Home » Modeling » ATL » xmi:type instead of xsi:type(ATL M2M transformation creates xmi file with xsi:type, how to get xmi:type?)
xmi:type instead of xsi:type [message #882348] Wed, 06 June 2012 05:35 Go to next message
I've started to learn ATL. I have done some M2M-Mappings with ATL. My target model is the UML-model delivered with eclipse. (namespace uri:http:www.eclipse.org:uml2:2.1.0:UML) The atl-script produces a xmi file as I want, but the problem is that the xmi file contains for the type a namespace which couldn't be detected by my uml model.
This is the generated xmi
<uml:Model xmi:version="2.0" xmlns:xmi="...omg.org/XMI" xmlns:xsi=".../XMLSchema-instance" xmlns:uml="..omg.org/spec/UML/20110701" name="COCT_HD080000UV09">
  <packagedElement xsi:type="uml:Package" name="R_Specimen universal">
    <packagedElement xsi:type="uml:Class" name="ActDefinition"/>
But the packagedElements should have the following attributes for importing to my uml tool.
 <packagedElement xmi:type="uml:Package" name="R_Specimen universal">
    <packagedElement xmi:type="uml:Class" name="ActDefinition"/>
I have manually changed the namespace and the import to my uml tool works.
How can I reach that the namespace of xmi is used for type instead of the xml schema namespace? Do I have to use another target Metamodel?
Re: xmi:type instead of xsi:type [message #882368 is a reply to message #882348] Wed, 06 June 2012 06:04 Go to previous messageGo to next message
Martin,
Probably it's best to ensure you save using a resource created by UML2's
specialized resource factory; failing that
XMIResource.OPTION_USE_XMI_TYPE mapped to Boolean.TRUE as a save option
should help.
> works.
Re: xmi:type instead of xsi:type [message #882375 is a reply to message #882368] Wed, 06 June 2012 06:33 Go to previous messageGo to next message
UML/20110701 is UML 2.4.1 so you must be using a Juno pre-release. This
should have xmi:version="20110701" as well as xmi:type.
Your UML configuration is therefore wrong.
Check that UMLResourcesUtil.init() is being called. It was not available
before M7, when user code had to get all the registrations right by hand.
Ed Willink
On 06/06/2012 11:04, Ed Merks wrote:
> Martin,
> UML2's specialized resource factory; failing that
> option should help.
>> works.
Re: xmi:type instead of xsi:type [message #882398 is a reply to message #882368] Wed, 06 June 2012 07:49 Go to previous messageGo to next message
Thanks for your response.
If I want to set the XMIResource.OPTION_USE_XMI_TYPE option, do I have to create a launcher class? Or could I do this with my ant-launch script.
[Updated on: Wed, 06 June 2012 07:52] by Moderator
Re: xmi:type instead of xsi:type [message #882402 is a reply to message #882398] Wed, 06 June 2012 07:56 Go to previous messageGo to next message
Normally you'd do this in Java in your resource factory or in Java in
the options passed to the call to Resource.save.
> If I want to set the XMIResource.OPTION_USE_XMI_TYPE option. Do I have
Re: xmi:type instead of xsi:type [message #882408 is a reply to message #882398] Wed, 06 June 2012 08:09 Go to previous messageGo to next message
This is tackling the wrong problem. The correct UML installation does
this and much more automatically.
If ATL RC3 doesn't call UMLResourcesUtil.init() raise a bug quickly.
Then you may create a launcher class to call it yourself.
Ed Willink
Re: xmi:type instead of xsi:type [message #882417 is a reply to message #882408] Wed, 06 June 2012 08:36 Go to previous messageGo to next message
Which parameter must I influence to get the correct UML installation? I'm sorry for asking such a stupid question, but I'm a complete beginner in ATL and EMF.
My current output now is:
<uml:Model xmi:version="2.0" xmlns:xmi="....omg.org/XMI" xmlns:xsi="....w3.org/2001/XMLSchema-instance" xmlns:uml="....eclipse.org/uml2/3.0.0/UML" name="COCT_HD080000UV09">
Edward Willink wrote on Wed, 06 June 2012 14:09
Ed Willink
Re: xmi:type instead of xsi:type [message #882423 is a reply to message #882417] Wed, 06 June 2012 08:47 Go to previous messageGo to next message
HI
I'm sorry, I can't help with ATL; hopefully some ATL committer/user will
respond.
I can only point out what appear to be the UML aspects of the problem.
Ed Willink
>> Hi
>> Regards
>> Ed Willink
>> have > to create a launcher class? Or could I do this with my
>> ant-launch script.
Re: xmi:type instead of xsi:type [message #882431 is a reply to message #882423] Wed, 06 June 2012 09:01 Go to previous messageGo to next message
I have written a ATL-plugin where I have defined the XMI option Ed Merks suggested. Now it sucessfully creates xmi:type attributes.
For the namespace of UML have used the eclipse namespace with 3.0.0.
According to Ed Willinks suggestions there will be more work.
The only drawback until now is, that I need a dedicated Java class for doing transformation. My aim was to have an ant script.
Thanks for any help, until now.
[Updated on: Wed, 06 June 2012 09:08] by Moderator
Re: xmi:type instead of xsi:type [message #882509 is a reply to message #882431] Wed, 06 June 2012 11:53 Go to previous messageGo to next message
Is your ouput file named xxx.uml ? ATL delegates to the resource factory using the file extension.
Re: xmi:type instead of xsi:type [message #882516 is a reply to message #882509] Wed, 06 June 2012 11:57 Go to previous messageGo to next message
This is probably alright for output, but is not consistent with the user
reports:
1st: ....omg.org/spec/UML/20110701 implies a Jiuno pre-release
2nd: ....eclipse.org/uml2/3.0.0/UML implies Indigo
if default creation is occurring.
Ed Willink
Re: xmi:type instead of xsi:type [message #882566 is a reply to message #882516] Wed, 06 June 2012 14:37 Go to previous message
The file is currently name xmi. I will have a try with *.uml
I see, in my first report there was the first mentioned value was occuring. I don't know and I can't reproduce. Perhaps it was reasoned by some experiments with other tools.
The second value ...eclipse.org/uml2/3.0.0/UML is the right one. It occurs always if I generate my model.
EDIT:
I have tested with file extension .uml. Now it works also with my ant script. Great!
Thank You
[Updated on: Wed, 06 June 2012 15:03] by Moderator
Previous Topic:How to improve my ATL transformation
Next Topic:Why isn't my profile applied?
Current Time: Wed Jul 23 12:56:10 EDT 2025
Powered by FUDForum. Page generated in 0.08291 seconds
