Home » Modeling » OCL » Ocl expressions
Ocl expressions [message #876004] Wed, 23 May 2012 14:11 Go to next message
Hi guys!
I'm working with OCL expressions and I need a expression that
validate a string in the context that it starter with a letter and not
with caracteres as !,?,*,&,^%,$.
Some idea how can I do that?
I tried to do with a regular expression, but I had no success.
Thank's for the help and sorry for the english!
Re: Ocl expressions [message #876027 is a reply to message #876004] Wed, 23 May 2012 15:15 Go to previous messageGo to next message
With the Ecore-binding in Indigo; you have only substring.
With the Pivot-binding in Indigo; you also have characters(), at() to
play with.
In Juno, you have characters(), startsWith(), at(), match() to play with.
Ed Willink
On 23/05/2012 19:11, Pablo Silva wrote:
> Hi guys!
Re: Ocl expressions [message #876030 is a reply to message #876027] Wed, 23 May 2012 15:31 Go to previous messageGo to next message
In my case, I'm trying validate a name of the a node on my Ecore Model.
I'm using the interactive OCL console for try validate these expressions.
For example, I should create a expression as: self.name.startsWith('[a-zA-Z]')
Is this possible? OCL expressions accept regular expressions?
Re: Ocl expressions [message #876038 is a reply to message #876030] Wed, 23 May 2012 15:41 Go to previous messageGo to next message
And why would you think that startsWith takes a regular expression argument?
You really should consult some documentation or at least common sense.
What does Java do?
Ed Willink
Re: Ocl expressions [message #876054 is a reply to message #876004] Wed, 23 May 2012 16:23 Go to previous messageGo to next message
Because I'm a new user in the OCL.
I'm learning about that.
Actually I am trying to place restrictions on a GMF graphical editor that I created. But I want these restrictions are implemented in EMF Ecore Model, because then it will be easier to manage them.
I've done to restrictions such as the name of a Node can not be empty, or that two nodes can not have the same name.
Take a look in my Ecore Model open in OCLinEcore editor:
package my : my = 'my'
	class Graph
		invariant NoDuplicateEdgeNames: edges->forAll(e1, e2 | e1 <> e2 implies e1.name <> e2.name);
		invariant NoDuplicateNodeNames: nodes->forAll(n1, n2 | n1 <> n2 implies n1.name <> n2.name);
		invariant NoMultiGraphs: edges->forAll(e1, e2 | e1 <> e2 implies (e1.start <> e2.start) or (e1.end <> e2.end));
		invariant NoSameOneNodes: edges->forAll( e1, e2 | e1 = e2 implies e1.start<>e1.end);
		property nodes : Node[*] { composes };
		property edges : Edge[*] { composes };
		attribute name : String[?];
		annotation 'gmf.diagram'(onefile = 'true', 'diagram.extension' = 'Graph');
	class Node
		invariant noEmptyName: self.name->notEmpty();
		invariant noInvalidCaracter:;
		attribute startNode : Boolean[?];
		annotation 'gmf.node'(label = 'name', figure = 'ellipse');
	class Edge
		property start : Node[1];
		property end : Node[1];
		annotation 'gmf.link'(label = 'name', source = 'start', target = 'end', 'target.decoration' = 'arrow');
All constraints are working, but I don't know how to do for to validate a name as I said before!
I can't find a document with all methods of OCL. If you could show me a link where
I can get this, I'll be grateful!
Pablo Silva
Re: Ocl expressions [message #876078 is a reply to message #876054] Wed, 23 May 2012 17:26 Go to previous messageGo to next message
Have you tried Help Contents OCL Documentation?
Have you tried the OCL specification?
Ed Willink
> class Graph
> = 'Graph');
> class Node
> class Edge
> a link where
> Pablo Silva
Re: Ocl expressions [message #878702 is a reply to message #876004] Tue, 29 May 2012 15:12 Go to previous messageGo to next message
Thank's for the Help.
I gonna read the OCL specification.
Att.
Pablo Silva
Re: Ocl expressions [message #879340 is a reply to message #878702] Wed, 30 May 2012 22:26 Go to previous messageGo to next message
I have a question!
Can I in a let expression in OCL applied recursively?
[Updated on: Wed, 30 May 2012 22:27] by Moderator
Re: Ocl expressions [message #879386 is a reply to message #879340] Thu, 31 May 2012 01:43 Go to previous messageGo to next message
Yes, you can do
let a : A = ... in let b: B = ... in ....
but beware of complex usages such as
y + z + let a : A = ... in let b: B = ... in a + b + x
that are challenging to the reader and also to the OCL parser. The above
should be treated as
y + z + (let a : A = ... in (let b: B = ... in (a + b + x)))
but use parentheses for portability and readability.
You may prefer a multi-variable let
let a : A = ... ,
b : B = ...
in ....
Ed Willink
On 31/05/2012 03:26, Pablo Silva wrote:
> I have a question!
> In a let expression in OCL can be applied recursively?
Re: Ocl expressions [message #879725 is a reply to message #879386] Thu, 31 May 2012 14:18 Go to previous messageGo to next message
I try to do this expression:
def:validate(n:Integer):Boolean =
(self.name.substring(n,n)<='@' or self.name.substring(n,n)>='[') and (self.name.substring(n,n)<='`' or self.name.substring(n,n)>='{')= true
inv: let tam:Integer = self.name.size() in
validate(tam)
But is wrong. I would like to know if I can do that, i.e., use a def like a function?
Thank's for the help.
Re: Ocl expressions [message #879764 is a reply to message #879725] Thu, 31 May 2012 15:46 Go to previous message
You can certainly use def: to define an operation; that's what it is for.
But as in my answer on the other newsgroup you must use String not
'Character'.
Ed Willink
> true inv: let tam:Integer = self.name.size() in
> validate(tam)
> like a function?
Previous Topic:Traversing from child to parent in derived relation
Next Topic:Problems parsing ocl query
Current Time: Fri Jul 25 21:32:00 EDT 2025
Powered by FUDForum. Page generated in 0.27264 seconds
