Home » Modeling » TMF (Xtext) » Custom Activator in UI plug-in?
Custom Activator in UI plug-in? [message #881453] Mon, 04 June 2012 11:32 Go to next message
I thought this should be simple but I'm stuck:
I want to add custom initialization to the activator of a UI plug-in.
So, how do I tell Xtext not to generate a new activator but use my version?
Things I tried:
- move activator from target/generated-sources/xtext to src/main/java
=> activator is re-generated and now I have two identical activators, compilation fails
- disable generating basic UI stuff (since I already have it),
Is this driven by the ImplicitUiFragment? I tried to disable this fragment by unsetting pathToUiProject and projectNameUi, (as suggested in the help) but then all UI stuff was generated into the DSL plug-in
=> compilation utterly broken.
- Sub-class the activator, but then it will not be used by the DSLExecutableExtensionFatory (and probably the entry in MANIFEST.MF will be overwritten, too, right?)
=> not the intended effect
I must be missing s.t. really obvious?
thanks,
Stephan
Re: Custom Activator in UI plug-in? [message #881483 is a reply to message #881453] Mon, 04 June 2012 12:28 Go to previous messageGo to next message
I just extended the generated activator.
You can check out what I did in cloudsmith/geppetto @ github.
The ui bundle is /org.cloudsmith.geppetto.pp.dsl.ui
Note that the manifest is not overwritten - you have to always manually
merge (and pick what you want) from the generated. So, it is perfectly
fine to just point to your activator.
The executable extension stuff will continue to work since the
references to the generated activator uses static information which is
present / setup since the custom activator inherits the generated...
Hope that helps.
- henrik
> Things I tried:
> compilation fails
> thanks,
> Stephan
Re: Custom Activator in UI plug-in? [message #881499 is a reply to message #881483] Mon, 04 June 2012 13:33 Go to previous messageGo to next message
Henrik Lindberg wrote on Mon, 04 June 2012 18:28
Thanks a lot. Now I know which path should work.
So that's the bug here: my GenerateMyDsl.mwe2 indeed overwrites the UI plug-ins MANIFEST.MF every time invoked. I see what you say regarding plugin.xml and plugin.xml_gen but not for the manifest!
So, how can I find out who's doing this?
I have the following fragments enabled in my mwe2:
- grammarAccess.GrammarAccessFragment
- serializer.SerializerFragment
- resourceFactory.ResourceFactoryFragment
- parser.antlr.XtextAntlrGeneratorFragment
- validation.JavaValidatorFragment
- scoping.ImportNamespacesScopingFragment
- exporting.QualifiedNamesFragment
- builder.BuilderIntegrationFragment
- formatting.FormatterFragment
- labeling.LabelProviderFragment
- outline.OutlineTreeProviderFragment
- outline.QuickOutlineFragment
- quickfix.QuickfixProviderFragment
- contentAssist.JavaBasedContentAssistFragment
- parser.antlr.XtextAntlrUiGeneratorFragment
- junit.Junit4Fragment
- types.TypesGeneratorFragment
- xbase.XbaseGeneratorFragment
- templates.CodetemplatesGeneratorFragment
- refactoring.RefactorElementNameFragment
- compare.CompareFragment
Which of these would be suspected to overwrite the manifest? Anything I need to configure? Or is that a bug in Xtext 2.2.1 that has been fixed in 2.3?
Tricky, indeed. So the only reference that should be updated is in the manifest?
thanks,
Stephan
Re: Custom Activator in UI plug-in? [message #881758 is a reply to message #881499] Tue, 05 June 2012 03:59 Go to previous messageGo to next message
Stephan,
use mergeManifest=false on the generator.
Sebastian
Am 04.06.12 19:33, schrieb Stephan Herrmann:
>> manually merge (and pick what you want) from the generated. So, it is
>> perfectly fine to just point to your activator.
> in 2.3?
> manifest?
> thanks,
> Stephan
Re: Custom Activator in UI plug-in? [message #882414 is a reply to message #881758] Wed, 06 June 2012 08:32 Go to previous message
That does the trick.
And it also avoids the need to refresh MANIFEST.MF after each run of the Xtext generator Smile
thanks!
Stephan
Previous Topic:quotation marks
Next Topic:Guice setup in multi-plug-in setups
Current Time: Sat Jul 26 11:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.28405 seconds
