Home » Language IDEs » C / C++ IDE (CDT) » CDT Build is built twice
CDT Build is built twice [message #881350] Mon, 04 June 2012 07:44 Go to next message
Does anybody knows which patch fixes the following reported BUG.
Bug 224326
I'm posting the number and the link because the system doesn't let me post links unless I post 25 messages !?!?!
I'm facing now with this issue in Eclipse Indigo 3.7.1.r37x_v20
First Build
*** Build of configuration Debug for project GhnStackManagementCuteTest ****
make all
Building file: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnDmCapableRoleManagementFSMTest.cpp
Invoking: GCC C++ Compiler
g++ -DOSAL_UNDER_LINUX -I../../../api -I../../../../../../../Common/BasicInfra/boost -I../../../../../../../Common/BasicInfra/cute -I../../../../../../../Common/OS/OSAL/api -I../../../../../../../Common/OS/Sockets/api -I../../../../../../../Common/BasicInfra/Logger/api -I../../../../../../../Common/BasicInfra/StatisticsCollection/api -I../../../../../../../Common/BasicInfra/FoundationClasses/api -I../../../../../../../Common/BasicInfra/IPC/api -I../../../../../../../Common/BasicInfra/BasicInfraClient/api -I../../../../../../../Jerry/Application/Map/JerryMapBuilder/api -I../../../../../../AdvancedInfra/HAL/JerryHal/api -I../../../../../../AdvancedInfra/HAL/JerryHal/hw_specific/sim -I../../../../../../AdvancedInfra/ConfigurationManager/api -I../../../../../../AdvancedInfra/XMLParser/api -I../../../../../../../Common/GalilInfra/GalilCommonStructures/api -I../../../../GhnMessenger/generated -I../../../../NetworkAdmission/GhnEPNetworkAdmission/api -I../../../../NetworkAdmission/GhnDMNetworkAdmission/api -I../../../../NetworkAdmission/GhnNetworkAdmissionCommon/api -I../../../../GhnMessenger/api -I../../../../MediumAccessManager/api -I../../../../EPRoutingAndTopologyManagement/api -I../../../api -O0 -g3 -Wall -c -fmessage-length=0 -fprofile-arcs -ftest-coverage -m32 -MMD -MP -MF"tests/GhnDmCapableRoleManagementFSMTest.d" -MT"tests/GhnDmCapableRoleManagementFSMTest.d" -o "tests/GhnDmCapableRoleManagementFSMTest.o" "/home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnDmCapableRoleManagementFSMTest.cpp"
Finished building: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnDmCapableRoleManagementFSMTest.cpp
Building file: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnNonDmCapableRoleManagementFSMTest.cpp
g++ -DOSAL_UNDER_LINUX -I../../../api -I../../../../../../../Common/BasicInfra/boost -I../../../../../../../Common/BasicInfra/cute -I../../../../../../../Common/OS/OSAL/api -I../../../../../../../Common/OS/Sockets/api -I../../../../../../../Common/BasicInfra/Logger/api -I../../../../../../../Common/BasicInfra/StatisticsCollection/api -I../../../../../../../Common/BasicInfra/FoundationClasses/api -I../../../../../../../Common/BasicInfra/IPC/api -I../../../../../../../Common/BasicInfra/BasicInfraClient/api -I../../../../../../../Jerry/Application/Map/JerryMapBuilder/api -I../../../../../../AdvancedInfra/HAL/JerryHal/api -I../../../../../../AdvancedInfra/HAL/JerryHal/hw_specific/sim -I../../../../../../AdvancedInfra/ConfigurationManager/api -I../../../../../../AdvancedInfra/XMLParser/api -I../../../../../../../Common/GalilInfra/GalilCommonStructures/api -I../../../../GhnMessenger/generated -I../../../../NetworkAdmission/GhnEPNetworkAdmission/api -I../../../../NetworkAdmission/GhnDMNetworkAdmission/api -I../../../../NetworkAdmission/GhnNetworkAdmissionCommon/api -I../../../../GhnMessenger/api -I../../../../MediumAccessManager/api -I../../../../EPRoutingAndTopologyManagement/api -I../../../api -O0 -g3 -Wall -c -fmessage-length=0 -fprofile-arcs -ftest-coverage -m32 -MMD -MP -MF"tests/GhnNonDmCapableRoleManagementFSMTest.d" -MT"tests/GhnNonDmCapableRoleManagementFSMTest.d" -o "tests/GhnNonDmCapableRoleManagementFSMTest.o" "/home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnNonDmCapableRoleManagementFSMTest.cpp"
Finished building: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnNonDmCapableRoleManagementFSMTest.cpp
Building file: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnStackManagementCuteTest.cpp
g++ -DOSAL_UNDER_LINUX -I../../../api -I../../../../../../../Common/BasicInfra/boost -I../../../../../../../Common/BasicInfra/cute -I../../../../../../../Common/OS/OSAL/api -I../../../../../../../Common/OS/Sockets/api -I../../../../../../../Common/BasicInfra/Logger/api -I../../../../../../../Common/BasicInfra/StatisticsCollection/api -I../../../../../../../Common/BasicInfra/FoundationClasses/api -I../../../../../../../Common/BasicInfra/IPC/api -I../../../../../../../Common/BasicInfra/BasicInfraClient/api -I../../../../../../../Jerry/Application/Map/JerryMapBuilder/api -I../../../../../../AdvancedInfra/HAL/JerryHal/api -I../../../../../../AdvancedInfra/HAL/JerryHal/hw_specific/sim -I../../../../../../AdvancedInfra/ConfigurationManager/api -I../../../../../../AdvancedInfra/XMLParser/api -I../../../../../../../Common/GalilInfra/GalilCommonStructures/api -I../../../../GhnMessenger/generated -I../../../../NetworkAdmission/GhnEPNetworkAdmission/api -I../../../../NetworkAdmission/GhnDMNetworkAdmission/api -I../../../../NetworkAdmission/GhnNetworkAdmissionCommon/api -I../../../../GhnMessenger/api -I../../../../MediumAccessManager/api -I../../../../EPRoutingAndTopologyManagement/api -I../../../api -O0 -g3 -Wall -c -fmessage-length=0 -fprofile-arcs -ftest-coverage -m32 -MMD -MP -MF"tests/GhnStackManagementCuteTest.d" -MT"tests/GhnStackManagementCuteTest.d" -o "tests/GhnStackManagementCuteTest.o" "/home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnStackManagementCuteTest.cpp"
Finished building: /home/vadim/Projects/Working_Copy/Galil/Jerry/Application/Ghn/GhnStackManagement/tests/GhnStackManagementCuteTest.cpp
Building file: ../src/Test.cpp
g++ -DOSAL_UNDER_LINUX -I../../../api -I../../../../../../../Common/BasicInfra/boost -I../../../../../../../Common/BasicInfra/cute -I../../../../../../../Common/OS/OSAL/api -I../../../../../../../Common/OS/Sockets/api -I../../../../../../../Common/BasicInfra/Logger/api -I../../../../../../../Common/BasicInfra/StatisticsCollection/api -I../../../../../../../Common/BasicInfra/FoundationClasses/api -I../../../../../../../Common/BasicInfra/IPC/api -I../../../../../../../Common/BasicInfra/BasicInfraClient/api -I../../../../../../../Jerry/Application/Map/JerryMapBuilder/api -I../../../../../../AdvancedInfra/HAL/JerryHal/api -I../../../../../../AdvancedInfra/HAL/JerryHal/hw_specific/sim -I../../../../../../AdvancedInfra/ConfigurationManager/api -I../../../../../../AdvancedInfra/XMLParser/api -I../../../../../../../Common/GalilInfra/GalilCommonStructures/api -I../../../../GhnMessenger/generated -I../../../../NetworkAdmission/GhnEPNetworkAdmission/api -I../../../../NetworkAdmission/GhnDMNetworkAdmission/api -I../../../../NetworkAdmission/GhnNetworkAdmissionCommon/api -I../../../../GhnMessenger/api -I../../../../MediumAccessManager/api -I../../../../EPRoutingAndTopologyManagement/api -I../../../api -O0 -g3 -Wall -c -fmessage-length=0 -fprofile-arcs -ftest-coverage -m32 -MMD -MP -MF"src/Test.d" -MT"src/Test.d" -o "src/Test.o" "../src/Test.cpp"
Finished building: ../src/Test.cpp
Building target: GhnStackManagementCuteTest
Invoking: GCC C++ Linker
g++ -L../../../../../../../Common/OS/OSAL/build/eclipse_linux_x86/Debug -L../../../../../../../Common/OS/Sockets/build/eclipse_linux_x86/Debug -L../../../../../../../Common/BasicInfra/Logger/build/eclipse_linux_x86/Debug -L../../../../../../../Common/BasicInfra/FoundationClasses/build/eclipse_linux_x86/Debug -L../../../../../../../Common/BasicInfra/StatisticsCollection/build/eclipse_linux_x86/Debug -L../../../../../../../Common/BasicInfra/IPC/build/eclipse_linux_x86/Debug -L../../../../../../../Common/BasicInfra/BasicInfraClient/build/eclipse_linux_x86/Debug -L../../../../../../../Jerry/Application/Map/JerryMapBuilder/build/eclipse_linux_x86/Debug -L../../../../../../../Jerry/Application/Ghn/NetworkAdmission/GhnEPNetworkAdmission/build/eclipse_linux_x86/Debug -L../../../../../../../Jerry/Application/Ghn/NetworkAdmission/GhnDMNetworkAdmission/build/eclipse_linux_x86/Debug -L../../../../../../../Jerry/AdvancedInfra/HAL/JerryHal/build/eclipse_linux_x86/Debug -L../../../../../../../Jerry/AdvancedInfra/ConfigurationManager/build/eclipse_linux_x86/Debug -L../../../../GhnMessenger/build/eclipse_linux_x86/Debug -L../../../../MediumAccessManager/build/eclipse_linux_x86/Debug -L../../../../EPRoutingAndTopologyManagement/build/eclipse_linux_x86/Debug -L../../eclipse_linux_x86/Debug -fprofile-arcs -rdynamic -m32 -o "GhnStackManagementCuteTest" ./tests/GhnDmCapableRoleManagementFSMTest.o ./tests/GhnNonDmCapableRoleManagementFSMTest.o ./tests/GhnStackManagementCuteTest.o ./src/Test.o -lGhnStackManagement -lEPRoutingAndTopologyManagement -lConfigurationManager -lGhnEPNetworkAdmission -lGhnDMNetworkAdmission -lGhnMessenger -lJerryHal -lMediumAccessManager -lJerryMapBuilder -lBasicInfraClient -lLogger -lIPC -lStatisticsCollection -lFoundationClasses -lSockets -lOSAL -lpthread -lrt -lbfd -liberty
Finished building target: GhnStackManagementCuteTest
**** Build Finished ****
Second Build
**** Build of configuration Debug for project GhnStackManagementCuteTest ****
make all
make: Nothing to be done for `all'.
Re: CDT Build is built twice [message #881763 is a reply to message #881350] Tue, 05 June 2012 04:11 Go to previous messageGo to next message
The patch is attached to the bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=291751
According to the bug report the patch was not applied to HEAD because of regression problems.
Re: CDT Build is built twice [message #881766 is a reply to message #881763] Tue, 05 June 2012 04:13 Go to previous messageGo to next message
Wait. The patch was in CDT 7.0 and then removed later.
Re: CDT Build is built twice [message #881768 is a reply to message #881766] Tue, 05 June 2012 04:17 Go to previous messageGo to next message
I understand.
Thank you very much for the info.
Can you please point me to a reference on how do I apply patches ?
Thanks you
Re: CDT Build is built twice [message #881771 is a reply to message #881768] Tue, 05 June 2012 04:21 Go to previous message
vadim malenboim wrote on Tue, 05 June 2012 10:17
I understand.
Thanks you
http://wiki.eclipse.org/Getting_started_with_CDT_development
Previous Topic:Keyboard: goto next build error (w/screenshot)
Next Topic:Problem "using namespace ..."
Current Time: Sat Jul 26 09:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.49254 seconds
