Home » Modeling » Compare » EMF plugin build setup (Solved)(How to setup build and necessary Jars)
EMF plugin build setup (Solved) [message #878235] Mon, 28 May 2012 18:19 Go to next message
What is the process to download EMF Compare source and build it on one's computer via git?
I went to the eclipse git repository and cloned the git repo for EMF Compare. But the repo does not contain any of the jar files. How do I know what jar files to install?
[Updated on: Fri, 24 August 2012 14:59] by Moderator
Re: EMF plugin build setup [message #878640 is a reply to message #878235] Tue, 29 May 2012 12:26 Go to previous messageGo to next message
I have looked at the issue a bit more and I found a website on EMF Compare's website that talks about setup.
They say you need new Eclipse and EMF SDK's as dependencies. They say use either import the workspace plug-in or packaging. But the import of those workspaces still has dependency errors.
Also how do you build the project and test it?
Re: EMF plugin build setup [message #903663 is a reply to message #878640] Fri, 24 August 2012 14:58 Go to previous message
This question was solved in EMF forum post#: 879307
Previous Topic:Naming Concept Left/Right
Next Topic:[EMF Compare] Moving items bug or by design?
Current Time: Wed Jul 23 13:19:34 EDT 2025
Powered by FUDForum. Page generated in 0.04270 seconds
