Home » Eclipse Projects » Eclipse Platform » Reuse the same menu contributions at multiple places
Reuse the same menu contributions at multiple places [message #873546] Fri, 18 May 2012 09:59 Go to next message
Basically, I want to re-use the same menu contributions at multiple places. I have a set of commands which will make up as either popup menu (in any view or dialog) or in the main menu. Is there any way to define a group for these set of commands, and whenever I want to define the menu, I can just reference the command group instead of referencing all the commands individually ?
If I have to change the order of menu items at once place, then I have to change the order of referenced commands at all the places where it has been used either as popup, view menu or main menu. Instead if there is something like command groups, we just need to change in the group.
Re: Reuse the same menu contributions at multiple places [message #880174 is a reply to message #873546] Fri, 01 June 2012 10:55 Go to previous message
A submenu could be shared in a menubar menu and a view menu. In that you could add the submenu in the 2 places, but have another menu contribution to the submenu that contained your commands.
But because they're in a different scheme (menu vs popup) you would be able to use that trick with the main menu/view menu and a popup menu.
PW
Previous Topic:Maven and Eclipse: there is no way to import the glassfish projet (100's of modules) using Eclipse.
Next Topic:Invalid preference page path: XML Syntax
Current Time: Sat Jul 26 19:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.03302 seconds
