Home » Archived » Test and Performance Tools Platform (TPTP) » Starting Agent Controller on Linux failing
Starting Agent Controller on Linux failing [message #86147] Wed, 01 November 2006 06:15 Go to next message
Originally posted by: dineshjain22.yahoo.com
Hi all,
I am not able to start the Agent Controller on Linux machine.
I have installed "agntctrl.linux_ia32-TPTP-4.2.1" on Linux (SLES 10 and RHEL
7.3).
The SetConfig.sh got executed properly, but on running RAServer, following
error is thrown:
#./RAServer
../ACServer: error while loading shared libraries:
/dinesh/agntctrl.linux_ia32-TPTP-4.2.1/lib/libtptpUtils.so.4 : file too short
I have tried this with IBM JVM 1.5.1 as well 1.4.2. But I guess JVM seems to
be not the issue here.
I have also ensured the things mentioned in "Prerequisites" as well
"Configuring and Starting Agent Controller"
which is documented at the below link:
http://www.eclipse.org/tptp/home/downloads/installguide/agen tcontroller_42/linux_ia32/getting_started.html
Please let me know. Any help will be greatly appreciated.
Thanks in advance,
Dinesh
Re: Starting Agent Controller on Linux failing [message #86179 is a reply to message #86147] Wed, 01 November 2006 12:38 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0060F25A85257219_=
Content-Type: text/plain; charset="US-ASCII"
Download the what's listed under the 'Agent Controller' section of this
site:
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.3.0- 200610310100.html
Don't download the 'New technology Agnet Controller'
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Download the what's listed under the
'Agent Controller' section of this site: http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.3.0- 200610310100.html</font>
<br><font size=2 face="sans-serif">Don't download the 'New technology Agnet
Controller'</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0060F25A85257219_=--
Re: Starting Agent Controller on Linux failing [message #87824 is a reply to message #86147] Fri, 17 November 2006 13:45 Go to previous messageGo to next message
What were you using to unpack the zip file? The Agent Controller will
only work if unpacked by the "unzip" utility on Linux since symbolic
links will be created.
Samson
Dinesh Jain wrote:
> Hi all,
> 7.3).
> error is thrown:
> #./RAServer
> Thanks in advance,
> Dinesh
Re: Starting Agent Controller on Linux failing [message #87980 is a reply to message #87824] Mon, 20 November 2006 06:52 Go to previous messageGo to next message
Hi Samson,
Thanks a lot for the help you provided. I used unzip utility and ran the
SetConfig utility.
I am running this on SLES 10 and using "New Tchnology Agent Controller"
downloaded from -
On starting the Agent Controller daemon (./ACStart.sh), it says:
Error starting transport layers, Agent controller exiting.
See servicelog.log for error report.
ACServer failed to start.
I couldn't figure out the problem with it. Any help with this will be
The log file <install-dir>/config/servicelog.log contains following
information logged with it:
<CommonBaseEvent creationTime="2006-11-20T18:29:39.979035Z"
globalInstanceId="A561F413000EF04C52EF84336FA1F7C8" msg="Unable to create
shared memory: acbuffer." severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent" executionEnvironment="SharedMemListener.c,
line 222" instanceId="1003" location="myhost.com" locationType="IPV4"
processId="2807" subComponent="Shared Memory TL" threadId="2807"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-11-20T18:29:39.979722Z"
globalInstanceId="A561F413000EF3052E4A5FDC4EE45AA9" msg="An error was
returned from TransportLayer(1003)::startTransportLayer errNum = -3"
componentIdType="TPTPComponent" executionEnvironment="ConnectionManager.c,
line 263" instanceId="2" location="myhost.com" locationType="IPV4"
processId="2807" subComponent="Connection Manager" threadId="2807"
<situationType
</situation>
</CommonBaseEvent>
Please let me know,
-Regards,
Dinesh
"Samson Wai" <samwai@ca.ibm.com> wrote in message
news:ejl000$l51$1@utils.eclipse.org...
> Regards,
> Samson
> Dinesh Jain wrote:
> > Hi all,
RHEL
> > 7.3).
following
> > error is thrown:
> > #./RAServer
short
seems to
> > Thanks in advance,
> > Dinesh
Re: Starting Agent Controller on Linux failing [message #88082 is a reply to message #87980] Mon, 20 November 2006 12:16 Go to previous messageGo to next message
Are you sure you would like to use the "New Technology Agent Controller".
It is not as stable as the Original "Agent Controller". I would try
downloading the original Agent controller. You could tell the difference
between the two by their file names once you have downloaded them. The
original Agent Controller zip file name starts with tptpdc.* while the
"New Technology Agent Controller" starts with agntctrl.*
To fix the problem you are having:
Check whether you accidently started the Agent Controller perviously, but
running:
ps -e |grep AC
or
ps -e |grep RA
if any processes show up as either ACServer, or RAServer, then kill that
process. Then make sure port 10002 is free by executing:
netstat -a |grep 1000
Also make sure you do not have any lingering java processes:
ps -e |grep java
if any java process exist, terminate them.
Finally check the folder: /tmp/IBMRAC
if there are any files in that folder, please remove them all, and
re-start the Agent Controller.
Good Luck.
Re: Starting Agent Controller on Linux failing [message #88111 is a reply to message #88082] Mon, 20 November 2006 12:51 Go to previous messageGo to next message
Thay Shanmugaratnam wrote:
> Controller". It is not as stable as the Original "Agent Controller". I
> would try downloading the original Agent controller. You could tell the
> difference between the two by their file names once you have downloaded
> them. The original Agent Controller zip file name starts with tptpdc.*
> while the "New Technology Agent Controller" starts with agntctrl.*
> To fix the problem you are having: Check whether you accidently started
> the Agent Controller perviously, but running:
> ps -e |grep AC
> or ps -e |grep RA
> ps -e |grep java
> Good Luck.
Given that the original logfile that Dinesh gave us indicated that there
was a problem initializing the SharedMemTL, I think we need to add the
following to the list of things to try:
ipcs
Then ipcrm the shared memory fragments lingering.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Starting Agent Controller on Linux failing [message #88384 is a reply to message #88111] Tue, 21 November 2006 23:23 Go to previous messageGo to next message
Hi Randy,
Thanks for having a deep look into it. Unfortunately, I couldn't figure out
what exactly you mean by following:
"I think we need to add the following to the list of things to try:
ipcs
Then ipcrm the shared memory fragments lingering."
By this, do you mean its a bug with the New Technology Agent Controller 4.3
on SLES 10?
or do you mean to say modifying something with the serviceconfig.xml file,
which will make it work?
Please let me know,
-Dinesh Jain.
"Randy D. Smith" <randy.d.smith@intel.com> wrote in message
news:ejspvv$vhh$1@utils.eclipse.org...
> > Hi,
> > ps -e |grep AC
> > or ps -e |grep RA
> > ps -e |grep java
> > Good Luck.
> ipcs
> RDS
Re: Starting Agent Controller on Linux failing [message #88458 is a reply to message #88384] Wed, 22 November 2006 10:42 Go to previous message
Dinesh Jain wrote:
> Hi Randy,
> ipcs
> on SLES 10?
> Please let me know,
> -Dinesh Jain.
I mean that unsuccessful runs of the agent controller (I think both old
and new) can leave shared memory segments tied up. ipcs will show you
those shared memory segments... they usually come in threes as I recall.
Then "ipcrm shm <#>" will remove the ones you own.
I've seen this on various Linux systems... not just SLES. I seem to
recall it is more likely with the new tech AC because (at least at one
time) we were allocating shared memory in bigger chunks.
RDS
Previous Topic:TPTP Code Coverage
Next Topic:Problems getting AGR to work wth RCP
Current Time: Fri Nov 07 19:25:39 EST 2025
Powered by FUDForum. Page generated in 0.04492 seconds
