Home » Eclipse Projects » Rich Client Platform (RCP) » Different splash screens
Different splash screens [message #879920] Fri, 01 June 2012 01:57 Go to next message
We have an Eclipse RCP application developed with Eclipse 3.6.2 that supports different licensing schemes. For each scheme it must have a different splash screen.
Is it possible to specify from the code which splash screen should be loaded?
I looked at the org.eclipse.ui.splashHandlers extension point. However, it allows only to decorate existing splash so the default splash.bmp will appear before splashHandlers class started its execution.
Thanks in advance!
-AJ
Re: Different splash screens [message #880058 is a reply to message #879920] Fri, 01 June 2012 06:43 Go to previous messageGo to next message
IMHO it will not be possible. Splash is drawn by native-code launcher at
the very beginning and tightly to product definition.
There is only a mechanism to have different splashscreents for various
languages.
But why not have break down your app to a few of different products
based on your licencing schemes? If products will be feature-based you
can easily share single plugin collection making your app throughout all
products.
Libor
> loaded?
> Thanks in advance!
> -AJ
Re: Different splash screens [message #886044 is a reply to message #880058] Thu, 14 June 2012 01:45 Go to previous message
It's definitely not possible. I think the suggestion with different products would be a good solution.
Previous Topic:Reusing workspace selection dialog in RCP application
Next Topic:Tile Editor horizontal/vertical programmatically
Current Time: Wed Jul 23 21:05:40 EDT 2025
Powered by FUDForum. Page generated in 0.04954 seconds
