How to avoid ReferenceError error messages? [message #879542] |
Thu, 31 May 2012 07:53  |
With this report design:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.23" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 3.7.2.v20120213 Build <3.7.2.v20120214-1408></property>
<text-property name="title">Manual Data Entry</text-property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">89</property>
<parameters>
<cascading-parameter-group name="Parameters" id="27">
<text-property name="promptText">Parameters</text-property>
<property name="dataSet">InputsParameters</property>
<property name="dataSetMode">single</property>
<parameters>
<scalar-parameter name="inputURL" id="28">
<property name="valueType">dynamic</property>
<property name="isRequired">false</property>
<property name="dataSetName">InputsParameters</property>
<expression name="valueExpr">row["inputURL"]</expression>
<expression name="labelExpr">row["displayText"]</expression>
<property name="dataType">string</property>
<simple-property-list name="defaultValue">
<value type="javascript">null</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<structure name="format"/>
</scalar-parameter>
<scalar-parameter name="paramName" id="29">
<expression name="valueExpr">row["paramName"]</expression>
<expression name="labelExpr">row["paramName"]</expression>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
<scalar-parameter name="measureTime" id="40">
<property name="hidden">true</property>
<text-property name="promptText">Measure Time</text-property>
<property name="valueType">static</property>
<property name="dataType">dateTime</property>
<property name="distinct">true</property>
<value type="javascript">new Date()</value>
<list-property name="selectionList"/>
<property name="concealValue">true</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="measureValue" id="41">
<text-property name="promptText">Value</text-property>
<value type="javascript">""</value>
</structure>
</scalar-parameter>
<scalar-parameter name="inputParameter" id="45">
<expression name="valueExpr" type="javascript">dataSetRow.inputURL + " - " + dataSetRow.paramName</expression>
<property name="mustMatch">false</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<script-data-source name="Main Data Source" id="30"/>
</data-sources>
<data-sets>
<script-data-set name="InputsParameters" id="31">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">inputURL</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">displayText</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">paramName</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">inputURL</property>
<text-property name="displayName">Input URL</text-property>
</structure>
<structure>
<property name="columnName">displayText</property>
<text-property name="displayName">Input</text-property>
</structure>
<structure>
<property name="columnName">paramName</property>
<text-property name="displayName">Parameter</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Main Data Source</property>
<method name="open"><![CDATA[inputs = AWPData.GetInputs();
count = 0;
input = null;]]></method>
<method name="fetch"><![CDATA[if (count < inputs.size()) {
parameterNode = inputs.get(count);
fb = parameterNode.fb();
row.inputURL = fb.url;
row.displayText = fb.name + " - " + fb.url;
row.paramName = parameterNode.parameter().name;
count++;
return true;
return false;]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<label id="47">
<property name="fontSize">x-large</property>
<text-property name="text">Manual Data Entry</text-property>
</label>
<extended-item extensionName="ComboBox" name="inputParameter" id="46">
<property name="label">Object URL - Attribute name</property>
<expression name="bookmark">inputParameter</expression>
</extended-item>
<extended-item extensionName="DateTimePicker" name="measureTime" id="42">
<property name="label">Time</property>
<expression name="bookmark">measureTime</expression>
</extended-item>
<extended-item extensionName="TextBox" name="measureValue" id="43">
<property name="label">Value</property>
<expression name="bookmark">measureValue</expression>
</extended-item>
<extended-item extensionName="Button" id="44">
<property name="text">"Submit Data"</property>
<property name="onclick">urlAttrNameText = document.getElementById("inputParameter").value.split(' - ');
url = urlAttrNameText[0];
attrName = urlAttrNameText[1];
timeStr = document.getElementById("measureTime").value;
valueStr = document.getElementById("measureValue").value;
alert("Sending command to server: set "+attrName+" of "+url+" to "+valueStr+" at "+timeStr);
SetAttributeValue(url, attrName, timeStr, valueStr);</property>
<property name="isrefresh">false</property>
</extended-item>
</body>
</report>
The report itself works fine: the proper function is called when the button is clicked, the combobox is filled correctly. But the problem is that I see error messages when the report is shown, under the report itself:
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "inputParameter":
ReferenceError: "inputParameter" is not defined. (<inline>#1) (Element ID:1)
+ There are errors evaluating script "measureTime":
ReferenceError: "measureTime" is not defined. (<inline>#1) (Element ID:1)
+ There are errors evaluating script "measureValue":
ReferenceError: "measureValue" is not defined. (<inline>#1) (Element ID:1)
There is no element with id="1" in the report source, so I am not clear what the errors refer to. I've added default values for parameters, as seen above, but this didn't help. How can I avoid those error messages?
My own controls are used in the report, but I've checked that they don't throw exceptions while generating HTML.
[Updated on: Thu, 31 May 2012 08:08] by Moderator
Re: How to avoid ReferenceError error messages? [message #879789 is a reply to message #879542] |
Thu, 31 May 2012 17:05   |
I believe this is complaining because of bookmark expressions.
For example:
id="42">
</extended-item>
measureTime does not evaluate.
Jason
> id="1">
> <parameters>
> <parameters>
> </scalar-parameter>
> </scalar-parameter>
> </parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> count = 0;
> count++;
> return true;
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <label id="47">
> </label>
> </extended-item>
> </extended-item>
> </extended-item>
> </extended-item>
> </body>
> </report>
> itself:
FUDForum. Page generated in 0.02772 seconds
