[Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #881877] |
Tue, 05 June 2012 08:12  |
in method ReflectUtil.instantiate() throws exception: Cannot cast Integer to int.
if is set the parameter "driverType" in the dataSource inside the cdo-server.xml.
To change the condition in line 446 in ReflectUtil to:
else if (type.isAssignableFrom(Integer.class) || type.isAssignableFrom(int.class))
value = Integer.parseInt(str);
solves the problem.
Can we get support for this bug?
Robert
[Updated on: Tue, 05 June 2012 08:14] by Moderator
Re: [Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #886239 is a reply to message #884476] |
Thu, 14 June 2012 10:06  |
Bugzilla entry is https://bugs.eclipse.org/bugs/show_bug.cgi?id=382491
On 06/11/2012 08:31 AM, Eike Stepper wrote:
> Am 11.06.2012 08:21, schrieb Joerg Pacher:
>> Hi Eike and Robert,
>> i fixed this for 4.1 and Robert should have the patch at hand already.
> Great! Please don't forget to attach the patch to the bugzilla Robert
> wants to submit ;-)
>> There are some other issues regarding the DB2-Adapter i would like to
>> discuss before raising issues but hadn't time to do so.
>> @Eike Maybe we can find some time at Democamp/Kassel.
> We can certainly try it ;-)
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Grettings
>> Jörg
>> On 06/05/2012 03:04 PM, Eike Stepper wrote:
>>> Hi Robert,
>>> Please submit a bugzilla against EMF|cdo.net4j and ideally provide the
>>> complete stack trace and your proposal of a fix.
>>> Please note that we stopped CDO 4.0 maintenance, now that 4.1 is almost
>>> released and all our current efforts go into the release.
>>> Cheers
>>> /Eike
>>> Am 05.06.2012 14:12, schrieb Robert Maier:
>>>> Integer to int.
>>>> cdo-server.xml.
>>>> // patch: || type.isAssignableFrom(int.class) added value =
>>>> solves the problem.
>>>> Thanks
>>>> Robert
FUDForum. Page generated in 0.24717 seconds
