server)
2. Is the server maybe started twice or not at all?
If the problem is not solved that way, just export the (tutorial) workspace you have and attach to this forum post so we can take a look at it.
Re: failed to load data [message #882808 is a reply to message #882797] Thu, 07 June 2012 04:47 Go to previous messageGo to next message
Hi Adrien
This error means that something went wrong on the server. It's a general message due to security reasons. Have a look at the server log in the server console, there you should find the original exception.
Claudio
Re: failed to load data [message #882814 is a reply to message #882808] Thu, 07 June 2012 05:02 Go to previous messageGo to next message
Thanks for your answers I attach the project
I tried your solution Ivan and the server is normally started I 've nothing on the console ...
[Updated on: Thu, 07 June 2012 05:16] by Moderator
Re: failed to load data [message #882856 is a reply to message #882814] Thu, 07 June 2012 06:29 Go to previous messageGo to next message
Hi Adrien
As Claudio said, the error is in the server. Please make sure the DB available. By default the location is C:\DerbyDB.
See here where to get it: wiki.eclipse.org/Scout/Tutorial/3.7/Minicrm/Get_example_database
I could run your code with the example db and everything worked fine.
Re: failed to load data [message #882922 is a reply to message #882856] Thu, 07 June 2012 09:24 Go to previous messageGo to next message
I use C:\DerbyDB I followed the tutoriel and nothing change I uninstall and re install eclipse but nothing change
[Updated on: Thu, 07 June 2012 10:04] by Moderator
Re: failed to load data [message #882998 is a reply to message #882922] Thu, 07 June 2012 11:58 Go to previous messageGo to next message
Hi sorry for the double post but I think there is a big problem with my eclipse because scout application available on my boss' computer doesn' t work on mine.
So I tried to reinstall eclipse and Scout SDK I suppress all occurrences of eclipse on my Computer I reinstall eclipse and get Scout SDK 3.6 and always this error.
So I noticed that there is some warning with my java jre version because I used 1.7 instead of using 1.6 so I change it to AND now I see the problem with my server the error is Address already in use: bind
Caused by: org.osgi.service.cm.ConfigurationException: default : Address already in use: bind
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:111)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:60)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 9 more
And now I don't know what to do my server part is the only one which run there isn't another one but it seems to be used ...
I have to tell you that I used the same workspace for Indigo and Juno and I think I broke something cause before using Juno I haven't any problems.
Re: failed to load data [message #883043 is a reply to message #882998] Thu, 07 June 2012 14:09 Go to previous messageGo to next message
One workspace, 2 Eclipse Version.
adrien teulade wrote on Thu, 07 June 2012 17:58
That is not a good idea.
The scout runtime (also based on Eclipse Runtime) have changed between Juno and Indigo, so there is some migration work to upgrade from Indigo to Juno. (see the other posts where developers ask what they need to do for the migration).
Even if you manage 2 versions of your code (one for each runtime) as branches in your code repository, the SDK do not seems to appreciate the change of eclipse version. Probably some metadata are not compatible. I just broke my workspace.
JRE Version
I do not know what are the requirement for Eclipse and for Eclipse Scout. Maybe some one else can help. I assume the requirements are not the same for Indigo and for Juno.
This might occurs if the port you try to use for the client server application is already in used by an other application. By default, the scout Application uses 8080. If you have also Tomcat on your machine, you will get a conflict.
If you are interested in how you can change the port of one application, I can point you to a commit where I did this for my application.
Client and Server Stacktrace
I understood you experienced some trouble with stack trace today.
As Claudio said, if a problem occurs on the server, you are not getting the stacktrace of this problem in the client, due to security reason.
Example: Assume the derby database is locked (only one connection is allowed on a derby database instance).
On the client I get this:
ProcessingException[ProcessingStatus[ERROR code=0 QuestionsListForm / Calling IQuestionsListProcessService.load() / Erreur d'emploi]]
at $Proxy8.load(Unknown Source)
at org.eclipselabs.mcqs.client.ui.forms.QuestionsListForm.reloadForm(QuestionsListForm.java:244)
at org.eclipselabs.mcqs.client.ui.forms.QuestionsListForm.access$0(QuestionsListForm.java:240)
at org.eclipselabs.mcqs.client.ui.forms.QuestionsListForm$DisplayHandler.execLoad(QuestionsListForm.java:252)
at org.eclipse.scout.rt.client.ui.form.AbstractFormHandler.onLoad(AbstractFormHandler.java:174)
at org.eclipse.scout.rt.client.ui.form.AbstractForm.loadStateInternal(AbstractForm.java:1072)
at org.eclipse.scout.rt.client.ui.form.AbstractForm.startInternal(AbstractForm.java:638)
at org.eclipselabs.mcqs.client.ui.forms.QuestionsListForm.startDisplay(QuestionsListForm.java:262)
at org.eclipselabs.mcqs.client.ui.desktop.Desktop.execOpened(Desktop.java:46)
On the server I get this:
ProcessingException[ProcessingStatus[ERROR code=0 invoking org.eclipselabs.mcqs.shared.services.process.IQuestionsListProcessService:load / jdbcDriverName=org.apache.derby.jdbc.EmbeddedDriver, jdbcMappingName=jdbc:derby:/***path to the db***/mcq/mcq_db.derby / unexpected exception java.sql.SQLException: Failed to start database '/***path to the db***/mcq/mcq_db.derby', see the next exception for details.]]
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.leaseConnectionInternal(AbstractSqlService.java:625)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.execCreateConnection(AbstractSqlService.java:288)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.leaseConnection(AbstractSqlService.java:601)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.getTransaction(AbstractSqlService.java:674)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.selectInto(AbstractSqlService.java:717)
at org.eclipse.scout.rt.server.services.common.jdbc.SQL.selectInto(SQL.java:117)
at org.eclipselabs.mcqs.server.services.process.QuestionsListProcessService.load(QuestionsListProcessService.java:35)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:160)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invokeImpl(DefaultTransactionDelegate.java:198)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invoke(DefaultTransactionDelegate.java:79)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransactionWithDelegate(ServiceTunnelServlet.java:442)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransaction(ServiceTunnelServlet.java:438)
at org.eclipse.scout.rt.server.ServiceTunnelServlet$RemoteServiceJob.runTransaction(ServiceTunnelServlet.java:466)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:176)
at org.eclipse.scout.rt.server.ServerJob.access$0(ServerJob.java:165)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:136)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:1)
at javax.security.auth.Subject.doAs(Subject.java:396)
at org.eclipse.scout.rt.server.ServerJob.run(ServerJob.java:132)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.server.ServerJob.runNow(ServerJob.java:119)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doPost(ServiceTunnelServlet.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.scout.http.servletfilter.HttpServletEx.access$0(HttpServletEx.java:1)
at org.eclipse.scout.http.servletfilter.HttpServletEx$1.service(HttpServletEx.java:37)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.doFilterInternal(AbstractChainableSecurityFilter.java:214)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.access$0(AbstractChainableSecurityFilter.java:213)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter$1.run(AbstractChainableSecurityFilter.java:151)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:144)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:38)
at org.eclipse.scout.rt.server.servlet.filter.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:98)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:57)
at org.eclipse.scout.http.servletfilter.HttpServletEx.service(HttpServletEx.java:35)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: java.sql.SQLException: Failed to start database '/***path to the db***/mcq/mcq_db.derby', see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory40.getSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.seeNextException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:582)
at java.sql.DriverManager.getConnection(DriverManager.java:185)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionBuilder.createJdbcConnection(SqlConnectionBuilder.java:39)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.pool.SqlConnectionPool.leaseConnection(SqlConnectionPool.java:102)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.leaseConnectionInternal(AbstractSqlService.java:609)
... 61 more
at org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.SQLExceptionFactory40.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 76 more
Caused by: java.sql.SQLException: Another instance of Derby may have already booted the database /***path to the db***/mcq/mcq_db.derby.
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unknown Source)
... 73 more
Caused by: ERROR XSDB6: Another instance of Derby may have already booted the database /***path to the db***/mcq/mcq_db.derby.
at org.apache.derby.iapi.error.StandardException.newException(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.privGetJBMSLockOnDB(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.run(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.getJBMSLockOnDB(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
... 73 more
You can switch between the two output by using the menu in the console tab:
index.php/fa/10127/0/
I hope it helps you when you debug your code.
If you read french
I have written this: Premiers pas avec Eclipse Scout. It shows step by step how to create a small application. I demonstrate this application at Eclipse Day Paris 2011 last year. Maybe it can give you an other view on your problem.
Ask your questions here
Do not hesitate to ask your questions. Don't be sorry about posting here... There is no stupid question.
One of the goal of Eclipse Scout is to simplify the creation of Eclipse based applications for everybody. Like you I started at the beginning. You are welcome here!
[Updated on: Thu, 07 June 2012 14:13] by Moderator
Re: failed to load data [message #883307 is a reply to message #883043] Fri, 08 June 2012 05:02 Go to previous message
Believe me or not I can't believe it !!!
I can't launch the server because tomcat was launched (that's not so unbelievable Smile )
So I uninstall tomcat ...
But when I look for my DB it was removed during the night (and that's unbelievable) and the DerbyBIN was removed too !!
I re-install it and all work fine ...
thanks all for your help it was hard but we did it Smile
[Updated on: Fri, 08 June 2012 05:06] by Moderator
Previous Topic:Report
Next Topic:Scout Client/Server Version Management
Current Time: Fri Jul 25 19:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.06128 seconds
