Home » Eclipse Projects » Eclipse Platform » Why plug-in depends on its fragment(s)?
Why plug-in depends on its fragment(s)? [message #878658] Tue, 29 May 2012 13:00 Go to next message
Hello everybody!
I don't understand why plugin depends on its fragment. Consider this
simple scenario:
Main application resides in "plugin.a". According to "best practises"
test are placed in fragment "plugin.a.test".
Dependency tree for "plugin.a" looks like this:
plugin.a
+ some.plugin
+ some.other.plugin
+ plugin.a.test <== Why?
I fully understand that fragment depends on its host, but why also
vice-versa?
Because I use fragments for tests (i18n is no matter for me), these
fragments themselves depend on org.junit bundle:
plugin.a.test
+ org.junit
Thus result dependency tree is:
plugin.a
+ some.plugin
+ some.other.plugin
+ plugin.a.test
+ org.junit
And dependency calculators like "Add required" button in Run
Configuration always add test fragments and org.junit. For my point of
view it is undesirable and only pollute it.
Am I missing something or it is normal? How to workaround this?
Libor
Re: Why plug-in depends on its fragment(s)? [message #880176 is a reply to message #878658] Fri, 01 June 2012 10:58 Go to previous messageGo to next message
What does the manifest and fragment.xml look like in your plugin.a.test? What does plugin.a MANIFEST.MF say?
Plugin's generally don't have a dependency on any fragments. By definition, a fragment requires its host bundle.
PW
Re: Why plug-in depends on its fragment(s)? [message #882284 is a reply to message #880176] Wed, 06 June 2012 03:27 Go to previous message
Hello Paul,
I observed that it's only "Plug-in Dependencies" view thing. I was
learning about OSGi dependencies and I used this view to confirm my
"mental model" how dependencies work. PDE is trying to be helpful and,
by default, shows fragments in tree in the same ways as true depending
plug-ins.
Anyway, thank you!
Libor
> PW
Previous Topic:org.eclipse.core.runtime.adaptor.FileManager cannot be resolved
Next Topic:internal classes v.s. API
Current Time: Sat Jul 26 09:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.04028 seconds
