[Acceleo] generation exception after deploy [message #878415] |
Tue, 29 May 2012 05:02  |
Hello all,
I have an Acceleo transformation which works fine when invoked from the target platform launched from Eclipse (PDE launch configuration).
When I try to deploy the jars of the same plug-ins I get the following exception:
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoS
ervice.java:565)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(
AbstractAcceleoGenerator.java:193)
at com.thalesgroup.dts.l905.dti.export.ui.ControlUnitGenerator$1.run(Con
trolUnitGenerator.java:45)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(Modal
Context.java:121)
It seems that the template files do not get loaded properly - that line accesses the type of a parameter of the main template - which is a class defined by my own ecore model.
I've checked and all plugins seem to be resolved.
Has anyone had this problem before ? What could be wrong ?
How can I further diagnose this problem ?
Any help would be greatly appreciated.
I use acceleo 3.2.0 / Indigo SR1.
Vlad Gheorghe
FUDForum. Page generated in 0.03531 seconds
