Home » Modeling » TMF (Xtext) » [Solved] How to configure a custom QualifiedNameProvider?(Guice binding error)
[Solved] How to configure a custom QualifiedNameProvider? [message #879797] Thu, 31 May 2012 17:28 Go to next message
I've created a custom QualifiedName provider (extends DefaultDeclarativeQualifiedNameProvider) and configured in the Runtime module as follows:
public class OoaRuntimeModule extends org.domainmodels.AbstractOoaRuntimeModule {
    public void configure(Binder binder) {
        super.configure(binder);
        binder
        .bind(IQualifiedNameProvider.class)
        .to(OoaQualifiedNameProvider.class);
When I try to create a runtime instance however Guice throws an exception:
1) A binding to org.eclipse.xtext.naming.IQualifiedNameProvider was already configured at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55).
  at org.domainmodels.OoaRuntimeModule.configure(OoaRuntimeModule.java:27)
I tried commenting out the fragment in the .mwe2 file but to no avail.
      //fragment = exporting.QualifiedNamesFragment {}
What am I missing? Thanks.
[Updated on: Fri, 01 June 2012 03:36] by Moderator
Re: How to configure a custom QualifiedNameProvider? [message #879802 is a reply to message #879797] Thu, 31 May 2012 17:39 Go to previous messageGo to next message
> module as follows:
> @Override
> binder
The interface is bound to an implementation elsewhere. Look for a method
called something like bindIQualifiedNameProvider and override it to
perform your own binding. (I have not looked what it is actually called,
look up the inheritance chain from your module as a starting point.
- henrik
Re: How to configure a custom QualifiedNameProvider? [message #879952 is a reply to message #879802] Fri, 01 June 2012 03:35 Go to previous message
Solved.
Look for a method
Thanks. I thought that including the binding in OoaRuntimeModule.configure() would do the trick but it doesn't. However it works with a specific override, i.e. defining in OoaRuntimeModule.bindIQualifiedNameProvider().
Previous Topic:Problem with imported model when referencing Xbase and JavaVMTypes models
Next Topic:Xbase: overwrite the Operator '='
Current Time: Mon Jul 21 11:35:57 EDT 2025
Powered by FUDForum. Page generated in 1.28830 seconds
