Home » Modeling » TMF (Xtext) » Can't get 5 minute tutorial to build(Throwing exception when running mwe2 to generate sources)
Can't get 5 minute tutorial to build [message #877117] Fri, 25 May 2012 18:57 Go to next message
After installing xtext plugin I attempted to run the 5 minute tutorial but get the following error:
1 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: org.apache.commons.logging.LogConfigurationException: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform (Caused by java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform)
java.lang.RuntimeException: Problems instantiating module org.xtext.example.mydsl.GenerateMyDsl: org.apache.commons.logging.LogConfigurationException: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform (Caused by java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Platform
When I run the tutorial in the preconfigured eclipse from itemis website it works fine. I made sure the plugins that were installed there are in my version of eclipse.
Any ideas?
Re: Can't get 5 minute tutorial to build [message #878434 is a reply to message #877117] Tue, 29 May 2012 05:41 Go to previous message
How did you install Xtext? Which version do you use?
Sebastian
Am 26.05.12 00:57, schrieb Todd Stevenson:
> Any ideas?
Previous Topic:JVM inferred objects and content assist
Next Topic:Manually Maintained Metamodel
Current Time: Sat Jul 19 03:07:44 EDT 2025
Powered by FUDForum. Page generated in 0.03000 seconds
