Cannot seem to be able to compile with -O2 [message #879039] |
Wed, 30 May 2012 08:16  |
Please help me this is driving me crazy !
Well what I get in the build output is :
Debug :
**** Build of configuration Debug for project asfaleia_hw3 ****
**** Internal Builder is used for build ****
g++ -O0 -g3 -Wall -c -fmessage-length=0 -o main.o ..\main.cpp
g++ -o asfaleia_hw3.exe main.o
Release :
**** Rebuild of configuration Release for project asfaleia_hw3 ****
g++ -O3 -Wall -c -fmessage-length=0 -o main.o ..\main.cpp
But I have specified -O2 as the compiler argument : ht tp: //www.bild.me/bild.php?file=3110466-O2.jpg
debug : ht tp: //www.bild.me/bild.php?file=4209407debug-O2.jpg
Till some point it was working great - I changed some workspace settings but not sure what's wrong
My .cproject :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?fileVersion 4.0.0?>
<cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage">
<storageModule moduleId="org.eclipse.cdt.core.settings">
<cconfiguration id="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807">
<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807" moduleId="org.eclipse.cdt.core.settings" name="Debug">
<externalSettings/>
<extensions>
<extension id="org.eclipse.cdt.core.PE" point="org.eclipse.cdt.core.BinaryParser"/>
<extension id="org.eclipse.cdt.core.GCCErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GASErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GLDErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
</extensions>
</storageModule>
<storageModule moduleId="cdtBuildSystem" version="4.0.0">
<configuration artifactName="${ProjName}" buildArtefactType="org.eclipse.cdt.build.core.buildArtefactType.exe" buildProperties="org.eclipse.cdt.build.core.buildType=org.eclipse.cdt.build.core.buildType.debug,org.eclipse.cdt.build.core.buildArtefactType=org.eclipse.cdt.build.core.buildArtefactType.exe" cleanCommand="rm -rf" description="" id="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807" name="Debug" parent="cdt.managedbuild.config.gnu.mingw.exe.debug">
<folderInfo id="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807." name="/" resourcePath="">
<toolChain id="cdt.managedbuild.toolchain.gnu.mingw.exe.debug.1469459977" name="MinGW GCC" superClass="cdt.managedbuild.toolchain.gnu.mingw.exe.debug">
<targetPlatform id="cdt.managedbuild.target.gnu.platform.mingw.exe.debug.1255650963" name="Debug Platform" superClass="cdt.managedbuild.target.gnu.platform.mingw.exe.debug"/>
<builder buildPath="${workspace_loc:/asfaleia_hw3/Debug}" id="cdt.managedbuild.tool.gnu.builder.mingw.base.1637975568" keepEnvironmentInBuildfile="false" managedBuildOn="true" name="CDT Internal Builder" superClass="cdt.managedbuild.tool.gnu.builder.mingw.base"/>
<tool id="cdt.managedbuild.tool.gnu.assembler.mingw.exe.debug.1101398299" name="GCC Assembler" superClass="cdt.managedbuild.tool.gnu.assembler.mingw.exe.debug">
<inputType id="cdt.managedbuild.tool.gnu.assembler.input.1125135213" superClass="cdt.managedbuild.tool.gnu.assembler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.archiver.mingw.base.1819688634" name="GCC Archiver" superClass="cdt.managedbuild.tool.gnu.archiver.mingw.base"/>
<tool id="cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.debug.914486801" name="GCC C++ Compiler" superClass="cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.debug">
<option id="gnu.cpp.compiler.mingw.exe.debug.option.optimization.level.2055394106" name="Optimization Level" superClass="gnu.cpp.compiler.mingw.exe.debug.option.optimization.level" value="gnu.cpp.compiler.optimization.level.none" valueType="enumerated"/>
<option id="gnu.cpp.compiler.mingw.exe.debug.option.debugging.level.2101351781" name="Debug Level" superClass="gnu.cpp.compiler.mingw.exe.debug.option.debugging.level" value="gnu.cpp.compiler.debugging.level.max" valueType="enumerated"/>
<inputType id="cdt.managedbuild.tool.gnu.cpp.compiler.input.1098279938" superClass="cdt.managedbuild.tool.gnu.cpp.compiler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.debug.832048799" name="GCC C Compiler" superClass="cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.debug">
<option defaultValue="gnu.c.optimization.level.none" id="gnu.c.compiler.mingw.exe.debug.option.optimization.level.602051395" name="Optimization Level" superClass="gnu.c.compiler.mingw.exe.debug.option.optimization.level" valueType="enumerated"/>
<option id="gnu.c.compiler.mingw.exe.debug.option.debugging.level.1092630975" name="Debug Level" superClass="gnu.c.compiler.mingw.exe.debug.option.debugging.level" value="gnu.c.debugging.level.max" valueType="enumerated"/>
<inputType id="cdt.managedbuild.tool.gnu.c.compiler.input.278354826" superClass="cdt.managedbuild.tool.gnu.c.compiler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.c.linker.mingw.exe.debug.1747948330" name="MinGW C Linker" superClass="cdt.managedbuild.tool.gnu.c.linker.mingw.exe.debug"/>
<tool id="cdt.managedbuild.tool.gnu.cpp.linker.mingw.exe.debug.858032385" name="MinGW C++ Linker" superClass="cdt.managedbuild.tool.gnu.cpp.linker.mingw.exe.debug">
<inputType id="cdt.managedbuild.tool.gnu.cpp.linker.input.4685161" superClass="cdt.managedbuild.tool.gnu.cpp.linker.input">
<additionalInput kind="additionalinputdependency" paths="$(USER_OBJS)"/>
<additionalInput kind="additionalinput" paths="$(LIBS)"/>
</inputType>
</tool>
</toolChain>
</folderInfo>
</configuration>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
</cconfiguration>
<cconfiguration id="cdt.managedbuild.config.gnu.mingw.exe.release.586289962">
<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="cdt.managedbuild.config.gnu.mingw.exe.release.586289962" moduleId="org.eclipse.cdt.core.settings" name="Release">
<externalSettings/>
<extensions>
</extensions>
</storageModule>
<configuration artifactName="${ProjName}" buildArtefactType="org.eclipse.cdt.build.core.buildArtefactType.exe" buildProperties="org.eclipse.cdt.build.core.buildType=org.eclipse.cdt.build.core.buildType.release,org.eclipse.cdt.build.core.buildArtefactType=org.eclipse.cdt.build.core.buildArtefactType.exe" cleanCommand="rm -rf" description="" id="cdt.managedbuild.config.gnu.mingw.exe.release.586289962" name="Release" parent="cdt.managedbuild.config.gnu.mingw.exe.release">
<folderInfo id="cdt.managedbuild.config.gnu.mingw.exe.release.586289962." name="/" resourcePath="">
<toolChain id="cdt.managedbuild.toolchain.gnu.mingw.exe.release.610511666" name="MinGW GCC" superClass="cdt.managedbuild.toolchain.gnu.mingw.exe.release">
<targetPlatform id="cdt.managedbuild.target.gnu.platform.mingw.exe.release.2059844021" name="Debug Platform" superClass="cdt.managedbuild.target.gnu.platform.mingw.exe.release"/>
<builder buildPath="${workspace_loc:/asfaleia_hw3/Release}" id="cdt.managedbuild.tool.gnu.builder.mingw.base.1819028856" keepEnvironmentInBuildfile="false" managedBuildOn="true" name="CDT Internal Builder" superClass="cdt.managedbuild.tool.gnu.builder.mingw.base"/>
<tool id="cdt.managedbuild.tool.gnu.assembler.mingw.exe.release.1155961527" name="GCC Assembler" superClass="cdt.managedbuild.tool.gnu.assembler.mingw.exe.release">
<inputType id="cdt.managedbuild.tool.gnu.assembler.input.647267910" superClass="cdt.managedbuild.tool.gnu.assembler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.archiver.mingw.base.2008065399" name="GCC Archiver" superClass="cdt.managedbuild.tool.gnu.archiver.mingw.base"/>
<tool id="cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.release.282792496" name="GCC C++ Compiler" superClass="cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.release">
<option id="gnu.cpp.compiler.mingw.exe.release.option.optimization.level.775607160" name="Optimization Level" superClass="gnu.cpp.compiler.mingw.exe.release.option.optimization.level" value="gnu.cpp.compiler.optimization.level.most" valueType="enumerated"/>
<option id="gnu.cpp.compiler.mingw.exe.release.option.debugging.level.1702343683" name="Debug Level" superClass="gnu.cpp.compiler.mingw.exe.release.option.debugging.level" value="gnu.cpp.compiler.debugging.level.none" valueType="enumerated"/>
<inputType id="cdt.managedbuild.tool.gnu.cpp.compiler.input.595440934" superClass="cdt.managedbuild.tool.gnu.cpp.compiler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.release.1940416028" name="GCC C Compiler" superClass="cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.release">
<option defaultValue="gnu.c.optimization.level.most" id="gnu.c.compiler.mingw.exe.release.option.optimization.level.1790292482" name="Optimization Level" superClass="gnu.c.compiler.mingw.exe.release.option.optimization.level" valueType="enumerated"/>
<option id="gnu.c.compiler.mingw.exe.release.option.debugging.level.652461532" name="Debug Level" superClass="gnu.c.compiler.mingw.exe.release.option.debugging.level" value="gnu.c.debugging.level.none" valueType="enumerated"/>
<inputType id="cdt.managedbuild.tool.gnu.c.compiler.input.40347474" superClass="cdt.managedbuild.tool.gnu.c.compiler.input"/>
</tool>
<tool id="cdt.managedbuild.tool.gnu.c.linker.mingw.exe.release.26878997" name="MinGW C Linker" superClass="cdt.managedbuild.tool.gnu.c.linker.mingw.exe.release"/>
<tool id="cdt.managedbuild.tool.gnu.cpp.linker.mingw.exe.release.157052916" name="MinGW C++ Linker" superClass="cdt.managedbuild.tool.gnu.cpp.linker.mingw.exe.release">
<inputType id="cdt.managedbuild.tool.gnu.cpp.linker.input.728829956" superClass="cdt.managedbuild.tool.gnu.cpp.linker.input">
</inputType>
</tool>
</toolChain>
</folderInfo>
</configuration>
</storageModule>
</cconfiguration>
</storageModule>
<project id="asfaleia_hw3.cdt.managedbuild.target.gnu.mingw.exe.1142478572" name="Executable" projectType="cdt.managedbuild.target.gnu.mingw.exe"/>
</storageModule>
<storageModule moduleId="refreshScope" versionNumber="1">
<resource resourceType="PROJECT" workspacePath="/asfaleia_hw3"/>
</storageModule>
<storageModule moduleId="scannerConfiguration">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId=""/>
<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807;cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807.;cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.debug.832048799;cdt.managedbuild.tool.gnu.c.compiler.input.278354826">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC"/>
</scannerConfigBuildInfo>
<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807;cdt.managedbuild.config.gnu.mingw.exe.debug.1009395807.;cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.debug.914486801;cdt.managedbuild.tool.gnu.cpp.compiler.input.1098279938">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP"/>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP">
<buildOutputProvider>
<openAction enabled="true" filePath=""/>
<parser enabled="true"/>
</buildOutputProvider>
<scannerInfoProvider id="specsFile">
<runAction arguments="-O2 -E -P -v -dD "${plugin_state_location}/specs.cpp"" command="g++" useDefault="true"/>
</scannerInfoProvider>
</profile>
<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.mingw.exe.release.586289962;cdt.managedbuild.config.gnu.mingw.exe.release.586289962.;cdt.managedbuild.tool.gnu.cpp.compiler.mingw.exe.release.282792496;cdt.managedbuild.tool.gnu.cpp.compiler.input.595440934">
</profile>
<scannerConfigBuildInfo instanceId="cdt.managedbuild.config.gnu.mingw.exe.release.586289962;cdt.managedbuild.config.gnu.mingw.exe.release.586289962.;cdt.managedbuild.tool.gnu.c.compiler.mingw.exe.release.1940416028;cdt.managedbuild.tool.gnu.c.compiler.input.40347474">
</storageModule>
</cproject>
FUDForum. Page generated in 0.03791 seconds
