Home » Modeling » EMF » XML Serialization of not-set required attributes/elements
XML Serialization of not-set required attributes/elements [message #877838] Sun, 27 May 2012 18:06 Go to next message
I have a question, I have an efeature which is required but does not have its default value set (it is null). How can I
force that it is serialized to xml?
Currently it seems that if an efeature is not set and has a null value or no default value then it is not serialized.
I can override the XMLSaveImpl.shouldSaveFeature to always write out required efeatures. Does it make sense?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: XML Serialization of not-set required attributes/elements [message #877931 is a reply to message #877838] Mon, 28 May 2012 01:09 Go to previous messageGo to next message
Hi Martin
I think XMLResource
* Keep default content ( e.g. default attributes). This applies to
saving and converting contents to DOM.
* By default the default content is discarded.
* To save the default content, set this option to
<code>Boolean.TRUE</code>.
String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";
is what you want in the saveOptions map.
Ed Willink
On 27/05/2012 23:06, Martin Taal wrote:
> have its default value set (it is null). How can I force that it is
> serialized to xml?
Re: XML Serialization of not-set required attributes/elements [message #877960 is a reply to message #877931] Mon, 28 May 2012 03:03 Go to previous messageGo to next message
Hi Ed,
This feature only works if there is a default value but if there is no default value then nothing is serialized, no
default value means also null which is a perfectly fine default value imho.
So my question is specifically for the case of a (required) efeature which has a null default value, how can I get it
serialized if its value is null?
gr. Martin
On 05/28/2012 07:09 AM, Ed Willink wrote:
> Hi Martin
> I think XMLResource
> * Keep default content ( e.g. default attributes). This applies to saving and converting contents to DOM.
> * To save the default content, set this option to <code>Boolean.TRUE</code>.
> Regards
> Ed Willink
>> Hi,
>> I force that it is serialized to xml?
The Netherlands
Re: XML Serialization of not-set required attributes/elements [message #877980 is a reply to message #877960] Mon, 28 May 2012 04:34 Go to previous messageGo to next message
Hi Martin
xsi:nil is what you need to end up with; I can't see an XMLResource
option, XMLSaverImpl.saveNil seems to be a narrower overload. Of course
if your clever with ExtendedMetaData you can probably do anything.
Ed Willink
On 28/05/2012 08:03, Martin Taal wrote:
> Hi Ed,
> default value then nothing is serialized, no default value means also
> which has a null default value, how can I get it serialized if its
> value is null?
> gr. Martin
>> Hi Martin
>> I think XMLResource
>> Regards
>> Ed Willink
>>> Hi,
Re: XML Serialization of not-set required attributes/elements [message #877989 is a reply to message #877980] Mon, 28 May 2012 04:56 Go to previous messageGo to next message
Hi Ed,
Thanks, yes I will override to get it done, I just wondered how 'incorrect' that would be.
gr. Martin
On 05/28/2012 10:34 AM, Ed Willink wrote:
> Hi Martin
> xsi:nil is what you need to end up with; I can't see an XMLResource option, XMLSaverImpl.saveNil seems to be a narrower
> overload. Of course if your clever with ExtendedMetaData you can probably do anything.
> Regards
> Ed Willink
>> Hi Ed,
>> gr. Martin
>>> Hi Martin
>>> I think XMLResource
>>> Regards
>>> Ed Willink
>>>> Hi,
The Netherlands
Re: XML Serialization of not-set required attributes/elements [message #877993 is a reply to message #877960] Mon, 28 May 2012 05:02 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Martin,<br>
<br>
Is your question about a model that's in an invalid state?&nbsp; A
required feature must be considered set if it is unsettable or must
have a non-null value otherwise:<br>
<br>
<small>&nbsp;&nbsp;&nbsp; else if (eStructuralFeature.isRequired())<br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (eStructuralFeature.isUnsettable() ?
!eObject.eIsSet(eStructuralFeature) :
eObject.eGet(eStructuralFeature, false) == null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; result = false;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (diagnostics != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; diagnostics.add<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (createDiagnostic<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (Diagnostic.ERROR,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; DIAGNOSTIC_SOURCE,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EOBJECT__EVERY_MULTIPCITY_CONFORMS,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; "_UI_RequiredFeatureMustBeSet_diagnostic",<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; new Object [] { getFeatureLabel(eStructuralFeature,
context), getObjectLabel(eObject, context) },<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; new Object [] { eObject, eStructuralFeature },<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; context));<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
</small><br>
Is the feature an EAttribute? In&nbsp; the serialized XML, is supposed to
appear as an XML attribute? In such a case, it's better to ensure
the model's state is valid by setting the value you want serialized.<br>
<br>
<br>
On 28/05/2012 9:03 AM, Martin Taal wrote:
<blockquote cite="mid:jpv80u$t35$1@xxxxxxxxe.org" type="cite">Hi
Ed,
<br>
is no default value then nothing is serialized, no default value
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">Hi Martin
<br>
<br>
I think XMLResource
<br>
<br>
<br>
<br>
<br>
&lt;code&gt;Boolean.TRUE&lt;/code&gt;.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
Re: XML Serialization of not-set required attributes/elements [message #878206 is a reply to message #877993] Mon, 28 May 2012 16:34 Go to previous messageGo to next message
Hi Ed,
Hmm, okay, but the same question applies to non-required efeatures, I would like to have these also serialized even if
the value is empty/null, this doesn't happen even if I set the keep default content option, as the eattribute does not
have a default value (it is null, which I want to have serialized also).
gr. Martin
On 05/28/2012 11:02 AM, Ed Merks wrote:
> Martin,
> Is your question about a model that's in an invalid state? A required feature must be considered set if it is unsettable
> or must have a non-null value otherwise:
> if (eStructuralFeature.isUnsettable() ? !eObject.eIsSet(eStructuralFeature) : eObject.eGet(eStructuralFeature, false) ==
> null)
> result = false;
> diagnostics.add
> (createDiagnostic
> (Diagnostic.ERROR,
> DIAGNOSTIC_SOURCE,
> new Object [] { getFeatureLabel(eStructuralFeature, context), getObjectLabel(eObject, context) },
> context));
> Is the feature an EAttribute? In the serialized XML, is supposed to appear as an XML attribute? In such a case, it's
> better to ensure the model's state is valid by setting the value you want serialized.
>> Hi Ed,
>> gr. Martin
>>> Hi Martin
>>> I think XMLResource
>>> Regards
>>> Ed Willink
>>>> Hi,
The Netherlands
Re: XML Serialization of not-set required attributes/elements [message #878341 is a reply to message #878206] Tue, 29 May 2012 01:33 Go to previous message
Martin,
Comments below.
On 28/05/2012 10:34 PM, Martin Taal wrote:
> Hi Ed,
> would like to have these also serialized even if the value is empty/null,
In that case, it's certainly not an issue of conformance to a schema,
but rather a stylistic preference. In any case, something needs to be
serialized, so setting what that should be as the default and
instructing the serializer to use what's specified should do the trick...
You're right, not if there is no default. Keep in mind that if you want
to serialize as an attribute, there isn't a way to represent null as an
attribute other than its absence. Also note that if you make your
features unsettable, and set a feature, you'll definitely always get
something serialized.
> as the eattribute does not have a default value (it is null, which I
An xsi:nil="true" XML element is okay?
> gr. Martin
>> Martin,
>> null)
>> result = false;
>> diagnostics.add
>> (createDiagnostic
>> (Diagnostic.ERROR,
>> DIAGNOSTIC_SOURCE,
>> context));
>> want serialized.
>>> Hi Ed,
>>> value imho.
>>> gr. Martin
>>>> Hi Martin
>>>> I think XMLResource
>>>> Regards
>>>> Ed Willink
>>>>> Hi,
Previous Topic:NPE in EcoreSchemaBuilder transformDefaultValue
Next Topic:Model Package not registered
Current Time: Thu Jul 24 04:59:07 EDT 2025
Powered by FUDForum. Page generated in 0.05298 seconds
