How to run ATL using a java program? [message #879100] |
Wed, 30 May 2012 10:09  |
Hi there,
At the moment, I am running ATL program using eclipse Run Configuration, where i specify source.ecore, target.ecore, source.xmi, target.xmi.
Is there any way to run this ATL program using a java program? How to do that?
Thanks in advance !
Kosala
Re: How to run ATL using a java program? [message #884699 is a reply to message #884039] |
Mon, 11 June 2012 12:14  |
So, I found the problem with my properties file.
There is a video in youtube, that help me to solved it, but as I'm new member I can't put the link here, so if you want to see it, search by the following title: Atlas Transformation Language avec JAVA.mp4
It is in French, but is not too hard to understand what he is changing at Eclipse.
[Updated on: Mon, 11 June 2012 12:15] by Moderator
FUDForum. Page generated in 0.05306 seconds
