Home » Language IDEs » C / C++ IDE (CDT) » CDT install problem
| CDT install problem [message #87868] |
Fri, 28 November 2003 15:20  |
Originally posted by: eclipse.fenke.xs4all.nl
* OS is Win2K SP 2 (restricted user, full control on eclipse) *
* Eclipse Platform Version: 3.0.0 Build id: 200311211210 *
* CDT 2.0 M5 *
It seems I can not get the current release of CDT installed/configured
/working
There were no specific installation instructions, so I followed the hint
on the cdt-download page that cdt2 would only work with Eclipse 3, which
would require j2re 1.4 and downloaded:
J2RE 1.4.2_02 installer from Sun
Eclipse 3 Platform (eclipse-platform-3.0M5-win32.zip)
CDT 2 M5 (cdt-2.0M5-win32.zip)
Unpacked with pkzip25 (commandline) and copied the directories under
features and plugins to the eclipse directory. Without further
instructions I assumed that eclipse would be quite capable of finding
them there.
The following snippet is from the Configuration details:
*** Error Log:
!SESSION Nov 28, 2003 20:01:06.281
java.version=1.4.2_02
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:F:/usr/local/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 Nov 28, 2003 20:01:06.281
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Nov 28, 2003 20:01:06.281
!MESSAGE Plug-in descriptor "org.eclipse.cdt.core" not found for
fragment "org.eclipse.cdt.core.win32". Fragment ignored.
Directory plugins/org.eclipse.cdt.core.win32_2.0.0/ contains
\org.eclipse.cdt.core.win32_2.0.0\cdt_win32.jar
\org.eclipse.cdt.core.win32_2.0.0\cdt_win32src.zip
\org.eclipse.cdt.core.win32_2.0.0\fragment.properties
\org.eclipse.cdt.core.win32_2.0.0\fragment.xml
\org.eclipse.cdt.core.win32_2.0.0\os
\org.eclipse.cdt.core.win32_2.0.0\os\win32
\org.eclipse.cdt.core.win32_2.0.0\os\win32\x86
\org.eclipse.cdt.core.win32_2.0.0\os\win32\x86\listtasks.exe
\org.eclipse.cdt.core.win32_2.0.0\os\win32\x86\spawner.dll
\org.eclipse.cdt.core.win32_2.0.0\os\win32\x86\starter.exe
| Re: CDT install problem [message #87913 is a reply to message #87868] |
Fri, 28 November 2003 21:42   |
If you want to use cdt, you should have a external compiler such as cygwin
or mingw. VC++ is also available. visit the following site:
http://www.cygwin.com
http://www.mingw.org
And, if you want to develop an java project, you should use JDK instead of
JRE.
One more thing, you may have to download the eclipse-SDK-3.0M5-win32.zip
instead of eclipse-platform-3.0M5-win32.zip.
Jin-serk.
> * CDT 2.0 M5 *
> /working
> them there.
> *** Error Log:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> org.eclipse.cdt.core.win32_2.0.0cdt_win32.jar
> org.eclipse.cdt.core.win32_2.0.0cdt_win32src.zip
> org.eclipse.cdt.core.win32_2.0.0fragment.properties
> org.eclipse.cdt.core.win32_2.0.0fragment.xml
> org.eclipse.cdt.core.win32_2.0.0os
> org.eclipse.cdt.core.win32_2.0.0oswin32
> org.eclipse.cdt.core.win32_2.0.0oswin32x86
> org.eclipse.cdt.core.win32_2.0.0oswin32x86listtasks.exe
> org.eclipse.cdt.core.win32_2.0.0oswin32x86spawner.dll
> org.eclipse.cdt.core.win32_2.0.0oswin32x86starter.exe
| Re: CDT install problem [message #87943 is a reply to message #87913] |
Sat, 29 November 2003 04:32   |
Yes, various C/C++ compilers are present:
gcc 2.95 (mingw)
bcc 5.5
bcb 4
> JRE.
Not planning on doing any Java in the near future.
That seems to do the trick, the environment will load, I can add a
project, new source files etc...
Thanks.
PS, the editor view will give an error though when reading an external
c++ file
| Re: CDT install problem [message #87990 is a reply to message #87868] |
Sat, 29 November 2003 10:16   |
There is a little version bug in
<eclipse_path>/plugins/org.eclipse.cdt.core.win32_2.0.0/fragment.xml
Change the
plugin-version="1.2.0"
to
plugin-version="2.0.0"
This should get you guys rid of the error message.
> * CDT 2.0 M5 *
> /working
> them there.
> *** Error Log:
| Re: CDT install problem [message #88063 is a reply to message #87990] |
Sat, 29 November 2003 16:45   |
No that didn't help. I fixed the version in my fragment.xml (in the linux
directory), but the startup error is the same.
TTimo
On Sat, 29 Nov 2003 16:16:27 +0100
> Change the
> to
> > * CDT 2.0 M5 *
> > /working
> > them there.
> > *** Error Log:
| Re: CDT install problem [message #88079 is a reply to message #88063] |
Sat, 29 November 2003 16:52   |
Actually, it's a bit different. The error is gone, but I still don't have
any sign of CDT C/C++ developement perspective after starting M5.
TTimo
On Sat, 29 Nov 2003 22:45:20 +0100
> TTimo
> > Change the
> > to
> > > * CDT 2.0 M5 *
> > > /working
> > > them there.
> > > *** Error Log:
| Re: CDT install problem [message #88110 is a reply to message #88079] |
Sun, 30 November 2003 14:08   |
Found another report of this bug on bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47696
TTimo
On Sat, 29 Nov 2003 22:52:51 +0100
> TTimo
> > TTimo
> > > Change the
> > > to
> > > > * CDT 2.0 M5 *
> > > > /working
> > > > them there.
> > > > *** Error Log:
| Re: CDT install problem [message #88140 is a reply to message #88079] |
Sun, 30 November 2003 16:56   |
Originally posted by: sasschgmxnet.yahoo.de
> > > > /working
> > > > *** Error Log:
> > > Change the
> > > to
Hi!
I ran into the same error yesterday (on linux). So I
a) ...deleted the *cdt/ folders in features/ and plugins/
b) ...reran eclipse. Maybe there is a smarter way to make it reread it's
actual conf - but it was my first contact with eclipse at all.
c) ...unpacked the cdt files and changed the plugin-version as suggested
above _before_ I
d) ...restarted eclipse.
You may even completely remove eclipse, reinstall it, install cdt, correct
the fragment.xml and then fire up eclipse for the first time, presuming,
you are privileged to do so.
The trick is, IMHO to make eclipse rebuild it's conf - after the changes
took place.
Just my 2ct.
Sascha
ps: sorry for reformatting...
Sascha Schwarz Please followup to the group.
Darmstadt/Germany
| Re: CDT install problem [message #88170 is a reply to message #88140] |
Sun, 30 November 2003 19:28   |
you could try
$ eclipse -data $HOME/workspace -initialize
Suppose, you want your workspace outside the eclipse-directory.
Initialize should reinitialize the Eclipse-Configuration. Otherwise,
you might think of deleting the workspace/.metadata directory.
And I believe, there is a eclipse/.config directory, which should contain global
configuration as workspace/.metadata should be per user. *think*
>>>>>/working
>>>>>*** Error Log:
>>>>Change the
>>>>to
> Hi!
> above _before_ I
> took place.
> Just my 2?ct.
> Sascha
> Darmstadt/Germany
| Re: CDT install problem [message #88223 is a reply to message #88170] |
Mon, 01 December 2003 05:49  |
Ah, this explains .. ok, I'm finally using 3.0 and CDT now, bye bye 1.2
TTimo
On Mon, 01 Dec 2003 01:28:43 +0100
> you could try
> >>>>>/working
> >>>>>*** Error Log:
> >>>>Change the
> >>>>to
> > Hi!
> > above _before_ I
> > took place.
> > Just my 2?ct.
> > Sascha
> > Darmstadt/Germany
Current Time: Sun Nov 09 04:37:52 EST 2025
Powered by FUDForum. Page generated in 0.04490 seconds
