Home » Archived » Test and Performance Tools Platform (TPTP) » Launch error, return code from startProcess0() = -1 in JUnit tests using TPTP
Launch error, return code from startProcess0() = -1 in JUnit tests using TPTP [message #87901] Sat, 18 November 2006 08:36 Go to next message
Hi All,
As a result of running the JUnit tests using TPTP, sometimes, I get the
following error (stacktrace below).
I tried to use eclispe -clean, and end the running 'eclipse.exe' and
'javaw.exe' using the task manager and tried the tests again, but it does
not help, if it appears once.
Did anyone experience this problem earlier ?
Thanks for the pointers!
Ravi.
____________________________________________________________ _________________
test.execution:
[echo] Executing test suite
adding file src\com\mycompany\mytest\tests\myTest.testsuite
Test started!
Test 'src\com\mycompany\mytest\tests\myTest.testsuite'
executing
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
at
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:420)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2085)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$3(TestExecutionHarness.java:1817)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:741)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Waiting...
No results collected!
at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:435)
at
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
at
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:140)
at
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
Re: Launch error, return code from startProcess0() = -1 in JUnit tests using TPTP [message #88023 is a reply to message #87901] Mon, 20 November 2006 10:46 Go to previous messageGo to next message
Originally posted by: dequeker.gmail.com
Sorry if this is a silly suggestion (I haven't done any Junit testing
using TPTP other than through AGR), but have you tried to restart the
agent controler ?
Ravi Roy wrote:
> Hi All,
> Regards
> Ravi.
> test.execution:
> Test started!
> executing
> at
> at
> at
> at
> Waiting...
> at
> at
> at
> at
Re: Launch error, return code from startProcess0() = -1 in JUnit tests using TPTP [message #88052 is a reply to message #88023] Mon, 20 November 2006 10:57 Go to previous message
Yes, today itself, I discovered, that if I delete the .metadata folder from
eclipse workspace and configure the project again, then this problem is gone
else this problem keep creeping up, this is what I have experienced so far,
though I am starter in using TPTP, not an expert ;-) I m using an Integrated
Agent Controller.
Thanks.
"Bevan DeQueker" <dequeker@gmail.com> wrote in message
news:ejsilg$ccl$2@utils.eclipse.org...
> agent controler ?
> Ravi Roy wrote:
>> Hi All,
>> Regards
>> Ravi.
>> test.execution:
>> Test started!
>> executing
>> at
>> at
>> at
>> at
>> Waiting...
>> at
>> at
>> at
>> at
Previous Topic:AGR like Web Application Testing
Next Topic:[AGR] NoClassDefFoundError while running test
Current Time: Thu Jul 24 17:25:48 EDT 2025
Powered by FUDForum. Page generated in 0.08430 seconds
