Home » Modeling » TMF (Xtext) » Problem with quick fixes(define a quick fixes by myself)
Problem with quick fixes [message #881746] Tue, 05 June 2012 03:33 Go to next message
hi,i want to use the feature (quick fixes) of xtext, and for that i wanted to do a simple example of putting a warning when a specific name doesn't start with a capital letter. this is the code of
- the javavalidator class:
  package org.xtext.example.validation;
import org.eclipse.xtext.validation.Check;
import org.xtext.example.project2.EEPROM_DEVICESTYPE;
import org.xtext.example.project2.Project2Package;
public class Project2JavaValidator extends AbstractProject2JavaValidator {
	//@Check
//public void checkNameStartsWithCapital(EEPROM_DEVICESTYPE  eEPROM_DEVICESTYPE) {
//		if (eEPROM_DEVICESTYPE.getName() == null || eEPROM_DEVICESTYPE.getName().length() == 0)return;
//		if (!Character.isUpperCase(eEPROM_DEVICESTYPE.getName().charAt(0))) {warning("Name in this case should start with a capital letter.", Project2Package.EEPROM_DEVICESTYPE__NAME, [u]INVALID_NAME [/u], eEPROM_DEVICESTYPE.getName());
my problem here is with the underline "INVALID_NAME" saying that INVALID_NAME cannot be resolved to a variable.i don't know how to fixe it.
and that error has an impact on the quickfixProvider class cince the INVALID_NAME is not good. That is the quickfixProvider class
package org.xtext.example.ui.quickfix;
import org.eclipse.jface.text.BadLocationException;
import org.eclipse.xtext.ui.editor.model.IXtextDocument;
import org.eclipse.xtext.ui.editor.model.edit.IModification;
import org.eclipse.xtext.ui.editor.model.edit.IModificationContext;
import org.eclipse.xtext.ui.editor.quickfix.DefaultQuickfixProvider;
import org.eclipse.xtext.ui.editor.quickfix.Fix;
import org.eclipse.xtext.ui.editor.quickfix.IssueResolutionAcceptor;
import org.eclipse.xtext.validation.Issue;
import org.xtext.example.validation.Project2JavaValidator;
public class Project2QuickfixProvider extends DefaultQuickfixProvider {
	@Fix(Project2JavaValidator.INVALID_NAME)
	public void capitalizeName(final Issue issue, IssueResolutionAcceptor acceptor) {
		acceptor.accept(issue, "Capitalize name", "Capitalize the name.", "upcase.png", new IModification() {
			public void apply(IModificationContext context) throws BadLocationException {
				IXtextDocument xtextDocument = context.getXtextDocument();
				String firstLetter = xtextDocument.get(issue.getOffset(), 1);
				xtextDocument.replace(issue.getOffset(), 1, firstLetter.toUpperCase());
can somebody tell why the name " INVALID_NAME" is not correct, i even change it, bbut i still have de same error.
My best regard,
Frank
  • Attachment: Project2.zip
    (Size: 265.74KB, Downloaded 136 times)
Re: Problem with quick fixes [message #881794 is a reply to message #881746] Tue, 05 June 2012 05:09 Go to previous messageGo to next message
Hi Frank,
INVALID_NAME is a string constant that you'll have to define somewhere.
It has to be accessible from the quickfix provider and the validator. It
should be unique as its value is used to identify fixable issues in your
language.
Sebastian
Am 05.06.12 09:33, schrieb frank fotso:
> //@Check
> // if (!Character.isUpperCase(eEPROM_DEVICESTYPE.getName().charAt(0))) {warning("Name in this case should start with a capital letter.", Project2Package.EEPROM_DEVICESTYPE__NAME, INVALID_NAME , eEPROM_DEVICESTYPE.getName());
> My best regard,
> Frank
Re: Problem with quick fixes [message #881801 is a reply to message #881794] Tue, 05 June 2012 05:22 Go to previous messageGo to next message
Thks Sabastian,
i have declare the constant String INVALID_NAME as follow
	public static final String INVALID_NAME = "org.xtext.example.project2.InvalidTypeName";
	@Check
	//	if (!Character.isUpperCase(name.getLocalName().charAt(0))) {
		//	warning("Name should start with a capital", Project2Package.Literals.EEPROM_BLOCKLOCAL__NAME);
	private void warning(String message, int eepromDevicestypeName,
			String invalidName, String name) {
		// TODO Auto-generated method stub
and change the quickfuixProvider class to the one follow:
now all the errors have dissapear and my file is correct but when i execute the project , the editor file that i create even if the name start with a small letter is correct which is not normal since it was supposed to put a warning telling that the name should start with a capital letter.
Re: Problem with quick fixes [message #881814 is a reply to message #881801] Tue, 05 June 2012 05:43 Go to previous messageGo to next message
That's because you have this method in your validator that does nothing:
Am 05.06.12 11:22, schrieb frank fotso:
You may want to use Project2Package.Listeral.sEEPROM_BLOCKLOCAL_NAME
instead.
Sebastian
Re: Problem with quick fixes [message #881919 is a reply to message #881814] Tue, 05 June 2012 09:54 Go to previous messageGo to next message
Thks sebastian
i did as you said and now the warning appear but when i try de quick fixes butmessage appearing that there are no quick fixe for that warning , but i've define it in the quickFixProvider class as follows:
	@Fix(value = "INVALID_NAME")
Re: Problem with quick fixes [message #881930 is a reply to message #881919] Tue, 05 June 2012 10:07 Go to previous messageGo to next message
For starters - do you have a binding for specialized quick fix provider
in your UI module?
- henrik
On 2012-05-06 15:54, frank fotso wrote:
> Thks sebastian
> acceptor) {
Re: Problem with quick fixes [message #881934 is a reply to message #881930] Tue, 05 June 2012 10:14 Go to previous message
is oki i've solved the problem
it was due to the encoding mode and something else , now everything is oki
Thks for the help guyz
FRank
Previous Topic:Please help with simple grammar
Next Topic:Outline "within" Project Explorer?
Current Time: Sat Jul 26 12:50:38 EDT 2025
Powered by FUDForum. Page generated in 0.05109 seconds
