Home » Language IDEs » Java Development Tools (JDT) » debugging/breakpoint problem
debugging/breakpoint problem [message #87879] Thu, 21 August 2003 13:58 Go to next message
Originally posted by: Keith.Wannamaker.org
I've got a problem with Eclipse 2.1.1 on NT 4Sp6a using Sun JDK 1.4.1.
The trouble is that Eclipse will no longer debug programs. By this I mean
that breakpoints will stop a running 'debug' program, but the GUI acts as
if the program is not paused. The thread windows says the VM is not
paused, yet the program is stopped at a breakpoint. Once Eclipse gets
into this state, it affects every project in my workspace. It happened to
me about three weeks ago, and I was forced to reinstall eclipse and
re-import my workspace. Once I did that, it worked fine again.
Yesterday, the debugging stopped working again. I don't see any bug
reports about this, so I suspect it is user error. Has anyone encountered
this? How did you overcome it?
Keith
Re: debugging/breakpoint problem [message #87910 is a reply to message #87879] Thu, 21 August 2003 14:10 Go to previous messageGo to next message
Do you have the option to try debugging using a different JDK? (1.4.2 or
ensure you have the latest 1.4.1)
We saw weirdness with the earlier 1.4.1 VMs.
HTH
Darins
"Keith Wannamaker" <Keith@Wannamaker.org> wrote in message
news:bi317c$c7r$1@eclipse.org...
> Keith
Re: debugging/breakpoint problem [message #88003 is a reply to message #87910] Thu, 21 August 2003 16:52 Go to previous messageGo to next message
Originally posted by: maximgb.yandex.ru
On Thu, 21 Aug 2003 11:10:26 -0700, "Darin Swanson"
<Darin_Swanson@us.ibm.com> wrote:
Looks like I've got the same problem, the program stops at the
breakpoint but only resume/terminate commands available, stepping
commands disabled.
I use W2K SP3, JDK 1.4.2, Eclipse 2.1.1
Also I try to debug the WTK 1.1.4, 2.0 emulators with remote debug, on
70% cases the emulator crashes with
"zayit.exe - Application error
Instruction at address 0x00xxxxx tried to access memory at address
0x0000004
Memery couldn't be read" ( My translation, sorry if there are any
mistakes )
I have tried the JDK 1.4.1_03 results were exactly the same.
>HTH
>Darins
>> Thanks,
>> Keith
Re: debugging/breakpoint problem [message #88015 is a reply to message #88003] Thu, 21 August 2003 17:13 Go to previous messageGo to next message
We have a bug report for the "zayit" problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36100
For the stepping problem, do you have the debug view visible with a "valid"
selection (stack frame, thread).
HTH
Darins
"Maxim Bazhenov" <maximgb@yandex.ru> wrote in message
news:qmbakvccqa3ijetm0n43p5cn8e472vt6oj@4ax.com...
> commands disabled.
> 0x0000004
> mistakes )
> >HTH
> >Darins
mean
as
to
encountered
> >> Thanks,
> >> Keith
Re: debugging/breakpoint problem [message #88075 is a reply to message #88015] Thu, 21 August 2003 22:27 Go to previous messageGo to next message
On Thu, 21 Aug 2003 14:13:47 -0700, "Darin Swanson"
>HTH
>Darins
Yes, I have the debug view visible, but the suspended thread in the
debug window hasn't any childnodes
Re: debugging/breakpoint problem [message #88304 is a reply to message #88075] Fri, 22 August 2003 10:51 Go to previous message
Can you log a reproducible test case against jdt debug?
Darins
news:bnvakv86pvpnsipmsufj2v386aiikgh6b8@4ax.com...
"valid"
> >HTH
> >Darins
Previous Topic:How I do generation bookmarks for any class ?
Next Topic:Tomcat plugin
Current Time: Wed Jul 23 02:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.05235 seconds
