Meaning of -shared location in org.eclipse.equinox.p2.director [message #882494] |
Wed, 06 June 2012 11:11 |
Hi again,
I'm hoping someone can help me out with this issue. I'm trying to use the org.eclipse.equinox.p2.director application to install features from a local update site. The product that I am installing the feature into is itself installed via Installation Manager (so it has a Shared directory of features/plugins).
eclipsec.exe -noSplash -application org.eclipse.equinox.p2.director -destination "D:\tpftoolkit_v40x_IM" -repository file://D:\runtime-ToolkitV40x\.metadata\.
plugins\com.ibm.tpf.configuration\.temp\site\site.xml -installIU ent.woohoo.feature.feature.group -bundlepool "C:\Program Files (x86)\IBM\IBMIMShared"
Installing ent.woohoo.feature.feature.group 1.0.0.201206051457.
Operation completed in 6506 ms.
This install works but when I look at the configuration, the feature is NOT installed into the shared location:
Id: ent.woohoo, Version: 1.0.0.201206051457, Location: reference:file:p2/cic.p2.cache.location/plugins/ent.woohoo_1.0.0.201206051457.jar
I think I need to use the -shared parameter but I don't understand how to use it. All of my attempts at adding this new parameter end with the following error:
plugins\com.ibm.tpf.configuration\.temp\site\site.xml -shared "C:\Program Files (x86)\IBM\IBMIMShared\plugins" -installIU ent.woohoo.feature.feature.group -bundlepool "C:\Pro
Installation failed.
Cannot complete the install because one or more required items could not be found.
Software currently installed: Feature 1.0.0.201206051457 (ent.woohoo.feature.feature.group 1.0.0.201206051457)
Missing requirement: Woohoo 1.0.0.201206051457 (ent.woohoo 1.0.0.201206051457) requires 'bundle org.eclipse.ui 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Feature 1.0.0.201206051457 (ent.woohoo.feature.feature.group 1.0.0.201206051457)
To: ent.woohoo [1.0.0.201206051457]
Application failed, log file location: D:\tpftoolkit_v40x_IM\configuration\1338930018732.log
Note that the only difference between the command that works and the this command is the addition of -shared. It complains about a missing org.eclipse.ui bundle, but this bundle does exist in the shared location. Somehow, the first command "finds" this bundle, but the second with the -shared does not...
Does anyone know what I'm doing wrong here?
FUDForum. Page generated in 1.06592 seconds
