Home » Modeling » TMF (Xtext) » Finer grained quickfixes possible?
Finer grained quickfixes possible? [message #881305] Mon, 04 June 2012 06:07 Go to next message
I want to implement a quickfix that only applies (for a certain issueCode) depending on extra data. For example: "library ieee;" should be quickfixable, but "library myLib;" not.
I can not find a way to do this in Xtext, except for giving a different issueCode for the libraries that can be fixed. I do not like this approach. It is not the responsability of the validator to know what can be fixed and what not (yet).
In Eclipse the method to check for quickfixes is hasResolution(IMarker...) but in Xtext it is hasResolutionFor(String issueCode). Why is this method not simply hasResolutionFor(Issue issue), so you check some extra data of the issue?
Hendrik.
Re: Finer grained quickfixes possible? [message #881410 is a reply to message #881305] Mon, 04 June 2012 09:53 Go to previous messageGo to next message
Hi Hendrik,
a workaround would be the following:
Override
org.eclipse.xtext.ui.editor.quickfix.XtextQuickAssistProcessor.canFix(Annotation)
and
org.eclipse.xtext.ui.editor.quickfix.MarkerResolutionGenerator.hasResolutions(IMarker)
which could both delegate to a custom IssueResolutionProvider that
accepts the Issue.
Sebastian
Am 04.06.12 12:07, schrieb Hendrik Eeckhaut:
> Hendrik.
Re: Finer grained quickfixes possible? [message #881721 is a reply to message #881410] Tue, 05 June 2012 02:46 Go to previous messageGo to next message
I could not get this to work with our current Xtext snapshot target (February). I saw that there were multiple changes in this area in the commit logs. So I will try again later this week with Xtext head.
Thanks for helping me out,
Hendrik.
Re: Finer grained quickfixes possible? [message #885094 is a reply to message #881721] Tue, 12 June 2012 09:09 Go to previous messageGo to next message
Hi Sebastian,
this only partially works. This allows quickfixes in the problems view, but not in the editor. As far as I can see the quickfix-abiliy is determined in the
getAnnotationsToAdd
method in
AnnotationIssueProcessor
. It does not look like I can easily modify that.
Any suggestions?
Hendrik.
Re: Finer grained quickfixes possible? [message #885131 is a reply to message #885094] Tue, 12 June 2012 10:05 Go to previous messageGo to next message
You are right, I missed that.
You'd have to override
AnnotationIssueProcessor.getAnnotationsToAdd(Multimap<Position,
Annotation>, List<Issue>, IProgressMonitor) and use the issue data
there. That's unfortunate. Could you please file a ticket?
Sebastian
Am 12.06.12 15:09, schrieb Hendrik Eeckhaut:
> Hi Sebastian,
> determined in the getAnnotationsToAdd method in
> AnnotationIssueProcessor. It does not look like I can easily modify that.
> Any suggestions?
> Hendrik.
Re: Finer grained quickfixes possible? [message #885539 is a reply to message #885131] Wed, 13 June 2012 03:56 Go to previous message
OK. Filed id=382461
Hendrik.
Previous Topic:XtextResource loading with JvmTypes and importURI
Next Topic:XTend 2.2.1 installation broken? (NPE at BuilderParticipant.java:184)
Current Time: Sat Nov 01 01:40:14 EDT 2025
Powered by FUDForum. Page generated in 0.96757 seconds
