The command org.eclipse.ui.views.showView [message #882068] |
Tue, 05 June 2012 15:02  |
I added the plg of PyDev to my app.
When i want to use the command org.eclipse.ui.views.showView, it list all the views of the PyDev plg, but i want to see my own view of the perspectives.
How can i do this?
Thanks.
Re: The command org.eclipse.ui.views.showView [message #882246 is a reply to message #882068] |
Wed, 06 June 2012 01:48   |
First I have to admit, that I do not know the PyDev plugin.
Is your problem, that your views do not appear in this menu or that also those PyDev views are available?
As long you use the org.eclipse.ui.views extension to register your views in your plugin.xml, they should also appear in the dialog, which is shown when the org.eclipse.ui.views.showView Command is invoked.
If you want to remove some views of the PyDev plugin from the showView Dialog, you will have to remove them from the plugin.xml of the PyDev plugin.
By the way:
Quote:..., but i want to see my own view of the perspectives.
Views do not belong to a certain perspective, they generally can be opened in every perspective.
Simon
Re: The command org.eclipse.ui.views.showView [message #884308 is a reply to message #882068] |
Sun, 10 June 2012 15:18  |
Hi Esteban,
Did you correctly register your own views in the plugin.xml of your plugin project?
Like it is done here :
help.eclipse.org/helios/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fworkbench_basicext_views.htm
Another common mistake is that your own project is not selected in the plugins tab of the run configurations, so that your own project will not be started withing the client.
I myself do use the org.eclipse.ui.views.showView in my new own little private RCP project and it works like it should.
Simon
FUDForum. Page generated in 0.06336 seconds
