Home » Eclipse Projects » Equinox » Exception during processing of http post
Exception during processing of http post [message #87945] Fri, 11 May 2007 02:49 Go to next message
Originally posted by: fireresq.embarqmail.com
I have an equinox 33M7 server running and everything is fine on Windows.
However when I run on Linux I get the following errors:
Exception in thread "SocketListener0-0" java.lang.NoClassDefFoundError:
javax/net/ssl/SSLSocket
at org.mortbay.http.HttpConnection.close(HttpConnection.java:26 9)
at org.mortbay.http.HttpConnection.destroy(HttpConnection.java: 1148)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 43)
at
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
What confuses me is I am not even using SSL so why am I getting this error?
Most of the time I get this error some times the request goes through.
I am running CentOS for my Linux
Thanks in advance for any help!
Mark
Re: Exception during processing of http post [message #87962 is a reply to message #87945] Fri, 11 May 2007 09:29 Go to previous messageGo to next message
Jetty has code in HttpConnection.close() that checks whether the underlying
socket is an instance of SSLSocket.
Unfortunately since this check is done in the HttpConnection superclass this
dependency is brought in even if you're not using SSL.
That said, I'm curious how the bundle is resolving because javax.net.ssl is
a dependency.
Do you know what VM and version is being used?
Are you embedding the JSSE classes in a bundle somewhere?
-Simon
"Mark Russell" <fireresq@embarqmail.com> wrote in message
news:f213mf$fgl$1@build.eclipse.org...
> at
> at
> error?
> Mark
Re: Exception during processing of http post [message #88005 is a reply to message #87962] Fri, 11 May 2007 13:37 Go to previous messageGo to next message
VM sun standard edition build 1.5.0_11-b03
I did a search for the class in eclipse and the only place I can find
the SSLSocket is in the JRESystemLibrary only I don't include it anywhere
> a dependency.
> -Simon
>> at
>> at
>> error?
>> Mark
Re: Exception during processing of http post [message #88020 is a reply to message #88005] Fri, 11 May 2007 15:15 Go to previous messageGo to next message
Strange. It almost like jsse.jar isn't on your boot class path.
It probably is but try "getprop sun.boot.class.path" ??
You might also create a dummy bundle that tries something like
context.getBundle().loadClass("javax.net.ssl.SSLSocket") as a sanity check
and if it fails walk the class loader to try and figure out what's going on.
-Simon
news:f229ki$j3e$1@build.eclipse.org...
>> underlying
>> this
>> is
>> a dependency.
>> -Simon
>>> at
>>> at
>>> at
>>> at
>>> at
>>> error?
>>> Mark
Re: Exception during processing of http post [message #89268 is a reply to message #88020] Fri, 01 June 2007 09:18 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I finally go back to this and tried what you asked.
the jsse.jar is on the boot classpath
I added the code to my start method of the activator class in the
application bundle like you asked and it could load the SSLSocket with
no problem but I still get the same exception.
Any more ideas?
here is what my ss looks like:
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070430
1 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
2 ACTIVE org.eclipse.update.configurator_3.2.100.v20070430
3 ACTIVE org.eclipse.osgi.services_3.1.100.v20060918
4 ACTIVE javax.servlet_2.4.0.v200704241052
5 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.v20070402
6 ACTIVE org.apache.commons.logging_1.0.4.v200701082340
7 ACTIVE org.mortbay.jetty_5.1.11.v200701082340
8 ACTIVE org.eclipse.equinox.http.jetty_1.0.0.v20070427
9 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070416
10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.v20070326
11 ACTIVE com.google.gwt_0.6.0
12 ACTIVE com.instantiations.gwt.sample.client_0.6.0
> -Simon
>>> underlying
>>> this
>>> is
>>> a dependency.
>>> -Simon
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> error?
>>>> Mark
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (Cygwin)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGYByfyHA2ZZVyicQRAmtAAJ9ZFAxCCK6l/jdLOpdw/fRsvursLgCb BNkv
jn8bOnRJ+K7SB68fUUWM0zg=
=Ywwc
-----END PGP SIGNATURE-----
Re: Exception during processing of http post [message #89283 is a reply to message #89268] Fri, 01 June 2007 09:41 Go to previous messageGo to next message
Very strange.
Can you attach the contents of a "getprop"
news:f3p685$iub$1@build.eclipse.org...
> Hash: SHA1
> Any more ideas?
> id State Bundle
>> check
>> on.
>> -Simon
>>> anywhere
>>>> underlying
>>>> this
>>>> javax.net.ssl
>>>> is
>>>> a dependency.
>>>> -Simon
>>>>> Windows.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> error?
>>>>> Mark
> =Ywwc
Re: Exception during processing of http post [message #89298 is a reply to message #89283] Fri, 01 June 2007 10:05 Go to previous messageGo to next message
--------------090809000203020109070803
Content-Type: text/plain; charset=ISO-8859-1
here it is
Simon Kaegi wrote:
> Very strange.
> Any more ideas?
> id State Bundle
>>>> check
>>>> on.
>>>> -Simon
>>>>> anywhere
>>>>>> underlying
>>>>>> this
>>>>>> javax.net.ssl
>>>>>> is
>>>>>> a dependency.
>>>>>> -Simon
>>>>>>> Windows.
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> error?
>>>>>>> Mark
name="telnet.log"
Content-Disposition: inline;
filename="telnet.log"
osgi> getprop
org.mortbay.log.LogFactory.noDiscovery=true
org.osgi.service.http.port=8080
sun.java.launcher=SUN_STANDARD
org.osgi.supports.framework.extension=true
sun.management.compiler=HotSpot Client Compiler
osgi.framework.beginningstartlevel=1
os.name=Linux
sun.boot.class.path=/opt/jdk1.5.0_11/jre/lib/rt.jar:/opt/jdk 1.5.0_11/jre/lib/i18n.jar:/opt/jdk1.5.0_11/jre/lib/sunrsasig n.jar:/opt/jdk1.5.0_
11/jre/lib/jsse.jar:/opt/jdk1.5.0_11/jre/lib/jce.jar:/opt/jd k1.5.0_11/jre/lib/charsets.jar:/opt/jdk1.5.0_11/jre/classes
osgi.ws=motif
java.vm.specification.vendor=Sun Microsystems Inc.
java.runtime.version=1.5.0_11-b03
osgi.noShutdown=true
user.name=markr
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,j
avax.imageio.event,javax.imageio.metadata,javax.imageio.plug ins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.i mageio.stream,javax.
management,javax.management.loading,javax.management.modelmb ean,javax.management.monitor,javax.management.openmbean,java x.management.relatio
n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.na
ming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.pri nt,javax.print.attribute,javax.print.attribute.standard,java x.print.event,javax.
rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax. security.auth.callback,javax.security.auth.kerberos,javax.se curity.auth.login,ja
vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sam
pled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,java x.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.s wing.border,javax.sw
ing.colorchooser,javax.swing.event,javax.swing.filechooser,j avax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.meta l,javax.swing.plaf.m
ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax
..swing.tree,javax.swing.undo,javax.transaction,javax.transa ction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,ja vax.xml.parsers,javax
..xml.transform,javax.xml.transform.dom,javax.xml.transform. sax,javax.xml.transform.stream,javax.xml.validation,javax.xm l.xpath,org.ietf.jgss
,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.
omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNamin g.NamingContextExtPackage,org.omg.CosNaming.NamingContextPac kage,org.omg.Dynamic
,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage, org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.Cod ecFactoryPackage,org
..omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,or
g.omg.PortableServer.CurrentPackage,org.omg.PortableServer.P OAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.P ortableServer.portab
le,org.omg.PortableServer.ServantLocatorPackage,org.omg.Send ingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.boo tstrap,org.w3c.dom.e
vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.language=en
user.language=en
org.osgi.framework.processor=i386
osgi.syspath=/opt/OSGi/eclipse/plugins
sun.boot.library.path=/opt/jdk1.5.0_11/jre/lib/i386
osgi.manifest.cache=/opt/OSGi/eclipse/configuration/org.ecli pse.osgi/manifests
osgi.compatibility.bootdelegation=false
eof=eof
java.version=1.5.0_11
org.osgi.framework.os.name=Linux
user.timezone=America/New_York
sun.arch.data.model=32
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.osgi.services@start, javax.servlet@sta
rt, org.eclipse.equinox.http.servlet@start, org.apache.commons.logging@start, org.mortbay.jetty@start, org.eclipse.equinox.http.jetty@start,
org.eclipse.equinox.registry@start, org.eclipse.equinox.http.registry@start, org.eclipse.equinox.http.servlet@start, com.google.gwt@start,
com.instantiations.gwt.sample.client@start
java.endorsed.dirs=/opt/jdk1.5.0_11/jre/lib/endorsed
sun.cpu.isalist=
sun.jnu.encoding=UTF-8
file.encoding.pkg=sun.io
org.osgi.framework.vendor=Eclipse
file.separator=/
java.specification.name=Java Platform API Specification
java.class.version=49.0
user.country=US
java.home=/opt/jdk1.5.0_11/jre
osgi.os=linux
java.vm.info=mixed mode, sharing
os.version=2.6.9-42.0.10.EL
osgi.arch=x86
path.separator=:
java.vm.version=1.5.0_11-b03
org.osgi.supports.framework.fragment=true
osgi.console=8580
java.awt.printerjob=sun.print.PSPrinterJob
sun.io.unicode.encoding=UnicodeLittle
org.osgi.framework.version=1.4.0
osgi.install.area=file:/opt/OSGi/eclipse/plugins/
osgi.framework=file:/opt/OSGi/eclipse/plugins/org.eclipse.os gi_3.3.0.v20070430.jar
user.home=/home/markr
osgi.bundlestore=/opt/OSGi/eclipse/configuration/org.eclipse .osgi/bundles
java.specification.vendor=Sun Microsystems Inc.
osgi.nl=en_US
java.library.path=/opt/jdk1.5.0_11/jre/lib/i386/client:/opt/ jdk1.5.0_11/jre/lib/i386:/opt/jdk1.5.0_11/jre/../lib/i386
java.vendor.url=http://java.sun.com/
org.osgi.framework.os.version=2.6.9-42.0.10.EL
eclipse.startTime=1180706471416
java.vm.vendor=Sun Microsystems Inc.
eclipse.ignoreApp=true
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.class.path=plugins/org.eclipse.osgi_3.3.0.v20070430.jar
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.version=1.0
sun.cpu.endian=little
sun.os.patch.level=unknown
java.io.tmpdir=/tmp
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
os.arch=i386
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.ext.dirs=/opt/jdk1.5.0_11/jre/lib/ext
user.dir=/opt/OSGi/eclipse
org.osgi.supports.framework.requirebundle=true
osgi.clean=true
line.separator=
java.vm.name=Java HotSpot(TM) Client VM
eclipse.ee.install.verify=false
file.encoding=UTF-8
osgi.framework.version=3.3.0.v20070430
java.specification.version=1.5
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
osgi.logfile=/opt/OSGi/eclipse/configuration/1180706471647.l og
osgi.configuration.area=file:/opt/OSGi/eclipse/configuration /
osgi> close
--------------090809000203020109070803--
Re: Exception during processing of http post [message #89358 is a reply to message #89298] Fri, 01 June 2007 10:32 Go to previous messageGo to next message
Ah...
I see the problem.
You're using an old version of the org.mortbay.jetty bundle.
Specifically that version lacks the imports for javax.net.ssl and a few
other packages.
Try updating to the latest version of that bundle from orbit [
http://download.eclipse.org/tools/orbit/downloads/ ]or get it from RC2.
-Simon
news:f3p901$1an$1@build.eclipse.org...
> here it is
> Simon Kaegi wrote:
>> Very strange.
>> Any more ideas?
>> id State Bundle
>>>>> check
>>>>> going
>>>>> on.
>>>>> -Simon
>>>>>> anywhere
>>>>>>> underlying
>>>>>>> superclass
>>>>>>> this
>>>>>>> javax.net.ssl
>>>>>>> is
>>>>>>> a dependency.
>>>>>>> -Simon
>>>>>>>> Windows.
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> this
>>>>>>>> error?
>>>>>>>> through.
>>>>>>>> Mark
> osgi> getprop
> os.name=Linux
> osgi.ws=motif
> user.name=markr
> .swing.tree,javax.swing.undo,javax.transaction,javax.transac tion.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,jav ax.xml.parsers,javax
> .xml.transform,javax.xml.transform.dom,javax.xml.transform.s ax,javax.xml.transform.stream,javax.xml.validation,javax.xml .xpath,org.ietf.jgss
> .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,or
> user.language=en
> eof=eof
> javax.servlet@sta
> sun.cpu.isalist=
> file.separator=/
> user.country=US
> osgi.os=linux
> osgi.arch=x86
> path.separator=:
> osgi.console=8580
> osgi.nl=en_US
> java.io.tmpdir=/tmp
> os.arch=i386
> osgi.clean=true
> line.separator=
> file.encoding=UTF-8
> osgi> close
Re: Exception during processing of http post [message #89385 is a reply to message #89358] Fri, 01 June 2007 10:48 Go to previous messageGo to next message
Thank you for your help and persistence on this issue.
I'll do that and let you know the results.
Simon Kaegi wrote:
> Ah...
> I see the problem.
> other packages.
> -Simon
>> here it is
>> Simon Kaegi wrote:
>>> Very strange.
>>> Any more ideas?
>>> id State Bundle
>>>>>> check
>>>>>> going
>>>>>> on.
>>>>>> -Simon
>>>>>>> anywhere
>>>>>>>> underlying
>>>>>>>> superclass
>>>>>>>> this
>>>>>>>> javax.net.ssl
>>>>>>>> is
>>>>>>>> a dependency.
>>>>>>>> -Simon
>>>>>>>>> Windows.
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> this
>>>>>>>>> error?
>>>>>>>>> through.
>>>>>>>>> Mark
>> osgi> getprop
>> os.name=Linux
>> osgi.ws=motif
>> user.name=markr
>> user.language=en
>> eof=eof
>> javax.servlet@sta
>> sun.cpu.isalist=
>> file.separator=/
>> user.country=US
>> osgi.os=linux
>> osgi.arch=x86
>> path.separator=:
>> osgi.console=8580
>> osgi.nl=en_US
>> java.io.tmpdir=/tmp
>> os.arch=i386
>> osgi.clean=true
>> line.separator=
>> file.encoding=UTF-8
>> osgi> close
Re: Exception during processing of http post [message #89431 is a reply to message #89358] Fri, 01 June 2007 11:11 Go to previous message
Thank you very much. That worked. Sorry for not trying the latest
version before asking for help.
Simon Kaegi wrote:
> Ah...
> I see the problem.
> other packages.
> -Simon
>> here it is
>> Simon Kaegi wrote:
>>> Very strange.
>>> Any more ideas?
>>> id State Bundle
>>>>>> check
>>>>>> going
>>>>>> on.
>>>>>> -Simon
>>>>>>> anywhere
>>>>>>>> underlying
>>>>>>>> superclass
>>>>>>>> this
>>>>>>>> javax.net.ssl
>>>>>>>> is
>>>>>>>> a dependency.
>>>>>>>> -Simon
>>>>>>>>> Windows.
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> this
>>>>>>>>> error?
>>>>>>>>> through.
>>>>>>>>> Mark
>> osgi> getprop
>> os.name=Linux
>> osgi.ws=motif
>> user.name=markr
>> user.language=en
>> eof=eof
>> javax.servlet@sta
>> sun.cpu.isalist=
>> file.separator=/
>> user.country=US
>> osgi.os=linux
>> osgi.arch=x86
>> path.separator=:
>> osgi.console=8580
>> osgi.nl=en_US
>> java.io.tmpdir=/tmp
>> os.arch=i386
>> osgi.clean=true
>> line.separator=
>> file.encoding=UTF-8
>> osgi> close
Previous Topic:Configure Jetty from an external file
Next Topic:Equinox in a servlet container and container dependencies
Current Time: Wed Sep 10 19:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.05061 seconds
