Home » Archived » Visual Editor (VE) » How to create SWT layouts under VE?
How to create SWT layouts under VE? [message #87748] Wed, 20 April 2005 08:15 Go to next message
I started SWT by creating controls manually. Now with that experienece I
want to use the VE to save working time.
I can place now different controls on the Shell but I do not know if there
is a way to create/maintain layouts such as RowLayout, GridLayout etc. using
VE?
Thanks for any help,
best regards,
Mr. Burns
Re: How to create SWT layouts under VE? [message #87818 is a reply to message #87748] Wed, 20 April 2005 09:57 Go to previous messageGo to next message
> VE?
To find out more open Help>Contents and browse to "Using the Visual
Editor for Java" / "Editing Java in the Visual Editor" / "Developing
Java classes with the Visual Editor" / "Laying out components using the
Visual Editor" / "SWT Layout managers".
To swith the layout manager of your shell use the Properties sheet and
select a new one from the "layout" property list.
Joe
Re: How to create SWT layouts under VE? [message #87973 is a reply to message #87818] Thu, 21 April 2005 02:57 Go to previous message
Thanks, that helped a lot!
"Joe Winchester" <winchest@uk.ibm.com> schrieb im Newsbeitrag
news:d45n5p$4dl$1@news.eclipse.org...
>> there is a way to create/maintain layouts such as RowLayout, GridLayout
>> etc. using VE?
> To find out more open Help>Contents and browse to "Using the Visual Editor
> for Java" / "Editing Java in the Visual Editor" / "Developing Java
> classes with the Visual Editor" / "Laying out components using the Visual
> Best regards,
> Joe
Re: How to create SWT layouts under VE? [message #607190 is a reply to message #87748] Wed, 20 April 2005 09:57 Go to previous message
> VE?
Joe
Re: How to create SWT layouts under VE? [message #607201 is a reply to message #87818] Thu, 21 April 2005 02:57 Go to previous message
>> etc. using VE?
> Best regards,
> Joe
Previous Topic:Icons on the custom widgets in VE are not visible
Next Topic:Initialise an object inside of VE
Current Time: Fri Jul 18 13:29:47 EDT 2025
Powered by FUDForum. Page generated in 0.07119 seconds
